- Jan 10, 2002
I have a Ti4200 that's a rebadged Prolink.
I got bored yesterday found a newer bios 4.25.00.37, The original is 4.25.00.34...
The new bios had the memory clocked at 400, the original is 500...
I've never been able to get good overclocks with it and the performance actually drops above 260/550...
I used X-Bios to set those speeds in the new bios...
After flashing the card gets very hot, the memory and the Caps(?), I had to use RivaTuner to turn the memory down to 530 to get rid of actifacting...
What in the bios could've caused this?!? Perhaps memory CAS?
I have'nt tried modifying the original bios yet to see what happens...
If it is a different CAS setting would the lower speeds be better?
Thanks...
Thanks...
