Notices
Overclockers Forums > Hardware > Motherboards > General Motherboards
Forum Jump
Need mobo advice (picking RAM)
Thread Tools
Old 02-28-04, 08:54 PM Thread Starter   #1
TehGoober
Ok, what I'm want to do is put 1 or 2 1GB sticks of DDR RAM (either PC2700 or PC3200) in to a motherboard but I want to be able to use HD RAM (as it's less costly than LD.)
My problem is that I've been reading that HD RAM is usually incompatible with, well, ALL Asus boards as well as ALL Nforce2 boards. Does anyone have any suggestions?
Looking to set up something like this:
AMD XP 2500ish
Radeon 9800 Pro (ish, maybe soon or later...)
HDD
CD burner
1-2 GB RAM (would prefer it have the option of using PC3200+ but PC2700 is fine.)
Built in LAN is a plus but I'm using wireless and will be getting something that plugs into the USB port anyway.
Floppy
Something like that. Also, I'm probably not going to be overclocking this one. Does anyone have a nice cheapy mobo that I can get? Or perhaps they can clear up a misconception about the High/Low density RAM in Asus boards/Nforce2 Chipsets. (This is relating to 1GB DIMMs only.)
Thanks
TehGoober is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 03-02-04, 02:53 PM Thread Starter   #2
TehGoober
bump
Anybody hear use 1GB sticks and have any info?
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
