Go Back   Overclockers Forums > Hardware > Cooling > Water Cooling > WARNING: Ethyl Glycol can Kill
Reply
Thread Tools
Old 02-01-06, 02:02 PM   #1
bryan_d
bryan_d's Avatar
Just a heads up to those that do not know.
I am sure everyone knows not to consume your coolant but pay attention to your pets! It can take only one teaspoon to kill your dog and far less for a cat. I had the misfortune of having a leaking resevoir that I had to drain quickly only to return to a huge puddle of coolant right beside my cat. Cats and dogs WILL lick the coolant because Ethyl Glycol smells sweet and they will drink it readily. What is even worse is that you will not know your pets have consumed this substance until it is too late. So basically if you see your pets acting drunk or stumbling about, the damage is already irreversible.
For more info check out this site:
http://www.petplace.com/cats/ethylen...ats/page1.aspx
I know many of you will say, "I leak check my system to make sure I do not have leaks", but so did I. 48Hrs of leaktesting to be exact. I was lucky enough that I got my cats to the clinic in time.
No more watercooling for me
Bryan d
__________________
Warning: Ethyl Glycol Can Kill!
Heatware
E4300 Abit IP35-E
2GB DDR2800 8800GS 384MB
Seagate 320GB/1.5TB
Audigy2 ZS Seasonic 500W
Sunbeam 775, Acelero S1, and Blacked-out CM 331
bryan_d is offline   Reply With Quote
Old 02-01-06, 02:04 PM   #2
custom90gt
custom90gt's Avatar
Send a message via MSN to custom90gt
man that sucks, I'm just glad your cats are ok.
__________________
Heatware
Gateway P-7811fx - P8400, 4gb ddr3 1066mhz, 9800GTS
Lian Li V2010B, i7 920 @ 4.0ghz, EVGA SLI LE, ATI 4870, 6gb Corsair DDR3 @ ???, Apogee GTZ, MCR320, DDC with alphacool Res Top, DD 4870 WB, 2x 80gb X18-ms in raid 0, 2x1.5TB Samsung Spinpoints.
Back home again.
custom90gt is offline   Reply With Quote
Old 02-01-06, 02:05 PM   #3
dominick32
Senior Solid State Aficionado
dominick32's Avatar
Man,
I am really sorry to hear about this. A familiar thing happened to my girlfriend a few years ago. Her father left an open bucket of coolant in the garage, and the door wide open. Their cat smelled the coolant and drank a decent amount of it, only to seizure later on that night. It was a terrible accident, as well as your own. I am very sorry about this bro but glad that the cat made it out ok.
Dom
__________________
Next Level Hardware
Solid State Drive Technology Discussion Thread
...i7-920 D0@ 4.59 GHz...6GB Dom GT's Cas7...TRUE...4870X2...Asus P6TD...Corsair HX1000...Intel X25-M G2...2 X 1TB Blacks in Raid1...
Dominick32 states "Bow down to your SSD god dominick32 and kiss my feet which are actually made of pure light.
Jason4207 Responds: "Upon closer inspection to go in for that foot kiss I'm noticing that the 'light' isn't doing you any justice.
This should help. :) Circa 2010
dominick32 is offline   Reply With Quote
Old 02-01-06, 02:06 PM   #4
SStrokerAce
Send a message via AIM to SStrokerAce
Yeah... you might want to look at EvansCooling.com if you want a alternative to this.
SStrokerAce is offline   Reply With Quote
Old 02-01-06, 02:14 PM   #5
Maviryk
Maviryk's Avatar
Send a message via ICQ to Maviryk Send a message via AIM to Maviryk Send a message via MSN to Maviryk
No more kitty!!!
Maviryk is offline   Reply With Quote
Old 02-01-06, 02:14 PM   #6
Electron Chaser
Senior Delta Fanatic
Electron Chaser's Avatar
Send a message via AIM to Electron Chaser Send a message via MSN to Electron Chaser
I am glad to hear your pets are OK. You could think about changing coolant before you throw in the towel.
__________________
I am the Senior Omega of the Delta ... Fan Users :burn:
Custom 48" X 24" X 12" Case- Abit IC7-MAX3 - Pentium 4 3.4 EE @ 4.2 |Mach II Phase Cooled
BFG 6800 Ultra @ 470 | NV-68 Water Cooled -1.5 GB PQI PC4400 -1 KW PCP&C -
2 X Raptor 150GB RAID 0 , 2 74GB Raptor RAID 1, 1 36GB Raptor, 1 250GB WD SATA
BIX3 w/ 3 GFB1212VHW Fans (660 CFM Total) -Case Fans 5 EFB1212SHE (710 CFM Total)
MB / RAM Cooler 2 TFB1212GHE (440 CFM Total)
:cool: 1800+ CFM of Pure Delta Coolness :cool:
Someone Help you out? Post a Thank you here. Project Denali Heat
Electron Chaser is offline   Reply With Quote
Old 02-01-06, 02:21 PM   #7
Aidenswarrior
Aidenswarrior's Avatar
if you get the "pet safe" antifreeze, it doesnt smell sweet to them and isnt as harmful. that is the **** i use as a just in case. you always could just not use antifreeze and just use something else.
__________________
w/e
http://heatware.com/eval.php?id=40089
Aidenswarrior is offline   Reply With Quote
Old 02-01-06, 02:43 PM   #8
ƒÓÒl
ƒÓÒl's Avatar
RV antifreeze (for an RV's watersystem) is the safest, being made for drinking water systems using Food Grade propylene glycol. The "pet safe" stuff is not food grade PG, but is considered safe.
The drawback is that the corrosion inhibitors are meant to be flushed out yearly and replenished, so no long term system running with this stuff...
ƒÓÒl is offline   Reply With Quote
Old 02-01-06, 02:44 PM   #9
Amarkarian
Send a message via AIM to Amarkarian
yo grats on saving your cat, if my dog died i wouldnt now what to do
Amarkarian is offline   Reply With Quote
Old 02-01-06, 04:17 PM   #10
nicoliani
You don't have to go that far as not to water cool because of Ethylene Glycol. Besides you don't need that poison or any other poison coolant in your system.
Distilled water is OK to use without anything else.
Check my post on this on a other thread. I gave up Ethylene Glycol because of health matter.
Quote:
Originally Posted by MoreGooder
Huh? Oil and water don't mix. Now, I wonder how this combo works? Please elaborate, and most especially on the health issues you refer to.
Thanks,
MG
About my health I can tell, using distilled water and ethylene glycol 20%. I removed my fans so the water temp gets pretty high. I now use only a small external aluminum water tank.
So I started to have problems with my eye's, they started to itch and get red. Next I started to have stomach aches and muscles started to hurt in my legs. Next I ran for the toilet every time I started the computer. What I'm saying in this is that the ethylene fumes forced me to go an pee, and also that hurt allot.
I looked up everything about ethylene glycol and found this things happening to me described. It attacks kidney, brain, tissue, liver, blood-vessel and many other things.
You will wonder now, yes occurs if you drink it this will happened, and also drinking 100 ml will get your life.
But there is the fumes that we find irrelevant but they are relevant. And they easily get out of the system, wondering that small things like atoms you can not seal how much you try, and this fumes will cause this to you. The more temp there is in your loop the more affected you will get.
So as I said I use olive oil and water. The oil I use for grease my system, and it does it very well without me getting poisoned.
nicoliani is offline   Reply With Quote
Old 02-01-06, 04:25 PM   #11
bryan_d
bryan_d's Avatar
Quote:
Originally Posted by Maviryk
No more kitty!!!
No no,
My cats are still here but I still feel horrible for what had happened and just wanted to spread the word so other cats and owners do not have to go through the same ordeal as I.
I will look into the "pet safe" additives but right now I am getting out of the game because my girlfriend and I had to drop a great of money for these two guys. It was in the excess of $1,500.00 to get them treated. So if anyone wants to know, the antidote is roughly $600.00 a bottle.
Thanks for the reponses guys,
Bryan d
__________________
Heatware
E4300 Abit IP35-E
Seagate 320GB/1.5TB
Old 02-01-06, 04:30 PM   #12
jcw122
jcw122's Avatar
Send a message via AIM to jcw122 Send a message via MSN to jcw122 Send a message via Skype™ to jcw122
I'd say someone make this a
STICKY
because if it's true that many people use Ethyl Glycol, it should be something to put in the stickies as an important precaution.
__________________
"YES! I AM INVINCIBLE!!!"
Folding for Team 32!
Gaming Nick: new_Faction64 or CharminULTRA
CPU-AMD Athlon 64 3000+ 2.0Ghz@2.2Ghz (was 2.4) Socket 754, CG rev., Newcastle core
Memory-Crucial Ballistix 2x512MB @ 220mhz 2.5-2-2-5
Motherboard-No Idea My DFI Died Though
Video Card-MSI ATI 9800XT---412/390(was 424/395)---w00t! Flash from 9800Pro
PSU-Forton Blue Storm 500w
Currently Air Cooled w/ Scythe Ninja and AC VGA Silencer
R.I.P. Project: Humidity
Heatware
jcw122 is offline   Reply With Quote
Old 02-01-06, 04:35 PM   #13
Evil_Eye
Evil_Eye's Avatar
I second sticky.
__________________
CPU: Sempron 2800+ (stock)
CPU Cooling: Zalman CNPS7000B-AlCu
Mobo: Asus K8V-X SE
GPU: Sapphire X1600 Pro
GPU Cooling: Zalman VF700-AlCu
Memory: 2x Kingston ValueRam 512Mb PC3200 (stock timings!)
PSU: Sparkle FSP350-60PN
I need a new computer :(
Evil_Eye is offline   Reply With Quote
Old 02-01-06, 04:54 PM   #14
xdkimx
after filling my w/c system with prestone's eth glycol antifreeze, i got some on a cut i had on my hand and it felt sore for 3 days or so lol
__________________
cpu: amd 2x +4400
cooling: xp90+92mm vantec tornado
case: antec p180
gpu: xfx 7800 oc 490/1300
psu: enermax noisetaker 600w
ram: ocz 2x1gb platnum 2-3-2-5 3200
mobo: dfi lanparty nf4 sli dr
hdd: 74gb western digital raptor
bios: 6/23
xdkimx is offline   Reply With Quote
Old 02-01-06, 05:06 PM   #15
Herr Rogers
Herr Rogers's Avatar
STICKY. I'm sure most of us would agree that we would rather have our pets than a good computer.
__________________
Asus P5b-D Wifi, e6600, PCP&C 750W Silencer, 2x250GB Perps in Raid 0, 8800GTX, Samsung 204BW, Thermalright Ultra-120, Ballistix DDR2 1066
HEATWARE
Herr Rogers is offline   Reply With Quote
Old 02-01-06, 05:07 PM   #16
Time4aMassiveOC
Time4aMassiveOC's Avatar
AGREED STICKY
saftey should be as important as any OC
__________________
"If You Do Things My Way, They Will Soon Become Your Way.
If You Do Things Your Way You Will Soon Be Trying Them My Way.".
Q6600 2.4Ghz@3.33Ghz
P4 3.4@3.85Ghz(14x275) , 2Gigs@DDR2-550 3-3-3-7
1.36Vcore , 1.90 vdimm , 32C Idle , 45C Load
Abit AA8XE , 256MB X600PRO AIW 480/308 Max OC
XP-90C , SilentCat 92mm 21dba 53CFM
Antec Truepower 550w 24-pin
Building Computers and OverClocking should be Outlawed and made Illegal due to the Highly Addictive properties of GHZ
Time4aMassiveOC is offline   Reply With Quote
Old 02-01-06, 05:10 PM   #17
Maviryk
Maviryk's Avatar
Sticky! I love kitties. Good to hear they're ok!
I wanna get one... as soon as I move in to my new apartment...
But yea, sticky, and more kitties!
Old 02-01-06, 05:11 PM   #18
Nathan0490
Conroe Hoe
Nathan0490's Avatar
Send a message via ICQ to Nathan0490 Send a message via AIM to Nathan0490 Send a message via MSN to Nathan0490 Send a message via Yahoo to Nathan0490
rgr I agree on a STICKY too.
btw that cat is awesome
__________________
abit IP35 Pro
C2Q Q6600 @ 3.6 - 1.5v
4GB G.Skill DDR2 1000
Samsung 750GB F1 32MB Raid 0 (x2)
visionTek 3870 512MB
AuzenTech Prelude
Ultra-120 Extreme w/ Antec TriCool
Corsair HX620
HSPC Tech Station w/ 10" Legs
Vista Home Ultimate 64-Bit
Dell E228WFP 22" WS LCD 5ms
Logitech Z-5500 5.1 THX
Nathan0490 is offline   Reply With Quote
Old 02-01-06, 05:14 PM   #19
bryan_d
bryan_d's Avatar
Thanks guys,
I just found more info from www.care2.com:
"The toxic element in traditional antifreeze is ethylene glycol. The new kind of antifreeze contains not ethylene glycol, but propylene glycol, which is somewhat safer. In fact, propylene glycol is found in pet foods, cosmetics, and over-the-counter preparations."
Hopefully others hear the word,
Bryan d
__________________
Heatware
E4300 Abit IP35-E
Seagate 320GB/1.5TB
Old 02-01-06, 05:15 PM   #20
nachosyumm
Send a message via AIM to nachosyumm
Hmmmm, that would explain why i felt weird after sucking out the coolant in the bottom of my loop.
Thanks for the heads up. I think ill use an alternative to it when i rebuild my computer over easter break. My only pet is a bird who is deadly afraid of even going near my computer, but I would rather be safe then sorry.
nachosyumm is offline   Reply With Quote
Old 02-01-06, 05:15 PM   #21
JEmlay
Wow, thank God they're ok. I would have never thought twice about them ever licking it up.
I had a pet die from eating poison from someone elses yard. It took a long time to get over it...... or did I get over it???
Anyway, I'm new to the WC game and am looking at a Exos-2. Shut up about cost!!!!
So before I actualy buy it and use it what does Koolance use in thier "coolant"? Is it harmful?
Koolance Coolant
JEmlay is offline   Reply With Quote
Old 02-01-06, 05:22 PM   #22
DvBoard
DvBoard's Avatar
Send a message via AIM to DvBoard
glad to hear the kitty is ok. definattly somethign for those with pets to worry about.
__________________
*Dead* CPU:Intel Pentium 4 (Northwood) 2400MHz with the 533MHz Bus Speed.; Mobo:First International Computer, Inc. (FIC) Motherboard, model: VI13, Chipset: Sis645DX, BIOS: Phoenix Technologies, LTD version 6.00PG; GPU:ATi Radeon 9000Pro (128MB) Video card (4x AGP); RAM:1 stick 512MB PC2700 (166MHz) Xerox RAM; 1 stick 512MB PC3200 (200MHz) Corsair RAM; HD's:WD 250 Gig HD (x2); Optical:Lite-On DVD+/-RW, DVD-Rom; PSU:Antec SL400; OS:Windows XP
*Current Rig* CPU:E6600; Mobo:Asus P5B Deluxe; GPU:ATi Radeon HD 4870 w/1GB GDDR5 (PCI Express); RAM: (2 x 1GB) PC2-6400 DDR2 Corsair TWIN2X2048-6400PRO & (2 x 1GB) PC2-6400 DDR2 Corsair TWIN2X2048-6400; HD's:(2x 320GB) Seagate Barracuda 7200.10 SATA Drive & (2x 500GB) Seagate Barracuda 7200.11 SATA Drive & (2x 250GB) WD IDE Drive; Optical: Lite-on SATA DVD +/- RW & Lite-on IDE DVD +/- RW; PSU:Corsair 520HX; OS:XP; Case:Thermaltake Armor;
DvBoard is offline   Reply With Quote
Old 02-01-06, 05:24 PM   #23
wa77ss
wa77ss's Avatar
Send a message via AIM to wa77ss Send a message via Yahoo to wa77ss
STICKY
I was worried in the beginning, but a happy ending though. Cool cat !!! LoL.
__________________
Toshiba Satellite A105
[Intel T2050 1.66GHz] - [2x512MB DDR2-667MHz] - [100GB HDD]
Windows XP SP3 MCE
Heatware
wa77ss is offline   Reply With Quote
Old 02-01-06, 05:30 PM   #24
Amarkarian
Stick eeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 02-01-06, 05:36 PM   #25
bryan_d
bryan_d's Avatar
Quote:
Koolance Coolant
Sorry about your loss JEmlay... but unfortunetly, the Koolance liquid is not pet safe.
"70% distilled water
27-28% monoethylene glycol (anti-freeze)"
If you can find, SIERRA brand coolant, it contains pet safe additives.
And for those that asked
__________________
Heatware
E4300 Abit IP35-E
Seagate 320GB/1.5TB
Old 02-01-06, 05:36 PM   #26
Jeff Moser
Jeff Moser's Avatar
Thats why I use onlyTHIS in all my systems.
Jeff Moser is offline   Reply With Quote
Old 02-01-06, 05:37 PM   #27
z0n3
z0n3's Avatar
I've probably injested a few oz of the stuff over the last few years. I never would have thought so small an amount could kill a cat or dog. Thanks for the info. I was keeping my extra coolent at the foot of my bed. Well not anymore. Does anyone know of a safe way to dump this stuff? I don't think it is safe to have it in my house now.
__________________
In other words, look for shiny books.-Frodo Baggins
OK Oni...I've told ya about rubbing David before. Keep it private, eh?-LutaWicasa
I just caught myself putting my credit card into the DVD drive of my computer ... -ghettocomp
LOL if I was sapphire I would leave ruby on there and take her shirt off instead...-Rattle
What do you most want to accomplish with your life? Ban SilverSinkSam-cw823
Ooo. that 1 comes with a mouse!-WarriorII
last friday I got back from annual training and downloaded my duffelbags to my house.-SuperFarStucker
Thank goodness the downtime was not any longer I almost got myself a life-UnseenMenace
I live in a steel reinforced cave/bunker so unless he is on my list of bad guys to kill, I don't pay too much attention to politics.-TommyHolly
z0n3 is offline   Reply With Quote
Old 02-01-06, 05:45 PM   #28
bryan_d
bryan_d's Avatar
Quote:
Hit up your local autoparts store for more info. I know in my city we can get milk bottles and put used auto oil in them for garbage men to take away.
This is from www.greentruck.com:
"Used Antifreeze Disposal
If you do not reclaim/recycle your used antifreeze at your facility, it may be recycled offsite by an EPA-approved facility. If it is hazardous waste (because of its lead content), you must transport it by using a transporter with an EPA identification number and prepare it for transport appropriately. Used antifreeze that is mixed with other fluids must be characterized to determine if it is hazardous waste, and disposed of accordingly. Nonhazardous used antifreeze also may be disposed at a landfill that is authorized to accept used antifreeze. Many landfills have a tank designated for used antifreeze disposal. Used antifreeze may not be dumped with regular trash, poured into the sewer, or poured onto the ground.
Do's and Don'ts for Antifreeze Disposal
DO. . .Keep used antifreeze in a covered container and out of the way of animals, who are often attracted to its sweet flavor. Be sure your recycled antifreeze meets manufacturers' warranties for the vehicle you are servicing. As described above, recycle antifreeze by purchasing or leasing onsite recycling equipment; or using an offsite recycling service. Handle filters and other recycling by-products as hazardous waste.
DO NOT pour antifreeze into sewers, on the ground, or into floor drains, or mix used antifreeze with any other waste. Keep it separate.
DO NOT collect antifreeze in containers that have been used to hold other substances (e.g., gasoline) unless the containers have been thoroughly cleaned. Antifreeze can leach substances from the walls of a container.
For Additional information
Call the RCRA Hotline at 1-800-424-9346 for information on determining if your antifreeze is hazardous. "
__________________
Heatware
E4300 Abit IP35-E
Seagate 320GB/1.5TB
Old 02-01-06, 05:51 PM   #29
PWatterson
PWatterson's Avatar
I vote sticky. Safety..for anyone.. is the most important thing. Glad to hear your cat(s) came through it ok though.
__________________
Personal: Intel E3110 - Biostar TPower I45 - 2x2Gb Mushkin Redline - eVGA GTX260 Core 216 - WD VelociRaptor 74Gb RAID 0 - Seasonic S12II Bronze 520w - Antec Twelve Hundred
Spare: AMD Opteron 165 (2601 MHz @ 1.325v x 110%) - DFI nF4 Lanparty SLI-DR - 2x1Gb OCZ Platinum - eVGA 7800gt SLI - WD 120Gb - Enermax 350w
Gov't Issued Desktop: Intel E8400 - Dell Motherboard- 4Gb DDR2 - ATI Radeon HD4670 512 Mb - 320Gb Seagate
Gov't Issued Netbook: Intel Atom Z520 - 1GB DDR2 - 40Gb PATA
PWatterson is offline   Reply With Quote
Old 02-01-06, 06:01 PM   #30
Romulox
Romulox's Avatar
Don't drink any more of it because its a reproductive hazard.
http://ptcl.chem.ox.ac.uk/MSDS/ET/ethylene_glycol.html
I had to look up info about this for chem class and I always use this site to find info about chemicals.
http://www.physchem.ox.ac.uk/MSDS/#CASnumbers
But its helpful if you know the cas number of the chemical.
propylene glycol is a food preservative.
Its kinda of funny that just one methyl group makes this stuff edible.
__________________
AMD 3800X2
2GB OZC GTX
Asus A8N32-SLI Deluxe
xfx 8800gts
Audigy ZS2
Antec III 550/Super lanboy
Samsung 206BW
Romulox is offline   Reply With Quote
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
