Notices
Overclockers Forums > Hardware > Cases and Case Modding
Forum Jump
New BIG case
Thread Tools
Old 07-06-04, 05:20 PM Thread Starter   #41
jiggamanjb
jiggamanjb's Avatar
All pictures are at the bottom
Well, I finally got a couple more things done.
After looking over the pieces that were dry I noticed that a lot of them weren't very smooth, a lot of bumps. So I wet sanded most of them, a few turned out just fine. Here is the front panel that slides up and down on the case.
I got my shipment of fans in the mail. I never have used a 120mm fan before, and I have to say, they are a lot bigger than I thought. The hole I drilled was almost perfect. It is gonna look great in the case when it is mounted.
I dremeled out some holes for some switches I am going to install on the front panel. You won't see the mess I made of the holes, thankfully.
And I finally cut out the 80mm fan grill on the top-back of the case. I went with straight lines. What do you guys think of it? I'm wondering if I should leave hole as is or the normal circular.
__________________
MAIN: Biostar H61MGC / i3 - 2120 Sandy / Team Elite 8GB DDR3 1333 / 300GB V-Raptor / OCZ ModXStream Pro 500W
SAPPHIRE AMD Radeon HD 6870 / Case: Modded CM 690 / Logitech Z-640 5.1 w/ Onboard Audio / Westy 22in Widescreen / Emprex 22" Widescreen for static viewing
HTPC/SERVER/ETC: Biostar H77MU3 / Core i3-3220T / CORSAIR Vengeance 8GB DDR3 1600 / PC Power & Cooling Silencer MK III 400W 80 PLUS Bronze
G.SKILL Phoenix Pro 60GB SSD ( OS ) + WD 20EARS 2TB 64MB Cache ( Video, Music, Pictures ) + 500GB Hitachi ( TV recordings ) / Custom Rosewill CHALLENGER
(2) AVerMedia AVerTVHD Duet - PCTV Tuner / HP Media Remote / Antennacraft Colorstar C490
Everything you need to know about Power Supplies and buying a new one ___ Heatware ___Retired Case: Modded Full Tower
jiggamanjb is offline Benching Profile Folding Profile SETI Profile Heatware Profile   QUOTE Thanks
Old 07-24-04, 11:05 PM Thread Starter   #42
jiggamanjb
jiggamanjb's Avatar
Well I finally got her finished!!!
A pic of the modding area
__________________
Old 07-25-04, 01:00 AM   #43
nova7
nova7's Avatar
I normally don't like yellow, but in this case (pun intended) it looks good.
nova7 is offline   QUOTE Thanks
Old 07-25-04, 02:08 AM   #44
Mr.Guvernment
Mr.Guvernment's Avatar
10 Year Badge
nice case - and nice work bench area - darn it ! i want one!! (the work bench area)
__________________
¸,ø¤°`°¤ø,¸© Poor Planning On Your Part Does Not Constitute An Emergency On My Part ©¸,ø¤°`°¤ø,¸
¸,ø¤°`°¤ø,¸© The trouble with life is there’s no background music ©¸,ø¤°`°¤ø,¸
¸,ø¤°`°¤ø,¸© Life isnt short, you're just dead for too long©¸,ø¤°`°¤ø,¸
Mr.Guvernment is offline   QUOTE Thanks
Old 07-25-04, 12:00 PM   #45
dribblesnort
dribblesnort's Avatar
Quote:
Originally Posted by jiggamanjb
I guess you push a button and it slides down all neat-like.
Let me know if you guys come across anything bigger. I'm just fed up with working in a small area. Bigger is better, isn't that what they say?
That thing's tiny.
Go with a CodeGen S-101
14 bays
Dual Power Supplies
4 fans on that back panel alone
I can fit my mobo, power supplies, drives, and (3) 1 gallon milk jugs in the case
THAT'S a case with room to spare
dribblesnort is offline   QUOTE Thanks
Old 07-31-04, 01:26 PM   #46
Ageeb
I sutter at the thought of your wardrobe . Nice craftsmenship btw...
-LxOxSxI
__________________
Case: Corsair Obsidian 650D
Psu: Corsair AX850
Mobo: Asus P8Z68-V Pro/Gen3
Cpu: Intel i5-2500k
Memory: G. Skill F3-12800CL9Q-16GBXM
Video: 2 - XFX 7970 FX-797A-TDFC
Display: 3 - Dell U2412M
Ageeb is offline   QUOTE Thanks
Old 08-23-04, 05:35 AM   #47
2Busy
I'm looking for the biggest case I can get for the least amount of money. Name brand doesn't matter, I'll be modding it anyway. I want to be able to get in there and climb around on the scaffolding! The best I've found so far has been http://store.yahoo.com/directron/880.html
Thanks guys
How about
2Busy is offline   QUOTE Thanks
Old 08-23-04, 06:02 PM   #48
Barrman
Nice work there. I like that lime green case on your tabel too.
By the way hom many of thos Abit NF& motherboards do you have
Im getting jelous
Barrman is offline   QUOTE Thanks
Old 08-23-04, 07:20 PM Thread Starter   #49
jiggamanjb
jiggamanjb's Avatar
Thanks! Most of those boxes are from old builds that me and my roommate built for people. I think that we have a total of 5 of them we've used. All of those boxes now are filled with old mobos that we have broke And that green case is my roommate's comp. I'll see if I can get some pics on here of it.
__________________
Old 04-17-06, 05:21 PM Thread Starter   #50
jiggamanjb
jiggamanjb's Avatar
updating outdated pic links
stock
stock
priming
fan hole
cut out fans
fan in front of hole
__________________
Old 04-17-06, 05:22 PM Thread Starter   #51
jiggamanjb
jiggamanjb's Avatar
water cooling
water cool
blue painted front plate
yellow drying outside
on/off switch plate
__________________
Old 04-17-06, 05:23 PM Thread Starter   #52
jiggamanjb
jiggamanjb's Avatar
all pcs drying
done
done
final screeny
__________________
Old 04-18-06, 10:58 AM   #53
n0aH
n0aH's Avatar
ouch about the finger!
and really what would you need 28 drives for!!
__________________
eVGA GeForce 9800gtx 512mb Superclocked
G.Skill 2 x 2gb ddr2 800 pc6400
2 x 320gb Seagate raid 0
Core 2 duo e6600
Gigabye ds3
Corsair HX 620W PSU
18X LiteOn DVD RW/Litescribe
Antec Nine Hundred Mid-ATX Case
Noctua NH-U12F High Performance Cooler
n0aH is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
