Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
sp-94 edges out xp-120.
Thread Tools
Old 07-29-04, 11:20 PM Thread Starter   #1
orion456
orion456's Avatar
Results are starting to come in:
sp-94 . . . 1st
xp-120 . . . 8th
The result appear to be based on the lack of high speed 120mm fans to test, though the xp-120's graph does seem to be flattening out after 2500 rpm. At low speeds, the xp-120 wins, but after 2500 rpm the sp-94 takes the lead.
http://www.overclockers.com/articles373/p4sum.asp
__________________
-- W3570 @ 3.8 P6TD on Swiftech H20-220
-- QX9650 P5K-E on Swiftech H20-220 water, ATI 3870, G.Skill PC 8500.
The only thing for sure, is that nothing is for sure!
orion456 is offline   QUOTE Thanks
Old 07-30-04, 07:44 AM   #2
archilochus
THE Senior FANMAN
archilochus's Avatar
The XP-120 was designed for quieter operation..We all know what that means..Less cooling to a certain point..Anyone willing to test a 120 x 38mm gutted fan for a spacer?
__________________
MOBYDICK
Intel-2.4c-HT @ 2.9 *SP-94 w/ Delta 92mm HHE w/25mm spacer *FIC-865PE-Max
OCZ 2x512 EL Gold PC 4000 @ 1:1 *2.5/4/4/7 *BFG Geforce 7800 GS OC
80g.Maxtor PATA and SATA *Xaser III. v1000D modified
FULL LOAD Temp 36°C / Syst. temp 23°C /Ambient 20°C (room temp)
F@H TEAM 32 :thup:
archilochus is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
