Notices
Overclockers Forums > Overclockers.com Teams > Competitive Benchmarking Team > Volt Modding & Circuitry
Volt Modding & Circuitry Calling Dr. Frankenstein! When too much is barely enough...
Forum Jump
Guide to the 7v Fan Mod
Thread Tools
Old 11-01-06, 01:30 PM   #61
doom0
i have one inside my case as an intake @12v. and its near silent.
i want to see it perform @24v tho.
doom0 is offline   QUOTE Thanks
Old 05-07-07, 03:26 PM   #62
Vento1
Vento1's Avatar
Just performed the 7v mod on a tornado fan what a difference i can still here the fan but it does'nt hurt my ears now.
__________________
OVERCLOCKERS.COM THE ONLY TEAM TO CRUNCH SETI FOR
Main rig
CPU QX9770 @ 4.0
MotherboardFoxconn Blackops
Memory 2gig Diablo
HD 450gig Raid 10
Graphics EVGA 9800 GX2
Cooling
Water
Benching rig
Anything i havent broken yet.
Vento1 is offline   QUOTE Thanks
Old 05-27-07, 11:54 PM   #63
Zoris
Zoris's Avatar
I just did this and it worked!
I guess this is my first real mod. lol.
Zoris is offline   QUOTE Thanks
Old 06-16-07, 08:29 AM   #64
Oc1Kenube
Oc1Kenube's Avatar
Just used this on a delta screamer 80mm fan that was ear pericingly loud,it is still audible now but bearable.
Many thanks
__________________
Coolermaster ATCS,Intel i7 920 - currently @ 3.5ghz
Gigabyte X58A UD5
6gb ocz gold 1333mhz ram
Ati XFX 4870 XXX 512mb
3 Samsung f3 500gb hard disks in raid 0
EKS supreme water block,1/2" tubing and barbs,xspc 360mm radiator,swiftech mcp655 vario pumpxspc single bay reservoir
3 x yate loon 120mm fans
Oc1Kenube is offline   QUOTE Thanks
Old 06-16-07, 10:20 AM   #65
jimmsch
I have these pics of the different voltage wirings printed and tacked to the wall in my garage where I do all my PC building/testing/money wasting stuff. Great guide!!
__________________
Main Rig - i5 2500K 42x (turbo)...2x2gb Corsair DDR3-1600...Asus P8Z68-M Pro...Corsair HX620...Hanns-G 19" LCD...1 x 80GB Intel SSD...2 x 1TB Samsung HDD...Zalman CNPS9700...Ultra Aluminus (black)...Win 7 Ult x86
HTPC - AMD A6 3650 under volted...2x2gb Crucial DDR3 1600...Gigabyte GA A75M D2H...Seasonic 300W PSU...Samsung 64GB SSD...Silverstone MLO3B HTPC Case...LG 55" 6700 series 3D LED LCD...Onkyo HT Receiver...Onkyo 5.1 speakers and sub...Win 7 Ult x86
jimmsch is offline   QUOTE Thanks
Old 06-16-07, 02:40 PM   #66
Oc1Kenube
Oc1Kenube's Avatar
Quote:
Could you post me a 5v mod please delta is still a tad too loud
__________________
Gigabyte X58A UD5
Old 06-17-07, 09:28 PM   #67
nd4spdbh2
nd4spdbh2's Avatar
Quote:
its very simple... take the 5v (red) line off the psu and put it to the + on the fan, then the - on the fan to a black or ground on the psu.
__________________
#12 in the 4ghz core 2 duo club baby! - 52 inches of CRYSIS! - Black Belt Ubercloxx0r -- Heatware
Main -- Lian Li V2000b -- i7 2700k -- MSI Z68A-GD80 -- 12gb 1600 -- GTX560Ti --Adata 128gb S510 & 2x500gb -- Seasonic S12 600w -- Dell 2209WA
HTPC -- Silverstone GD05B -- E7200 @ 3.2ghz -- G41-M7 -- 4GB 800mhz -- g210 passive -- 320gb 2.5in WD -- Antec EA 430w -- 52inch Samsung LCD
Server -- Antec NSK4480B -- E3300 @ 2.5ghz -- ECS G33T-M2 -- 3gb 667mhz -- Onboard Vid -- 500Gb + 1TB hatachi + 1tb WD -- Zalman 400w
Netbook - Dell Mini 9 - Atom 1.6ghz - 8GB ssd - 2GB pc6400 - WIN 7 PRO!
Need 4 Speed - BH
nd4spdbh2 is offline   QUOTE Thanks
Old 06-18-07, 08:08 AM   #68
Oc1Kenube
Oc1Kenube's Avatar
Quote:
Confused. im using a pass through molex to molex mod like shown in the picture on page 1
__________________
Gigabyte X58A UD5
Old 12-26-07, 06:55 AM   #69
SkuToV
SkuToV's Avatar
What I did to mod the voltage on my 120mm fan on my case was I cut the plug so it fitted onto the molex the other way round so it's now running off 5v. works just as well as whats described above but its a helluvalot simpler
__________________
"Immortality notwithstanding, I'm not going to live forever, you know." - o
"...how could I not have problems?" - rainless
"they sell games in stores? " - lordkosc
SkuToV is offline   QUOTE Thanks
Old 02-12-08, 04:25 AM   #70
bardos
bardos's Avatar
question: i'm using a 120mm fan that at 12v is rated at 69 cfm and 36dba. I've tested it at 7volts and it is of course noticeably slower and quieter. is there some formula to let me know what cfm i could expect at this voltage (and dba)?
__________________
Motherboard: gigabyte p35 d3sl
CPU: q6600
RAM: 4gb OCZ reaper
Graphic Card: radeon 6750
HDs: Intel 330 60gb ssd, 1tb samsung 103SJ, 500gb wd,
bardos is offline   QUOTE Thanks
Old 06-30-08, 11:59 AM   #71
markp1989
I have a PicoPSU-120, running my fan at 5v, would it be smart with that PSU to run the fan at 7v, or could that cause problems?
Thanks Markp1989
I just ordered these
http://cgi.ebay.co.uk/4-Molex-Power-...d=p3286.c0.m14
so i can connect the fans to the 5v without damaging the metal pins like i did with the one i have now
markp1989 is offline   QUOTE Thanks
Old 11-22-09, 04:10 PM   #72
Foolios
How is it that you can have one wire going to +12v and one wire to +5V and get 7v? Why do these take away instead of adding up?
And how is it that when you switch the black ground wire away from the ground and into the 5v that this works at all now that the ground is no longer there?
It would seem to me that the two voltages would buck and burn things out if this was to work at all. This is DC so I would think that since everything is going one way that it wouldnt work.
What gives?
Foolios is offline   QUOTE Thanks
Old 11-22-09, 05:49 PM   #73
eobard
Give me a break Senior
10 Year Badge
What gives?
It's not going one way. The 12v is pushing in one "direction" if you will, and the 5v is pushing in the opposite direction. So the first 5v of the 12v line are canceled out leaving only 7v remaining. Now that is in no way what I would consider an accurate technical explanation, but it does make the point in an easy to understand manner.
__________________
Thank you Baby. I love you.
eobard is offline Author Profile   QUOTE Thanks
Old 11-22-09, 06:02 PM   #74
Foolios
Thank you for trying to explain it.
But where is the ground? I don't understand how this completes the circuit without a ground.
I am wondering how it is possible to use a wire to output voltage and current and yet still perform the job of a return.
Very interesting stuff!
Old 11-22-09, 06:29 PM   #75
MattNo5ss
b4n4n4 dr4g0n d00m3d m0d3r4t0r
Overclockers.com Editor
MattNo5ss's Avatar
The 5v wire is the "ground" with the left over 7v running through it to complete the circuit.
I used the 3.3v wire as a "ground" to mod my Panaflo to run at 8.7v (12v-3.3v=8.7v).
__________________
i7 3770K | ASUS Maximus V Gene | 4x2GB Dominator GT DDR3-1600 6-6-6-20 | EVGA GTX780 SC ACX | 256GB OCZ Vertex 4 | SeaSonic X750
E8700/E6750/P4 631 | Rampage Extreme & EP45T-Extreme & Commando | DDR2 D9 or any DDR3 | 1 of 20ish GPUs | 50GB OCZ Vertex 2 | SeaSonic SS-1000XP
O/C Author Profile | HWBot Profile | Heatware (92-0-0)
\m/ OverClockers mATX L33T Club \m/
Projects: Copper-Framed, MDF Station | PVC-Framed, MDF Station | Custom Cascade Cart/Case | Untitled TJ07 Build
MattNo5ss is online now Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 11-22-09, 09:00 PM   #76
noxqzs
noxqzs's Avatar
When you think of voltage, you must think in terms of difference in potential energy. Voltage is a difference between two points. A simple example could be a ball at the top of a hill. The higher up on the hill, the bigger its potential energy. If you took 4 3v LEDs and wired them in series powered by a 12v source. The measured voltage between each led would be 3v.
__________________
___________________________________________
I7 980x, R3E, HX1000, Corsair 6x2GB, Areca 1880i, Corsair GT240, 4xF120, 680GTX, 3007fpw-HC
noxqzs is offline Heatware Profile   QUOTE Thanks
Old 11-24-09, 08:53 PM   #77
Foolios
Saying that there is difference in potential makes sense in a way to me. There are two wires to complete a circuit.
But the part I can not get around is that this method does not appear to include a positive and negative side.
I can almost imagine this working with a/c because I know that current can travel in two directions with a/c. But in a/c I don't believe this would be the case as if one were to do this with a/c, I believe the two voltages would buck.
But in d/c don't we need the difference to be between a positive and negative, the negative supplying the electrons(current) to the positive side?
I am imagining a circuit that is being created with this mod having two positive sides and no negative.
Ooooohhhh, wait a minute.. You are saying that because one side is lower in voltage than the other that it will give up electrons to a higher voltage source? So, a positive with only 5v will now act as a negative and give up electrons to the side with 12v? The 12v has a stronger attraction and wins over?
Whoaaaa!!!!!!!!
Old 12-08-09, 07:02 PM   #78
Foolios
EDIT:
Works with 3 fans at 7v on the same cable.
What about cables that have other devices like hdd's on them, can this mod be used on those just at the point of the fan connection or will it cause power problems along the rest of the cable?
Old 12-08-09, 08:21 PM   #79
Foolios
Quote:
Originally Posted by Skeith View Post
this is an easy way to do it yes, but if somone has a bit of knowledge in electronics you can easily set up a NE555 timer as a PWM modulator with a transistor and controll your fan speeds very acurately. If anyone is interested let me know and ill post the information. PWM (pulse width modulation) is very acurate and can run a fans speed slower than a voltage modification, because the PWM controller runs the fan at its desired voltage the fan will start at very low speeds.
I would love to see this.
Old 02-05-10, 02:20 AM   #80
Rockfellah
Nice guide, trying now.
Rockfellah is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
