Hello. I just got my 1 gig ddr stick in today and i've installed it. works just perfect. I've read where the 5/4 ratio isn't the best way to overclock, however i changed the clock speed of the ram in the bios to 200 Mhz and my CPU frequency to 250 and multiplier to 10x. this successfully puts me at 2.5 Ghz and things seem to be quite stable so far. I'm wondering if it would be better to overclock this memory so i can get the memory and cpu speed the same and increase the multiplier to 11. i don't have knowledge of this type of memory and i'm wondering what would be a safe setting to overclock the memory to. my voltage is 2.6 volts on the memory right now and 1.35v on the cpu. My motherboard is an Asus A8N-SLI Delux and i have the Toledo Core and the max multiplier is 11x.
Regarding temperature, my cpu right now is 33 celcius. what is a temperature i DON'T want to reach. what is the average "low" temperature while the processor isn't really being used or challenged? so far i think 45 celcius is the hottest i've seen it while using windows media encoder to encode at HDTV resolution and each processor was at 96 percent.
my cpu is a geniune AMD x2 4400+ with the heatsink and fan that came from AMD with the copper pipes.
Any help here is greatly appreciated!
Thank You
Thank You
