Notices
Overclockers Forums > Hardware > CPUs > AMD CPUs
AMD CPUs
Forum Jump
My Tip for: If you really must remove your IHS
Thread Tools
Old 08-20-05, 05:02 PM   #21
willkill1337
willkill1337's Avatar
Well for some people it may not only be a 3-5 degrees drop in temps. If your core isn't making good contact with the IHS then removing the IHS can drop temps dramatically.
willkill1337 is offline   QUOTE Thanks
Old 08-20-05, 07:05 PM Thread Starter   #22
JasonBr
Disabled
JasonBr's Avatar
Sticky worthy?
Ill clean up the text and description if so.
JasonBr is offline   QUOTE Thanks
Old 08-20-05, 08:18 PM   #23
Quest For Speed
Great tip. safer using plastic than the blade. I found also that freezing the cpu for 15 minutes does make it easier for the blade to penetrate the corners.
I have a venice 3200 and a X2 3800 and for the venice my temps improved by 2C but on the dual core my load temps went from 52C down to 38C.
__________________
Rig 1:Asus P5B Deluxe E6600 Core 2 3.6Ghz@400 fsb
2 gig Gskill DDR2-1000@1200(2:3)5-5-4-5
WATER COOLED:White Water & Swifty MCW50 block
2x74Gig Raptors RAID 1 ATI X850XT PE 660/650
Pro Power & Cooling 510
Quest For Speed is offline   QUOTE Thanks
Old 08-20-05, 08:52 PM   #24
njkid32
njkid32's Avatar
Quote:
Originally Posted by JasonBr
Sticky worthy?
JasonBr, I think if you write a detailed howto then it would be worthy of a sticky. There are several howto's out there at different sites. But I think you mabe onto something here. I also think that if you were to write a howto you should give different options on how to remove it. Some use the freezer method, razor, dental floss, and some have even tried different chemicals to break the glue down. So maybe do a little research about this and post different methods from all the different sites. Make a one stop shopping list what a killer of a skicky that would be. I would do it myself but I am way to lazy! LOL Here are some links if you dont already have them----
http://forums.extremeoverclocking.co...d.php?t=177873
http://forums.extremeoverclocking.co...d.php?t=178897
http://www.ocforums.com/showthread.php?t=401748
http://www.xtremesystems.org/forums/...ad.php?t=59068
http://www.dfi-street.com/forum/showthread.php?t=17992
njkid32 is offline   QUOTE Thanks
Old 08-20-05, 09:02 PM   #25
xAndrA
xAndrA's Avatar
Yeah, removing the IHS safely is one thing I'd be iffy on... The overclocking doesn't stand nearly as much chance of ruining a CPU as this one. I was planning on getting some dead CPUs from a store for cheap to practice on, but with a detailed HOWTO, I may not need it =)
xAndrA is offline   QUOTE Thanks
Old 08-20-05, 09:07 PM   #26
JoT
You can't fire me, I have tenure!
MODERATOR
JoT's Avatar
10 Year Badge
This man is on to something.
__________________
"There it is, ladies and gentlemen: the most expensive car in the world, dressed up like a mouse."
Why yes, I do have Heat!
Welcome to the forums. Please read all of the forum rules. Thank you =) --- What mods are active that I can PM my concerns to?
JoT is offline Heatware Profile   QUOTE Thanks
Old 08-20-05, 09:20 PM   #27
CCUABIDExORxDIE
CCUABIDExORxDIE's Avatar
agreed jot. ive always been wanting to de-ihs my chip, but im really scared. my 6600gt was killed by a crazed me and maze4, and my 6200 died outta the blue and on all of days, day 16, and newegg only warentees refurbs for 15 days. i could see myself killing my 2800+, and being SOL.
CCUABIDExORxDIE is offline   QUOTE Thanks
Old 08-20-05, 11:45 PM   #28
jcw122
jcw122's Avatar
Excellent idea there, I've always thought it risky to use a razor...sharp stuff + delicate stuff u shouldn't be cutting= no no! and mabe UH OH!
LMAO
__________________
"YES! I AM INVINCIBLE!!!"
Folding for Team 32!
Gaming Nick: new_Faction64 or CharminULTRA
CPU-AMD Athlon 64 3000+ 2.0Ghz@2.2Ghz (was 2.4) Socket 754, VENICE
Memory-Crucial Ballistix 2x512MB @ 220mhz 2.5-2-2-5
Motherboard-No Idea My DFI Died
Video Card-MSI ATI 9800XT---412/390(was 424/395)---w00t! Flashed
PSU-Forton Blue Storm 500w
Currently Air Cooled w/ Scythe Ninja and AC VGA Silencer
R.I.P. Project: Humidity
Heatware
jcw122 is offline   QUOTE Thanks
Old 08-21-05, 12:01 PM   #29
Valk
Valk's Avatar
hey man. i wasnt able to get this to work for me unfortunatly <_<. i had this game gube memory card case i butchered for it and all, and it wasnt really able to do much other than shave off the crap little by little. was much better using the razor blade throughout.
he he. its sad though. i wanna get another a64 so i can try this out again. its a great idea.
__________________
Fumika - HP2710p, My personal Tablet PC slave
Intel C2D U7600@1.2ghz - 4GB Kingston HyperX pc5300 - Runcore Pro IV 32gb 1.8" ZIF SSD - 12" LED backlit with Wacom Digitizer - HP Slice Battery +6 hours - 3.1-4 lbs - Windows 7 Home Premium
Other Stuff
Heat - Watercooled Lian Li PC-V600 - HIME, Watercooled SFF -
Valk is offline   QUOTE Thanks
Old 08-21-05, 12:37 PM Thread Starter   #30
JasonBr
Disabled
JasonBr's Avatar
I was looking around for the plastic i used, but i must of thrown it out.
Best way to explain it, you know when you buy something and its in that clear plastic. (Kids toys, cheap electronics.) its its sealed shut and you have to cut the edged off to open it.
Its a very hard plastic , yet flexible. Literally it cut the seal almost as good as the razor. I could see it it was a softer plastic it might not be able to keep a sharp edge as you push through.
I cut it into a tear drop shape and used the edge.
If i can find it , ill take a picture. Hopefully Im a bit more clear than before.
Edit: Hey atleast we used the same razor
Old 08-21-05, 01:44 PM   #31
Valk
Valk's Avatar
Ha, my temps went up. now i get to solve the problem of retention <_< my 90 is kinda retarded. they got those screws in there in a really annoying way so its like impossible *without mutilating them horribly* to unscrew them. would be a simple measure of adding a washer or two to compensate for the no heat spreader.
ah well. right angle screw driver, here i come.
__________________
Other Stuff
AMD CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
