Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
It almost killed my nf7-s and I'm still not sure it didn't kill me...
Thread Tools
Old 09-02-03, 11:38 AM Thread Starter   #1
Lithan
Disabled
Lithan's Avatar
But my pump has been upgraded, my northbridge has a cck-6035 on it. My mosfets are actively cooled, and my front (radiator) fan is now pulling are in through the radiator, instead of out. Oh yeah, and the 120mm grills in the back have been cut out.
I spent thirty minutes trying to get a boot (kept getting either cmos error or nothing) and eventually figured it was dead... then I went through the long process (a good 20 minutes) of taking off my northbridge sink just to be sure and saw some metal shavings and as3 shorting there (dont ask me how the as3 got there. the shavings I have a good idea). Swept it up, tested it with stock sink, worked fine. So I spent 4 hours putting everything back together (Took alot of careful maneuvering as I use very tough tubing that doesn't like bending) and finally at 8 am my system was put together enough to get into windows. I'm going to switch the fan I've on the radiator, as the rheo on the current fan puts out too much heat, and I must add my optical drives and usb/firewire ports... but otherwise it's pretty well done. I get pics as soon as possible.
Lithan is offline   QUOTE Thanks
Old 09-02-03, 03:26 PM   #2
pummer
pummer's Avatar
ouch. how'd you get shavings there?
pummer is offline   QUOTE Thanks
Old 09-02-03, 05:32 PM   #3
cherryp00t
from cutting teh 120 mm fan holes in the case.. hehe at least its the only thing that would make sense =d
cherryp00t is offline   QUOTE Thanks
Old 09-02-03, 05:48 PM   #4
eXCeSS
eXCeSS's Avatar
lol silly you, take your stuff out next time
eXCeSS is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
