Revivalist said:
1. You can cool both the CPU and video card with it. I have personally seen great performance gains with a TEC on my video card as well. However, a phase change unit can only be used on the CPU. (Very few people have gone to the expense and trouble of putting a phase change unit on their video card as well.) People with phase change units that also want to extreme cool their video card usually end up getting a TEC setup for the video card anyways.
In most cases, yes. However, with a liquid chiller such as mine, you can cool both the CPU and GPU concurrently to extremely cold temperatures, far colder than you'll ever see a pelt hit.
Revivalist said:
2. It is more compact. A TEC setup can be placed completely inside a full-size ATX case so the computer is still portable. (It's definitely heavier but it's still portable.) A system with a phase change unit is usually not portable since it could be difficult and risky to try to move the computer and the phase change unit together.
You're correct there. Skilled phase change builders can fit full systems inside normal sized cases (Check out Zork's system, IIRC he's got TWO in a case.) But those are more the exception than the rule. DIY phase changers usually tend to have a mess of a test bench. For compactness and practicality a watercooled TEC system is usually a better choice, which is why I was considering one a long time ago myself. Ended up deciding that looks, noise and size don't matter to me. What ever floats your boat.
Revivalist said:
3. It can save more power. For daily use you can turn off the TEC and still get good temps due to the water-cooling. I usually get 35C idle, 45C load on the CPU and 40C idle, 60C load on the video card when the TECs are both off. For daily use I usually leave them off. For gaming and benchmarking I turn them on and get -2C idle, 18 load on the CPU and <31C idle and load on the video card (I don't know exact temps because the card doesn't report below 31). So leaving the Meanwell off most of the time is a good way to save on the electric bill. I don't think you can turn off a phase change unit while the computer is running.
This only pertains to chillers pretty much, but I can shut mine off or run it on a thermostat. After its pull down is complete, I can have subzero temps for around 6 hours in near dead silence with no power drawn.
Revivalist said:
4. It's cheaper. I believe a good phase change unit is around $900. A good water-cooled TEC setup will probably run you about $450 ($50 CPU waterblock with TEC, $70 GPU waterblock with TEC, $80 radiator, $80 pump, $50 fans, $85 Meanwell PSU, $20 tubes and coolant, $15 reservoir). And remember that you would be cooling the video card as well for that price.
People that build their own systems usually pay a bit less than this. The tools often comprise a large amount of the costs though.
I just converted an A/C so my needs weren't very aggressive.
$55-Eheim 1250 + 15ft of Tygon
$35-Swiftech MCW6002-P
$40-Swiftech MCW50 (Was purchased two and half years ago)
$70-Kenmore 5150BTU A/C
$10-Armaflex tape (neoprene insulation)
$33-3 gal denatured alcohol
$6-2 gal windshield wiper fluid
=$249
Revivalist
[U said:
5. No coldbug.[/U] I could be wrong about this but I don't think anyone has had a cold bug problem with a TEC-setup. However, with a phase change unit some CPUs just don't want to boot.
Well this is true, although technically some of the latest A64's don't like the sort of temps pelts would provide either. Though there are very very few procs out there that would cold bug on a Vapo LS/Mach II.
Pelts have always appealed to me despite the bad rap they usually get. Honestly though, the only reason I was considering them was because I have a Dothan. I wouldn't personally run one on a dual core A64 or P4, even a single is sort of pushing it. If the needs aren't as extreme though, TECs can make for very fast and practical systems, but now that procs are pushing beyond the 200W range, they won't even be an option for long.
