Thread Tools |
#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Mar 2004
If you have Antec P180/182 and Watercool can you post Pictures
Moved from P180 to 182. Lost P180 watercoold pictures. New Setup Hardware Case: Antec P182 Motherboard: Asus p5q dlx CPU: e8400 Memory: 4gb corsair pc8500 Gfx: 8800gt Power Supply: Corsair 520w Optical DriveSamsung dvd burner Cooling: CPU Block: Swiftech Apogee GT with 2 DD 1/2id barbs GPU Block: Swiftech MCW60 with 2 DD 1/2id barbs Pump: Swiftech MCP350(blue propeller) with modded Alphacool top and 2 ek 1/2 id barbs Tubing: Durelene 7/16 id tubing Radiator: Thermochill PA120.3 ![]() I also got one more picture of previous setup with antec p182 - Something wacky, dual triple radiator, not the brightest thing ever ![]() Last edited by meionm; 07-28-08 at 01:06 AM. |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Dec 2004
replace that reservoir for T-Line then you can have your Sunbeam installed and NO MORE FOUNTAIN |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: May 2005
I am going to be doing this soon, so if anyone, including yourself can post some pics I really need some ideas. I am not afraid to do a little bit of cutting, although I would prefer to keep everything inside of the case.
__________________
Gigabyte EX58a-UD3R F5 BIOS :Intel i7 920 @ 4.15ghz w/ Venomous-X Still Testing : 6GB 3x2 G.Skill PC12800 ATI HD4870x2 : HITACHI Deskstar T7K250 + 180GB & 500GB Western Digital Caviar SE Rocketfish + PCP&C 750W : Dell 2407FPW My Heatware Blackbelt Ubercloxx0r |
#4 | |
Quote:
#5 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Jan 2003
i think the part pf bleeding with the T line is cycling the pump on and off so it just barely gets moving. you could also kink a tube by squeezing it to cut flow while bleeding. then there'd be less weight and an open bay and the water wouldnt have that go stop go stuff goin from a res.
__________________
Student of Electronic Engineering as of September 20, 2010 |
#6 |
ahh the messy-ness inside of your case kinda scares me. but most importantly I now know that it is possible. I think I am going to try to put my pump in the bottom where the bottom hard drive cage goes.
__________________
#7 |
![]() ![]() Registered Join Date: Aug 2005
This is my first attempt at WaterCooling. Bought a P180 and cut the crap out of it. But, with some adjustment it all fits inside the case! (Need more color/lights though omg) Anyway, here it is! Just finished it like 30 minutes ago! ![]() ![]() |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Jun 2002
Nice, Krazed. Perhaps you could mount your hard drive in the 5.25" section to improve airlflow on the lower part of the radiator. Do you have any pics of the radiator's fans?
__________________
Desktop: Intel C2D E6700 @ 2.67Ghz / TR AXP-140 | Asus P5W DH Dlx | Corsair TwinX 4Gb PC6400 CL4 Nvidia 8800 GTS 640Mb / TR HR-03 | Creative X-Fi 2x WD Raptor 150Gb | Plextor PX-760SA Lian Li V2000 Plus | Corsair HX620 Dell 2407WFP | Logitech Z-5500 Laptop: Sony VAIO Z11 Intel i5-520M | 4Gb | Nvidia GT330M | 2x64Gb RAID-0 SSD | 13" 1600x900 panel |
#9 |
looks pretty good krazed.
__________________
#10 |
Is that all? Little update here on my setup, I just installed swiftech MCR 220 radiator and vga cooler with cutting about two pieces of metal inch by inch. I will post some pictures once I recharge batteries. |
#11 |
nice, i can't wait to see it!
__________________
#12 |
Pics Added |
#13 |
![]() Registered Join Date: Nov 2005
heres mine [img=http://img83.imageshack.us/img83/4892/100025927xh.th.jpg] thinking of redoing the tubing to 3/8 tho |
#14 | |
Quote:
Here's my latest addition to antec p180 waiting for intel setup to arrive. |
#15 |
![]() ![]() ![]() Member Join Date: Jan 2006
You're going to need some outriggers for that! ![]() |
#16 | |
![]() ![]() ![]() ![]() ![]() Member Join Date: Dec 2005
Quote:
#17 | |
Quote:
#18 |
New Member Join Date: Dec 2005
Here's mine, hung the rad off the back for simplicity. -pickles ![]() |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004
was wondering, meionm, on the pics you posted in your first post, what connects the fan to the case on the back? is that some kind of shoud?
__________________
< FOLD! < Heatware < EVGA X58, 920, TRUE, 12GB Corsair, 2 x EVGA GTX 285, Enermax Revolution, Velociraptor, 7 64-bit |
#20 | |
Quote:
Yes it was shroud holding radiator. |
#21 | |
![]() ![]() ![]() ![]() Member Join Date: Jun 2005
Quote:
OMDG... that looks extremely complicated. God how much does it weigh?? Looks like it does its job great though. |
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Jul 2002
lol that must have mad flow rate - you need to use some proper steel hose clips IMO! Nice setup though! I dont really like the P180 design for watercooling as its difficult to keep everything neat - I have the same rad as you but on the top of my case which is a Casetek 1019A |
#23 |
![]() ![]() ![]() Member Join Date: Apr 2006
That last one is nuts with the 2 pumps and huge rad. HD cooler also? |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Oct 2005
Quote:
it looks to me like it is using steel worm drive clamps. What kind of clamps are you talking about?
__________________
[Q9550 - Lapped - 4012Mhz @1.38v | Thermalright Venemous X - Shrouded San Ace 120x38mm] [Abit IX-38 Quad GT @ 471 Mhz FSB | 4x2GB Gskill DDR2-1066 @ 942Mhz | Sapphire HD4890 OC] [Kingston SNM225S2 80GB SSD | Samsung 1TB F1 | Sony DVD RW | PCP&C Silencer 750W Quad] [Tagan A + Seenium Case | Saitek Eclipse II | Logitech G9 | Logitech z5300 | Sunbeam Rheobus] [--------------HEATWARE: jivetrky --------------|-------------- GAMING NICK: jivetrky--------------] "With every upgrade I become less clever." -Socket eh?¯\(º_o)/¯ |
#25 |
![]() Registered Join Date: Mar 2006
My P180 Setup
Very difficult to finally get installed and bleed. The only thing I have changed is that use Delta 3 bladed fans to pull air through. They work far better than other fans with high pressure. I would of liked to mount the BIE2 radiator on the top of the case but I need the room for 2 LG DVD burners and my 150g raptor. The bottom was out of the question due to a four disk 3ware array cluster. Any ideas on improving the setup will be welcome. I love this forum! ![]() |
#26 | |
![]() ![]() ![]() Banned Join Date: Apr 2006
Quote:
#27 | |
Quote:
Looks like a Swiftech Storm to me
__________________
#28 | |
Quote:
#29 | |
Quote:
haha....whoops ![]() ummmm....yeah he's got a storm on his video card ![]()
__________________
#30 |
![]() ![]() ![]() ![]() Member Join Date: Apr 2006
| Thread Tools | |
