- Dec 11, 2003
- Pike Creek, DE
I just got a new 2.4C. It's a SL6WF, made in the Philippines. It looks like it was made week 41 of 2003, but not packed out until this August.
I put it in an Abit AI7 board, along with two sticks of standard grade Crucial PC3200. Overclocking to 3000 MHz was a no brainer. I just set the divider to 5:4, and it worked perfectly.
I expected I should be able to get more out of it that that. I'm still hoping for something in the 3200 MHz range. I put the GAT settings to auto, auto, auto, disabled, disabled. I set the processor strap to 800 PSB. I tried leaving the memory timings at SPD, which gave me 2.5-3-3-7. That looked funny to me, since I thought my Crucial memory was only spec'd CAS 3. So, I tried manually setting the timings to 3-4-4-8. I've got the Vdimm set to 2.7 in the BIOS, but it shows up closer to 2.8 in Motherboard Monitor. Hyperthreading is enabled. Temperatures look decent: 22 deg C case, 24 CPU (idle), 42 CPU (load), 52 PWM (load).
I can't seem to get anything more than 3000 MHz out of it. I tried setting the clock to 255 (3.06 GHz), but I get errors in Prime95 fairly quickly. I also tried setting the clock even higher. At 267 (3.2 GHz) I get Prime95 errors almost instantly. At 275 (3.3 GHz) it will not boot into Windows.
I tried setting the divider to 3:2 to see if a slower memory clock would help. At a clock of 260 (3.12 GHz) the memory is at 173 - well under spec. It didn't help. I still get errors.
I also tried the divider at 1:1. I set the clock at 220 (2.64 GHz), and it booted and ran fine. This seems to tell me my RAM will stand at least 220 MHz, so I don't know why it's failing so soon when the divder is at 5:4.
I tried raising the CPU voltage slightly. It defaults to 1.525, but shows up in Motherboard Monitor closer to 1.54. I raised the BIOS setting one notch to 1.55, but it didn't seem to help. Besides, I thought Northwoods didn't really benefit from a lot of voltage.
Am I doing something wrong? I expected the 2.4C should do a little better than this. Did I just get a bum chip?
