- Jul 24, 2004
hi all
ok i just got my new ATI silencer 1 and im going to install it later tonight.
but there is a little problem im sure some of you will encounter, i have a 9800pro 128mb and arctic-cooling made 2 different versions for the 9800 pro , "ati silencer 1" for the 9800pro 128mb and "ATI silencer 3" for the 9800pro 256mb/XT , i was sitting in the store for an hour trying to figure out if the silencer 3 will fit my 128mb 9800pro as it has the extra memsinks built in , while the "silencer 1" doesnt have ramsinks included, the store just got them today and they come in sealed pacages so they didnt whant to open them to try and fit a "silencer 3" which is made for 9800pro 256mb/9800XT on a 9800 pro 128mb card.
eventualy i didnt whant to take the risk of it not fitting so i took the "silencer 1" that for sure will fit my 9800pro 128mb and got some ramsinks for the mem.
this is an image of the "silencer 3" with the extra copper ramsinks.
did anyone manage to install the "silencer 3" on the 128mb 9800pro? it should only fit the 9800pro 128mb and the XT but maybe it will also fit the 128mb pro, i couldn't check this maybe someone else did?
cheers , ledzep.
cheers , ledzep.
