Notices
Overclockers Forums > Hardware > Cooling > Water Cooling
Water Cooling Discussion devoted to blocks, pumps, radiators, reservoirs, tubing, and everything else to get you running smooth on a water loop
Forum Jump
Simple radiator positioning Q
Thread Tools
Old 10-22-04, 05:13 AM Thread Starter   #1
Don K
Simple radiator positioning question
I've been unable to find a definite answer to this, so I'll post it here:
Hooking a DD D4 pump up with a D-Tek JR120 (in that order), are there any "requirements" as to whether the radiator barbs being up or down?
"Requirements" meaning risk of cavitation, pump efficiency etc...
Edit: The pump manual specifies that the pump should be placed between point of highest static pressure (bottom of loop, i know) and the lowest point in the setup.
If I understand correctly, that means the radiator needs to have the barbs near the cabinet floor (i only have a midi case)?
Don K is offline   QUOTE Thanks
Old 10-22-04, 08:48 AM   #2
threeputt
threeputt's Avatar
No. Just make sure you bleed all the air out.
threeputt is offline   QUOTE Thanks
Old 10-22-04, 12:39 PM Thread Starter   #3
Don K
Ehrm, no what?
Old 10-22-04, 12:48 PM   #4
threeputt
threeputt's Avatar
Barbs being up or down...doesn't matter...just bleed all the air out
Old 10-22-04, 04:52 PM Thread Starter   #5
Don K
Thx!
Old 10-22-04, 07:32 PM   #6
greenman100
Disabled
greenman100's Avatar
again, radiator position doesn't matter, just rotate the radiator or case to get ALL the air out
greenman100 is offline   QUOTE Thanks
Old 10-22-04, 08:40 PM   #7
Lt_Horn
Lt_Horn's Avatar
air = evil
evil = bad
evil air = 60 bucks for a new pump
__________________
Proc:... Intel Core 2 Quad Q6600 2.4 @ 3.1
Ram:....G.SKILL 8GB (4 x 2GB) DDR2 1000 @ 1080
Mobo:
..EVGA 132-CK-NF78-A1 LGA 775 780i
HDs:
.... 2xWDBlack 2TB RAID 1, 1x320 OS
GPU:
....EVGA 570GTX HD
Case: ...LIAN LI PC-V2000Bplus II
Life has cancer folding gets rid of it!
Lt_Horn is offline   QUOTE Thanks
Old 10-22-04, 09:27 PM   #8
pwnt by pat
pwnt by pat's Avatar
water = good
working pump = good
working WC = $60 you are able to send to pat for another pump...
__________________
Intel 630
ASUS P5LD2-VM
2x256 WINTEC AMP-X
Raptor 360gb + Seagate sata 400gb
Pioneer DVR-106
Antec True350
Cheapest black USB keyboard from the Egg + Razer Viper
Some people don't deserve to have anything electronic other than a TV, and maybe a toaster, becuase they may hurt themselves and possibly someone else.
pwnt by pat is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
