Notices
Overclockers Forums > Hardware > Laptops/Netbooks/SFF/Smartphones
Laptops/Netbooks/SFF/Smartphones For all your tiny computing needs.
Forum Jump
Does Shuttle SFFs offer good sound?
Thread Tools
Old 01-02-05, 10:33 AM Thread Starter   #1
iopf
I just built myself a SFF system, the biostar ideq 200. It works great, quiet, fast,etc. However, the analog sound is horrible. When something is not playing, or on low volume, you can hear a hissing whine coming through the speakers. Im pretty sure that the hiss is caused by interference from the other components. I use headphones alot so this is really annoying.
Is this something that happens frequently with SFF systems? I've been thinking about upgrading to a new system to a Shuttle SB81P.
Does anybody with a shuttle experience the same hissing problem I have?
Or does anybody know how to remedy the interference?
p.s. (Yes I have tried adjusting volume controls, audio properties, and drivers).
Thanks in advance!
iopf is offline   QUOTE Thanks
Old 01-04-05, 09:09 AM   #2
Yuriman
Yuriman's Avatar
It really depends on what speakers you are using, and how sensative you areto these things. When I moved to a shuttle nforce3 from my nforce2, I could hear a difference between it and soundstorm, but I dont think there was any more hissing. If you are that worried about it, get an external audigy or a nice internet card.
Yuriman is offline   QUOTE Thanks
Old 01-05-05, 02:32 AM   #3
UnseenMenace
UnseenModerator
UnseenMenace's Avatar
10 Year Badge
The Biostar iDEQ 200T runs a CMedia 5.1 audio system, which although perhaps not the best sounding from my experience its pretty reasonable. I have however experienced driver problems with the CMedia before.
What configuration do you have for your speakers?, are The 3 audio jacks configured to drive a 6-speaker audio system ?
Have you tried listening to the sound on headphones, to ensure that the problem is not the speakers ?
Have you tried up dating your sound card drivers ?
__________________
one M15x is never enough
UnseenMenace is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
