Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
My Computer heats up my room!
Thread Tools
Old 03-11-04, 10:00 PM   #21
Fu_Man_Chew
Fu_Man_Chew's Avatar
"Either you guys have rooms the size of a closet..." I got a friend with a room like that 6' x 9' on the second floor and south side of the house!! the roof cuts down past a third of the room. You can't use the computer from 12:00 to 2:00. The funny part is he joined the military and has a larger living space in barracks…
Also point the fan in your room. The colder air in on the floor.. Warm air rises.
Fu_Man_Chew is offline   QUOTE Thanks
Old 03-11-04, 11:05 PM   #22
ZachM
ZachM's Avatar
I know that when I go over to my friend's house and we are both gaming on our comps with the door closed it gets hot in the room. The room our computers are in is noticable hotter than the rest of the house. Usually one computer doesn't do much, but when you get a couple of high performance systems running at load in the same room, they can warm the room pretty quickly.
__________________
Heatware
ZachM is offline   QUOTE Thanks
Old 03-11-04, 11:22 PM   #23
Leviathan41
Leviathan41's Avatar
Wow I didn't know so many other people had the same issue. My room is pretty small and my computer does heat it up a lot. I usually open a window and put a box fan in it, it helps a lot. I'm really dreading the summer months, I think I may have to build a duct because we have central cooling but not much cool air gets upstairs. Heat rises and my dark roof absorbs all the sun that shines on it and there is little shade around the house. It was hot in my room during summer before I built this rig, no telling what it is going to be like now.
Leviathan41 is offline   QUOTE Thanks
Old 03-12-04, 01:38 AM   #24
Jackaroo
honda_man, I think you have no clue how hot computers can get. I put my hand over my psu's exhaust and its a little more then warm. Yes a computer will raise a rooms temp if it isnt well ventalated. It will no matter how big the room is. If you have a computer room (no ventelation) @ 75 degrees and your computer is running 110 exhaust, the room will eventualy get that warm because there is no were for the heat to go.
Jackaroo is offline   QUOTE Thanks
Old 03-12-04, 06:38 AM   #25
g0dM@n
Inactive Moderator
g0dM@n's Avatar
10 Year Badge
This is a really awesome thread. I don't know why I didn't make one just like this myself. Just this past summer I went lef my appartment at college to go home for about a month. I hooked both of my overclocked computers up in my bedroom, located on the 2nd floor of my house.
I have:
Gaming PC.....................................Everything else PC
ASUS A7N8X-DEL 2.0.............................EPOX 8RDA+
2500Barton 210x11@1.74V.....................1700xp 200x11.5 1.7V
ATI Radeon 9700Pro (retail)....................Xtasy GF4 TI4600
2x256 Geil Dragon PC3500 2/3/3/7@2.8....Geil 256 PC2700 2.5cas
WD 80gig Special Ed. 7200.....................WD 120&80gig Spec. Ed.
Lite-On 40x CDRW & Sony DVD 16X..........NEC 4X DVD+R
SB Audigy Gamer..................................SB Audigy Platinum
6 Blue LED case fans.............................5 Blue LED case fans
SLK-800u with Vantec Tornado...............ThermalT Volcano 11+
Aspire X-DreamerII 350W (new PS?).........Enermax 300W seethru
Vantec Nexus fan controller (blue LED)......Vantec Iceburg (copper)
Let me just tell you that my dad would always say "What the hell... your room is the hottest room in the house. It stinks b/c it's so hot in there. Turn those damn things off."
Wow did it get HOT in my room in the summer (even with central air on 24-7) I'd either have to turn off the gaming PC and put a fan in my room, or go sleep in the basement in the extra room. It aint bad at all now using it as heat for the winter.
__________________
ASUS Crosshair V *Water* | FX-8320 Enzotech Sapphire CPU block | 8GB Mushkin 2133 | 6970 2GB | 256GB SSD | SB X-Fi Elite Pro | Corsair 520W Modular | 3x 26" Asus VW266H Eyefinity 5760x1200 | DDC pump with petra top @ 18w, Thermochill HE 120.3 w/ 3x120x38mm Deltas 152cfm on controller |
Xbox 360 Gamertag: g0dMAn114
Top 5 Heatware
**IHS Removal Tutorial**HotFlashing Tutorial**DFI NF4 UTT Problems**Funny-ChuckNorrisFacts**Custom RAM Cooler**
nightelph: I wanted to play so bad last night but I was OC'ing my video card.
g0dM@n is offline   QUOTE Thanks
Old 03-12-04, 07:25 AM   #26
rogerdugans
Linux challenged Senior, not that it stops me...
rogerdugans's Avatar
A room with poor ventilation can be heated up fairly easily over a period of time: add heat and then don't let it get away= higher temps.
Try a simple experiment-
put a thermometer in a closet and leave the door open, wait an hour and record the temp.
add a light with 100watt bulb (turned on of course!) and wait an hour- record temp again.
Now close the door and leave the light on. Cover any gaps around the door if you can. Wait the same hour and check the temp again.
The first two will be about the same but the third will be higher. This shows the effect of adding a heat source both with and without ventilation.
The key is to think of the room exactly the same as your computer case: if you have bad airflow, temps WILL go up inside.
Just how much depends on how hot your chip(s) is(are).
In my case, I have one chip around 120watts, 4 around 90ish and one dually around 60per cpu (I think...). that is about 600 watts. (All numbers are rough guesstimates based on old calcs.)
If the window down here is NOT cracked on even the coldest days it warms up pretty quick.
__________________
Still overclocked and running linux on watercooled computers after all these years.
rogerdugans is offline   QUOTE Thanks
Old 03-12-04, 02:02 PM   #27
SewerBeing
Grasshoppa Senior
SewerBeing's Avatar
Quote:
Originally posted by honda_man
You people have no clue what you are talking about. A computer will not raise the temps in a room. In order for that to happen you would have to have 20 computers running to notice a difference. I run three 24 hrs a day, seven days a week and it has no effect on my room. My computer room is only 7' x 9'. I do not have a problem. Of course I know what indoor air quality means. Do you?
I must say, my pc heats up my room like 5C, and it only runs 6 hours perday. so I do notice. (I do not mean to insult you, just making a point)
__________________
"Unlike Windows, Linux tries to happily coexist with other OS's. It's not like Windows which will go out of its way to break other installs." MRD
"On the second day of the seventh month, in the third year of the new milenium, Wedo looked down and saw new pow-ah join team 32, and it was good." Wedo
"I switch Oses like most people change pants. :)" rogerdugans
"Always be sure to flash your bios during lightning storms!" MRD
Please Fold for team 32!
portage > apt > source > rpm > windows update
Gautam is a water buffalo
SewerBeing is offline   QUOTE Thanks
Old 03-12-04, 02:10 PM   #28
ccb056
ccb056's Avatar
I've got 4 pc's in the same room right now.
3x AMD Athlon XP2100
1x Intel Celeron 667
and my room is approx 5 degrees hotter than any other room.
It really has to do with were the sun is relative to the room, if the sun is shining directly on the room, it should be hot, fortunately, this room doesnt see alot of sun
ccb056 is offline   QUOTE Thanks
Old 03-12-04, 02:39 PM   #29
mccoyn
Senior Member
mccoyn's Avatar
An "air handler" that is supposed to cool my office has been broken. Lets see, there are 10 computers in the room and up to 5 people. I'd only consider one computer to be a performance computer though and they are all running at stock. Temps are definantly running high in here. I get the ice wall effect when I leave the door. When the air handler was working there wasn't a noticable difference.
Fortunatly, at home my apartment is very well ventalated with large cold air vents in every room. My computer is in the dining room, which is open to the large main living room. I've never noticed a problem with it, but the temperature is always well controled by the thermostat and either the heater or the AC.
__________________
Once there was a caterpillar who had commas for legs. Which meant he had to allow a literary pause after each step. The other caterpillars really respected him for it and he came to have quite a commanding presence. Oh, and talk about a philanthropist! He was notorious for giving fresh leaves to those less-fortunate.
mccoyn is offline   QUOTE Thanks
Old 03-12-04, 03:19 PM   #30
-SSS-FireFly
My main PC doesn't heat up my room at all...case temps are a constant 1*F over ambient at full load.
The thing that heats up my room is the audio system...hehe...
-SSS-FireFly is offline   QUOTE Thanks
Old 03-12-04, 04:31 PM   #31
Busty St. Clair
Busty St. Clair's Avatar
yeah that happens to my friend since he has a small room
Busty St. Clair is offline   QUOTE Thanks
Old 03-16-04, 11:43 AM Thread Starter   #32
Digital_Cowboy
Digital_Cowboy's Avatar
Thanks for the advice. I did what you said and now my room stays pretty cool except when I shut the door at night.
__________________
Core I7 970 @ 3.6GHZ | Asus Rampage III Formula | 12GB Patriot DDR3 | EVGA GTX 580 SC | OCZ Revodrive X2 240GB | PCP&C Silencer 940 | Hyper 212+
Core 2 Quad Q6600 @ 3.0GHZ | Gigabyte X38-DQ6 | 8GB DDR2 | 2 x ATI 4870 1gb in Crossfire | 2 x 2tb | PCP&C 940 Silencer | Cooler Master Cosmos | hyper 212+
Digital_Cowboy is offline   QUOTE Thanks
Old 03-16-04, 11:50 AM   #33
Big_Baller
Big_Baller's Avatar
I bought a window AC unit for my room for the summers. I can't wait to plug that baby in again this summer.
I also have to keep my window open during the days with my fountain cooler because it will heat the place up pretty quick otherwise.
__________________
e7300 w/ Rosewill RCX-Z3 fan, G.SKILL PI Black 4GB 4-4-4-12, evga 9800gx2, Asus P5Q SE mobo, cooler master real power pro 650w.
Dell Inspiron 6000 running gentoo Linux.
2GHz celeron, 512MB, Media/network server running Gentoo linux
Buffalo WHR-HP-G54 running DD-WRT
Proud member of P.E.T.A: People for the Eating of Tasty Animals.
Big_Baller is offline   QUOTE Thanks
Old 03-16-04, 12:04 PM   #34
Cerberus2k7
Drifto Mexicano
Cerberus2k7's Avatar
I have a nice big 24" fan to keep me cool at night. Then again, I need it. Arizona gets hot.
__________________
Member of OCdriftingNinjas | You gotta' Fold if you wanna turn up the Heat
Overclocking: My Anti-Drug. | Overclocking my body...one day at a time... | Black Belt Ubercloxx0r | You are the most ripped yo-yo'er I have ever seen. - Seven
HTPC | i5 2500k@3.8 | Gigabyte Z68X-UD3H-B3 | 16GB HyperX | GTX 460 1gb@845/1100 | 1.5TB | Silverstone LC10S-M | Corsair 500w
Cerberus2k7 is offline   QUOTE Thanks
Old 03-16-04, 12:16 PM   #35
bluediamond
bluediamond's Avatar
If you are having a problem with heat create a flow of air similar to the flow in a computer. At work my server room has 5 Compaq Proliant Servers in a room 5" x 10" and I have an intake fan at the front of the room on the floor and an exhaust at the back of the room at the top of the wall. This has created a flow of air similar to the air flow in a computer case. The room stays around 70-74 degrees farenheit with this setup.
bluediamond is offline   QUOTE Thanks
Old 03-16-04, 03:14 PM   #36
dood
I experience the same thing. It got to the point where I knew my CPU fan (stock) was dying because it would overheat at night when my door was closed and the room heated up. Replaced the stock with a Vantec CopperX, and it overheats no more. Near impossible to get to sleep with the fan noise, though :-).
I'm running a Celeron 333, Athlon 1800+, and an Athlon 2100+...
dood is offline   QUOTE Thanks
Old 03-16-04, 06:39 PM   #37
theELVISCERATOR
theELVISCERATOR's Avatar
Quote:
LOL dude you crack me up..
Is your pillow water cooled?
__________________
Intel 2600k @4.5ghz Megahalem/Corsair SP120 Pull
Gskill Sniper 8gb DDR3-2133cas8 @ 1866
MSI P67A-GD65 BIOS 2.4
Galaxy Winforce GTX670 @1215/3404 SLI
Xfi Fatality Pro Sound
Boot /Adata SX900 256gb SSD
Storage/ 2x 640GB WDAAK Raid 0
Antec 1200/Corsair 750 TX PSU / Win7 Pro 64bit
Yamakasi 30" IPS 2560x1600
theELVISCERATOR is offline Benching Profile Heatware Profile   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
