Notices
Overclockers Forums > Hardware > Video Cards > nVidia GPUs
nVidia GPUs
Forum Jump
Why wont the svideo work? i wanna hook up my tv
Thread Tools
Old 08-10-05, 04:32 PM Thread Starter   #21
Bboy_Jon
Bboy_Jon's Avatar
i tried wdm drivers, one of them (in deevice manager) said that the device failed to operate
__________________
Current PC
[AMD Athlon XP 3000+ Barton@2.3ghz][Abit NF7-S V2][1GB PC3200 Mushkin RAM@432mhz][Saphire ATI Radeon 9800 Pro->XT@432/375.55][80GB 7200RPM Maxtor HDD][60GB 7200RPM Maxtor HDD][Thermalright SP-97 Heatsink w/AS5 and 90mm Enermax Fan][Raidmax Scorpio 868][Crappy raidmax 420w PSU]
[30ºC Idle/40ºC Load]
!Now Folding@Home for Team 32!
Bboy_Jon is offline   QUOTE Thanks
Old 08-11-05, 04:24 PM   #22
DaWiper
Image Compare Man
DaWiper's Avatar
Can you provide a picture of everything involved, backplate of your xfx-card, cable, adapters and input on tv?
DaWiper is offline   QUOTE Thanks
Old 08-11-05, 04:58 PM Thread Starter   #23
Bboy_Jon
Bboy_Jon's Avatar
ehh well i cant take pics, so ill find some on the net
http://www.newegg.com/Product/Produc...82E16814102362
in the pic with the included stuff, the little yellow thing is my adapter (7 pin svideo to composite) im also using that cable to connect between the two
heres my video card
http://www.newegg.com/Product/Produc...82E16814150089
and ive tried to connect to the tv, directly and through a switch box/av selector (both tv and box are composite)
http://www.comparestoreprices.co.uk/...lector-ps2.jpg
__________________
Current PC
Old 08-11-05, 05:50 PM   #24
DaWiper
Image Compare Man
DaWiper's Avatar
Ok, I think I know what the problem is.
First of all there is no such thing as a 7pin svideo cable/or connector. svideo is only 4 pin.
http://www.proav.de/index.html?http&...o/s-video.html
However, many cards has a more-than-4-pin configuration which are the same size. There is AFAIK no pin standard for which signal should go where. Which in your case is the problem. I think the sapphire adapter is not pinned the same way as your xfx card.
Does your tv has one or more scart connectors? If the tv is not too old it might be possible that your tv can handle a svideo signal thru scart.
Old 08-11-05, 06:11 PM Thread Starter   #25
Bboy_Jon
Bboy_Jon's Avatar
what is scart?
ya i dunno what the multiple pin thing is (its called svideo out on newegg though) but ya that could be
because the thing is like 6 pins, and then where theres a row of i think 4 on the card, theres 3 (since its not needed, but ya maybe its different on the 6600gt)
__________________
Current PC
Old 08-18-05, 03:21 PM Thread Starter   #26
Bboy_Jon
Bboy_Jon's Avatar
GOD DAMMIT WTF, JUST WEHN I THINK my card can get any worse!!!!!!
i get a new cable (free from someone off another forum) the one with RGB, and the svideo has 7 pins, and the big black thing
turns out my video card has 10 holes, and theres no hole for the big black thing (the big black thing acts as 2 pins) other cards have 7 holes and one for the big black thing, but noooooooo not XFX WTF
__________________
Current PC
Old 08-18-05, 03:43 PM   #27
Lat
Lat's Avatar
i don't think that's an svideo connection. i had one of those on my ti4200, and i needed a separate converter that split that into composite in and out and svideo in and out...
__________________
There are only 10 types of people in the world...those who understand binary and those who don't
Lat is offline   QUOTE Thanks
Old 08-18-05, 03:47 PM   #28
[SaS]hornet
i use a scart DECENT PIC to 3 phono and s-video. the connections in the US are different to the uk. worked fine on my 5900xt. in the driver screen i had a duel screen option (Nview i think) that would allow me to have clone or duel screens with my tv. i have nothing like this with my 6800gt.
[SaS]hornet is offline   QUOTE Thanks
Old 08-19-05, 01:44 PM   #29
DaWiper
Image Compare Man
DaWiper's Avatar
Quote:
Huh? All the card's I've tested from the gf4 mx400 and up could do that. Doesn't your 6800gt have a tv out?
Old 08-31-05, 07:03 PM   #30
[SaS]hornet
yep, it has a tv out. it is a 4pin s-video conection, and my tv has a 4pin s-video connection, but it still wont work, ive tried the force connect thing aswell. no joy.
Old 08-31-05, 07:14 PM Thread Starter   #31
Bboy_Jon
Bboy_Jon's Avatar
thats wierd, it should work for u
i ddont have a svideo on my tv
__________________
Current PC
nVidia GPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
