Welcome to the Overclockers Forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact us. |
Thread Tools |
#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Senior Member Join Date: Feb 2001
Guide Installing the HDTV Wonder! okay this is a tough sob!
XP PRO GUIDE INSTALL Before PCI CARD * Windows XP Service Pack 2 * Microsoft DirectX 9.0c * Windows Media Encoder 9.0 * Net 1.1 or greater Download these and install in order DAO / MDAC HDTV WONDER Drivers DTV Decoder* must have the cd intray to install inorder to validate. Multimedia Center Catalyst Control Center Wonder Remote Plus update Then you need to read ATI Advanced Tech doc 737-216 in advanced search on their website. HERE IS THE QUOTE FROM ATI Unable to start TV: The TV Player failed to initialize the video. It has been noted that in systems with this symptom the DTV Player will launch successfully. Not all systems are affected. To workaround this issue you will need to add an additional line to the Environment Variables section of the Windows System Properties. 1. Open Windows Control Panel, and double-click the System icon 2. Select the Advanced tab, then click Environment Variables button 3. Under System variables section scroll to the variable called Path 4. Highlight Path, then click Edit 5. At the end of the Variable value line add the following text exactly as it appears: ;%SystemRoot%\system32\drivers 6. Click OK 3 times and then restart Windows 7. Run TV Player This caused me tons of headaches and I'll try and see if a exe can be made that fixes this in the registry. I am now happy with my HDTV Wonder with remote.
__________________
42 | SigAssassin ADVANCED SEARCH | Google | SOFTWARE DVD PLAYERS | MEMORY REPS/Forums | MEMORY CHIPS LIST |
| Thread Tools | |
