Notices
Overclockers Forums > Hardware > Storage
Storage SSDs, HDDs, CD/DVD/Bluray
Forum Jump
saving my system
Thread Tools
Old 03-14-04, 08:17 AM Thread Starter   #1
computerbias
computerbias's Avatar
Unhappy saving my system
I have a problem, with windows 98
Have lost my OS, tried to repair and won't
I tried to upgrade to me, and after 15+ hours the programing tells me there are still drive errors and will not continue
I NEED to save the files. Am I screwed or how can I fix the drive errors without losing my files, when I cannot even get into the OS
HELP ME PLEASE !!!
computerbias is offline   QUOTE Thanks
Old 03-14-04, 08:25 AM   #2
skab
skab's Avatar
Maybe try Knoppix, runs off of the cdrom, boot to that search the disc for the files and save them to floppy's? Otherwise put a another hard drive in laod up the os and then go into the origianal and try to find the files.
__________________
STILL CRUNCHING SETI FOR THE USA
SETI, only SETI, always SETI!!!!
HEAT
skab is offline   QUOTE Thanks
Old 03-15-04, 12:31 AM   #3
G-PHoRCe
G-PHoRCe's Avatar
Quote:
I would also advise the same thing, just put another HDD with an OS already installed in it, and access your file directly from there and save them. It happened to me so many times, and that's what I did to save my files.
G-PHoRCe is offline   QUOTE Thanks
Old 03-15-04, 06:50 AM Thread Starter   #4
computerbias
I put the HDD into another pc, as slave, and most of the files were missing, that is another factor in my dilema.
Any other ideas
Old 03-15-04, 07:52 AM   #5
Xaotic
Very kind Senior
Xaotic's Avatar
10 Year Badge
Try this utility:
http://www.pcinspector.de/file_recovery/uk/welcome.htm
It's freeware and provided the HW is good and data is not completely corrupt, you should get at least some of the files back. It runs within Windows and you'll need space on another drive to copy the files into.
Xaotic is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
