Notices
Overclockers Forums > Hardware > Video Cards > General GPU
General GPU
Forum Jump
How many FPS is smooth to you?
View Poll Results: How many FPS for a game to be considered Smooth?
25-35 130 10.28%
35-45 378 29.88%
55-65 403 31.86%
65-85 222 17.55%
90+ 132 10.43%
Voters: 1265. You may not vote on this poll
Thread Tools
Old 04-13-04, 10:50 PM   #61
insecure^
insecure^'s Avatar
uhh lol I only play counter-strike and its playable for me at around 60. Its nice if its 100. But I occasionally play quake 3 and 100 is good.
insecure^ is offline   QUOTE Thanks
Old 04-14-04, 12:11 AM   #62
NO LIFE
10 Year Badge
Anything over 60 is fine for me. Even when I play bf42 in competition I dont care if the framerate is 60 or 100. All the same to me....I pwn either way .
However, after playing farcry at 1152x864 with details maxed I have learned to live with 35 FPS in action scenes. I cant really see the diff bewteen 35 or 70 FPS in farcry, but I can see the diff. bewteen high and veryhigh shadow quality, If ya know what I mean
__________________
Rampage III Extreme
Xenon W3520 (i7-920 D0) @ 3.8ghz, stocks volts
3x2gig g.skill 2000mhz sticks @ 1850mhz 8-8-8-24 1.64v
128gig OCZ Agility SSD
GTX470s in SLI
DD gpu blocks, corsair h80, EK full MB block, EK radiators, XPSC bay res/pump
NO LIFE is offline   QUOTE Thanks
Old 04-14-04, 03:15 AM   #63
makaka
makaka's Avatar
60+ is usually smooth enough for me 70+ is great
__________________
Intel 2600k @ 4.8 Ghz , DDR3 - 2133 Mhz 9-9-9 , P67 Pro from Asus , GTX 570 from Asus , 2 X Raid 0 SSD 128 GB OS and 2 x 2TB raid 1 storage , 1.2 Kw PSU. All under water
makaka is offline   QUOTE Thanks
Old 04-14-04, 10:36 AM   #64
Chowdy
Chowdy's Avatar
CS has spoiled me. in CS if i run fps_max at anything below 70it's too slow. MUST.. BE..SMOOTH... *drool*
__________________
. 3570k / 7970 / 16gb .
Chowdy is offline   QUOTE Thanks
Old 04-14-04, 10:45 AM   #65
Xplos!ve
90+, i cant stand anything below that
Xplos!ve is offline   QUOTE Thanks
Old 04-14-04, 12:05 PM   #66
deathman20
High Speed Senior
deathman20's Avatar
10 Year Badge
I play some FPS's right now and like in the 50-60 FPS range but I play mostly MMO's and run around 20-25FPS with 2 accounts running on the same computer so I'm doing good.
__________________
-=The Gamer=-
MSI Z68A-GD65 (G3) | i5 2500k @ 4.5Ghz | 1.3875V | 28C Idle / 65C Load (LinX)
8Gig G.Skill Ripjaw PC3-12800 9-9-9-24 @ 1600Mhz w/ 1.5V | TR Ultra eXtreme 120 w/ 2 Fans
Sapphire 7950 VaporX 1150/1500 w/ 1.2V/1.5V | 32C Idle / 64C Load | 2x 128Gig Crucial M4 SSD's
BitFenix Shinobi Window Case | SilverStone DA750 | Dell 2405FPW 24" Screen
-=The Server=-
Synology DS1511+ | Dual Core 1.8Ghz CPU | 30C Idle / 38C Load
3 Gig PC2-6400 | 3x Samsung F4 2TB Raid5 | 2x Samsung F4 2TB
Heat
deathman20 is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 04-14-04, 02:09 PM   #67
Panzerknacker
Disabled
Panzerknacker's Avatar
I play RTCW mostly, I don't have maximum on the framerate, it varies between 70 and 600 @ 1024 x 768. When I would max it I would use the default of 90, that's just great. But to get constant 90 I would have to lower some visual details and tweak stuff (everything is at maximum right now) but it plays fine.
Panzerknacker is offline   QUOTE Thanks
Old 04-14-04, 06:58 PM   #68
Voodoo Rufus
Powder Junkie Moderator
Voodoo Rufus's Avatar
10 Year Badge
I'll put up with 25-35 for single player, but for both single and multiplayer I like to see 60+ ideally.
__________________
"I am a leaf on the wind, watch how I soar!"
Serious Gamers Halo Custom Edition
Green Leaves!
Voodoo Rufus is offline SETI Profile Heatware Profile   QUOTE Thanks
Old 04-15-04, 01:05 AM   #69
Jo-Jo
the higher the better, so that you have less chance of 'dipping' into the sub 30's.
Jo-Jo is offline   QUOTE Thanks
Old 04-15-04, 04:33 AM   #70
24Gordon
I have no idea how anyone can tell a difference between 80FPS and 100FPS. I can't tell the difference between anything over 70FPS. I wish I had that eye for detail.
50FPS works just fine for me in FPS games. 30FPS is bare minimum for me.
24Gordon is offline   QUOTE Thanks
Old 04-16-04, 06:59 AM   #71
theELVISCERATOR
theELVISCERATOR's Avatar
its quite simple when you are wheeling quickly to turn and shoot..... you can see...feel the difference...
__________________
Intel 2600k @4.5ghz Megahalem/Corsair SP120 Pull
Gskill Sniper 8gb DDR3-2133cas8 @ 1866
MSI P67A-GD65 BIOS 2.4
Galaxy Winforce GTX670 @1215/3404 SLI
Xfi Fatality Pro Sound
Boot /Adata SX900 256gb SSD
Storage/ 2x 640GB WDAAK Raid 0
Antec 1200/Corsair 750 TX PSU / Win7 Pro 64bit
Yamakasi 30" IPS 2560x1600
theELVISCERATOR is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 04-16-04, 03:20 PM   #72
aNTiChRisT
aNTiChRisT's Avatar
Too be honest, i rate stable frames better than higher frames. I would rather have 40fps than 60-80, normally i run my games capped @ 60fps, ut2k4 goes down to 50 however, my TI4600 is starting to show its age.
~t0m
aNTiChRisT is offline   QUOTE Thanks
Old 04-16-04, 05:26 PM   #73
am8soccer
For multiplayer fps i like 60-80. Any less, and i lower my settings to get more
am8soccer is offline   QUOTE Thanks
Old 04-16-04, 08:06 PM   #74
fletch
fletch's Avatar
I like to keep my FPS 45+
fletch is offline   QUOTE Thanks
Old 04-17-04, 09:55 PM   #75
SharkDiver
Quote:
Originally posted by funnyperson1
This is false, many people can see the difference between 80 and 100 fps. There was a great article posted here somewhere about this.
25 fps is only the point at which pictures blur into motion. There is definately a sensing of faster/slower motion beyond that point.
Im one of those people,I can tell between 80 and 100 fps.I have to have 100fps or it drives me crazy and I keep my refresh rate at 150Mhz 1028/762,everything is as smooth as a babies bottom.
Shark
SharkDiver is offline   QUOTE Thanks
Old 04-17-04, 10:01 PM   #76
MetalStorm
Quote:
Shark
I think you mean 150Hz not MHz, you are out by a factor of a million there... Also, you must have one hell of a monitor and graphics card to run it at 150Hz as I didn't know monitors could do more than 100hz, let alone graphics cards support that sort of refresh speed (not in terms of frame rates obviously)
MetalStorm is offline   QUOTE Thanks
Old 04-17-04, 10:17 PM   #77
SharkDiver
Quote:
Yes I do mean Hz,Oops.My monitor is in my sig.SONY G520/P it can go to 250Hz and my card loves it.
Old 04-18-04, 09:02 PM   #78
DMAN505
I'd have to say >60 if I'm playing online, same for single player. I dont want my frames to drop in the middle of a fire fight.
DMAN505 is offline   QUOTE Thanks
Old 04-18-04, 09:45 PM   #79
SharkDiver
Quote:
With that rig your frame rate shouldnt drop in any game but FarCry with everything all the way up.
Old 04-18-04, 10:28 PM   #80
DMAN505
Your right, but with HL2 and Doom 3 around the corner I worry about it. I'll end up getting the 6800Ultra or X800XT (whichever is faster and has good IQ) to take care of that problem though.
General GPU
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
