- May 6, 2004
- I live by a Delta
Well I decided that since I had all that empty space in the empty shell of a 120mm fan I was using as a spacer duct I would through in som LEDs to brighten it up a bit. and Really accent that big 190 CFM Delta I have pushing air over my XP-120. So here are some pics. I bought all the parts from All Electronics great site Archilochus "The fan man" recommended it to me. Anyway here are some pics.
Just got the resisitor soldered on.
Testing they work on a old AT PS I keep just for this purpose.
You can tell the UV really messes with the camera.
All epoxied together. Time to work on the wires.
Cleaned up ready for test.
Tested Good
Bench Test with the fan.
Installed with the lights on and Flash OOPS!
That is a little better sorry about the Grainy look it actually looks much better
Distance shot with the cover off. When I turn off the lights both the room and the case it looks really cool.
Tested Good
