- Aug 19, 2001
- Minneapolis, MN
System:
AMD T-Bird 1.2 / 266
MSI K7T Turbo-R
1280MB PC133 SDRAM (The awesome generic Russian kind)
Geoforce2 64MB
Two 30GB 7200 IBM drives in RAID 0 mode
For cooling, the case has a 92mm intake fan in the front spinning at 2800RPM. It has some heatsink/fan combo that I got with my processor and the guy who sold it to me said it was the approved(tm) heatsink/fan for all AMD T-Bird 1200Mhz processors (hah). I bought his pitch because at the time I hadn't upgraded anything since my Intel 266 - plus I was kept out of the loop while living for several years in technology challenged 3rd-world countries. Anyways, the CPU fan spins at 4800rpm. I also have a fan that sits in one of the PCI slots. It's just below my video card and pushes air off it and out the back at 42 cfm. The front intake fan, the cpu fan, the pci fan, and the power supply's fan is all I have cooling my system amidst a mesh of cables I have yet to tie up. My room temp is a constant 20C and inside the case is usually around 25C. My CPU idles at 47C and maxes at 51C. Can anyone tell me if something is wrong with that? Is that too high and what should a typical CPU core temp be for my AMD? I wonder if my diag program is screwy. I checked the specs for the CPU on AMD's website and they say it shouldn't go over 90C. 90C is huge! I bet their temp max is just theoretical and my chip would smoke at 70C. I'm going to mod a new case here shortly but it would be cool if someone could toss me some info. Thanks.
MSI K7T Turbo-R
Geoforce2 64MB
