Best Heatsink NOT requiring motherboard removal
poopyman67
I am looking for a good heatsink, however, most of the high performance ones out there require that you remove the mobo to install the mounting bracket, etc. I really don't wanna do this, and was wondering, what is the best heatsink/fan that does not require you to do this??
Noise is NOT a problem, as long as its not outrageous, and if u k2n, I have a Gigabyte 8KNXP. Thanks for the help!
I'd look at a Swiftech MCX478-V with either a 92mm Panaflo H-1 or the 92mm Enermax. I believe with the Zalmans you don't need to remove the mobo either and from what I hear are excellent, but I've never tried them.
hmm, swiftech, yeah, they make pretty good stuff, and I know zalman is also really good. Any1 know of any others?
You DO need to remove the board to install the Zalman...unless ( like me) you have skeletonized the motherboard wall for a fan.
crap, i really dont want 2 have 2 take out my mobo. Its really a big inconvienience.
ah well there ya go poopyman67, told ya i never used one before :)
Get a thermalright SLK-900A. You don't need to remove your board and it's pretty much the 3rd best, after the SLK-947U and SP-97.
clocker2 said:
I understand.
There's 15 minutes shot to hell....
(grin) I used to dread having to remove the mobo, but at this point I've taken it out so many times that it doesn't even phase me. No matter which HS I used, I found that removing the mobo made its installation much easier, including the SLK-900A.
hafa said:
15 minutes? Man, don't I wish! It takes me 15 minutes just to remove the 37 i/o cables on the back of the unit and losen the screws on the 5 pci cards. Then we get to deal with 6 hard drives...
Just out of idle curiosity, why must you remove your HDDs to take out the motherboard?
And 37 I/O cables?
Surely you exaggerate...
I have a Swiftech MC370 and I wish every manufacturer would go this kind of clip retention setup. If it weren't for reapplying thermal interface, you can install/remove the heat sink in under five minutes. I save that heatsink for testing my new CPU's and mobos that come in to make sure they're not defective.
i agree with blkgti
although i still haven't got my sp-97 to work, it was the first time ive taken out my mobo EVER. it was really easy, and i don't know how you got it set up, ,but i never removed any drives.
had to wiggle the mobo around a bit to get it out and back in, but wasnt a big deal
Wait....why do you need to remove the motherboard? I have a Zalman and I didn't need to remove the motherboard.
i think im going with the SLK-900A. Thermalright makes some pretty good stuff.
NOOOO!!! THIS ISN'T Compatible with INTEL!!! FUDGE!! Gotta find a different one!
I found my answer!!!!!! The gigabyte pro cool 3-d or whatever its called, no removal of mobo and performance within 1-2 C!!!!! Ohh yeah!! Gigabyte 2 the rescue!!
Perhaps you have a different model than I.
I have the 7000cu and it mounts onto two brackets that are screwed into the motherboard.
You must access the rear of the board to install the bracket screws....
