Notices
Overclockers Forums > Hardware > Motherboards > AMD Motherboards
AMD Motherboards
Forum Jump
A8N-SLI Deluxe northbrige fan not working
Thread Tools
Old 08-10-05, 01:10 PM Thread Starter   #1
mezzz
how do i take it off to put a new one on?
mezzz is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 08-10-05, 01:26 PM   #2
Son1990
Son1990's Avatar
Bend plastic studs/pins in back (the ones with springs) so they slide through the holes. Bada-Bing-Bada-Boom.
~Ken
*Edit spelling
__________________
I am the Omega of the Delta ... Fan Users :burn:
Son1990 is offline   QUOTE Thanks
Old 08-10-05, 01:26 PM   #3
eaglescouter
Frustrating Senior SETI Nut!
eaglescouter's Avatar
10 Year Badge
From the rear of the board, find the two plastic pins that hold on the sink. Squeeze the prongs of one pin together and pop it thru the board, repeat for second pin.
I found I could perform this task with fingernails (required effort), if you use tools be very careful not to scratch the mobo as you could break a trace and kill the board.
If you find a plasticlike shield on the bottom of the sink, pull it off and use it between the chipset and your new sink.
(Note: And you might want to prune down your signature, I believe you are over the limits. Mine got pruned to its current size by the helpful moderators.)
__________________
Mining LTC
#4 in the 20 Million SETI Club
Top 4 Producer for BOINC Seti Many GHz of Seti Crunching Power!
Number 18 Seti Classic Cruncher
Member of the Phase Cooled 6Ghz Club
[SG] Halo Custom Edition Clan Leader
eaglescouter is offline SETI Profile   QUOTE Thanks
Old 08-10-05, 01:42 PM Thread Starter   #4
mezzz
yea it is not coming out i pushed the one pin in and the the otherone on the other side and it is not coming
Old 08-10-05, 09:12 PM   #5
swindelljd
I just took a pair of pliers and bent the plastic pins (from the underside of the board) back and forth until they broke. Then I popped the fan off and cleaned the NB with some rubbing alcohol, let it dry and installed the replacement. It took a bit of force and watch out for all the pins on the bottom as I scratched my hand to the point it was bleeding. No pain, no gain, right?
Unfortunately the new chipset fan doesn't respond to SpeedFan or Q-fan so I have just bought a Zalman NB47J. Though I am going to wait until I get my X2 to minimize the times I have to take the mobo out of the case.
FYI, your sig is completely unreadable to a color blind person
John
swindelljd is offline   QUOTE Thanks
Old 08-11-05, 01:36 PM   #6
Chief_Drunk
I removed my chipset fan without taking the mobo out the case. Just got hold of the top of the plastic pins and pulled with a pain of pliers. Bit of force and they just broke in 1/2.
Chief_Drunk is offline   QUOTE Thanks
AMD Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
