- Oct 15, 2001
- Portland, OR. USA
Arctic Cooling VGA Silencer Revision 3
The VGA Silencer is the first VGA cooler with selectable cooling and noise level. The unique mounting clip on the silencer improves heat transfer of the GPU to the heat sink significantly while the DHES (Direct Heat Exhaust System) carries the warm exhaust air directly outward. The VGA silencer draws cool air from inside the case and exhausts warm air outwards. This prevents the fan from recycling warm air to cool the CPU, which increases cooling performance. Further, the DHES lowers the air temperature inside the case significantly. Arctic Cooling's VGA silencer operates with absolute silence and uncompromising cooling performance. After all, Arctic Cooling is the expert in noise reduction.
Regular Price: $14.99 $9.99 w/ coupon code "vga3" Expires August 22, 2004.
Link
OCZ DDR Booster Diagnostic Device w/ Powerclean Technology and Digital Led Readout
OCZ DDR Booster Diagnostic Device with Patent pending PowerClean Technology™ allows users to supply cleaner power to their memory modules, resulting in more stable memory. Additionally, users are able to view memory module voltage with the digital LEDs o*n the DDR Booster, allowing simple and inexpensive troubleshooting of the memory modules. Each OCZ DDR Booster allows VDIMM adjustments up to 3.9V* and is compatible with most DDR1 motherboards.**
Regular Price: $58.99 $49.99
Link
Thermalright SLK-948(U)
Thermalright's SLK-9XX line of CPU coolers all feature the same award-winning heatsink in different configurations. The newest addition to the lineup is the SLK-948(U) which is intended for use with the Athlon 64 and Athlon 64 FX line of CPUs and Intel Pentium IV CPUs. The SLK-9XX coolers are some of the best CPU coolers available for any application, and the SLK-948(U) will offer this performance to Athlon64 users and Intel users alike. The list of reviews below offer confirmation that the performance of this heatsink is top notch.
Regular Price: $36.99 $29.99
Link
This was all cut and paste form the add they emailed me.
Link
Link
Link
