Thread Tools |
#1 |
![]() ![]() ![]() ![]() Member |
My First Water cooling setup (P180 case)
Setup consists of: 1/2inch thick walled ClearFlex MCP655 Pump Storm CPU Block MCW60 GPU Block with Ceramique'd/SuperGlue'd ramsinks BIP.3 w/6 47cfm Yate Loons in Push Pull All nice stainless Lowes worm clamps, haha BTW, this was my spring break besides working at the WONDERFUL Compusa here.http://i34.photobucket.com/albums/d1...j/IMG_0687.jpg How it all started(My girlfriend's bedroom... she loves me I KNOW )http://i34.photobucket.com/albums/d1...j/IMG_0690.jpg X1900XTX http://i34.photobucket.com/albums/d1...j/IMG_0691.jpg She's all apart http://i34.photobucket.com/albums/d1...j/IMG_0692.jpg X's 2 http://i34.photobucket.com/albums/d1...j/IMG_0699.jpg Finished Product 1 http://i34.photobucket.com/albums/d1...j/IMG_0694.jpg Finshed Product 2 http://i34.photobucket.com/albums/d1...j/IMG_0697.jpg Finished Product 3 http://i34.photobucket.com/albums/d1...j/IMG_0717.jpg BLING! haha Hope you like PS... Clamps are to keep the tubing perfectly round in the tight turn and the T-line is capped now as I was still bleeding it in the pictures. Richard
__________________
Gautam: "I like the black one... its 4" longer too... but its not 'high performance" Mobo------------Asus Commando CPU-------------L628B121-E6600(Apogee GTX)@ 505x8@ 1.53V Actual (Still Testing) Vid--------------BBA ATI X1900XTX @ 765/900@ 1.550/2.217 volts (Swiftech MCW60) Ram----------- 2x1024 OCZ PC2-8500 HDD------------74GB Raptor, 2 320GB 7200.10's Matrix Raid Optical--------- DVDRW's- Dual Lite-On LH-20A1S PSU------------ Thermaltake Toughpower 1200W Water Cooling- PA120.2 & PA120.3 (San Ace fans), Dual DDC2's with Petra tops, 7/16" lines Benchies PCMark05: 9420 3DMark06: 7751 3DMark05: 13203 3DMark 03: 26301 SuperPi: 12.782 Project: Clean Overkill Last edited by eightballrj; 03-21-06 at 03:57 PM. |
#2 |
how cool does it keep that 1900?
__________________
< FOLD! < Heatware < EVGA X58, 920, TRUE, 12GB Corsair, 2 x EVGA GTX 285, Enermax Revolution, Velociraptor, 7 64-bit |
#3 |
Cool enough for 760/890 at 1.425 volts. I can get you temps later.
__________________
Gautam: "I like the black one... its 4" longer too... but its not 'high performance" Mobo------------Asus Commando CPU-------------L628B121-E6600(Apogee GTX)@ 505x8@ 1.53V Actual (Still Testing) Vid--------------BBA ATI X1900XTX @ 765/900@ 1.550/2.217 volts (Swiftech MCW60) Ram----------- 2x1024 OCZ PC2-8500 HDD------------74GB Raptor, 2 320GB 7200.10's Matrix Raid Optical--------- DVDRW's- Dual Lite-On LH-20A1S PSU------------ Thermaltake Toughpower 1200W Water Cooling- PA120.2 & PA120.3 (San Ace fans), Dual DDC2's with Petra tops, 7/16" lines Benchies PCMark05: 9420 3DMark06: 7751 3DMark05: 13203 3DMark 03: 26301 SuperPi: 12.782 Project: Clean Overkill |
#4 |
![]() ![]() ![]() Member Join Date: Aug 2004
Any specific reason on why you went with 6 Yate Loons? I know the Yate Loons are quiet but could you have wired the fans separately such that you have 1-2 Yate Loons for when you want quiet operation and a set of say ... Deltas for when you want performance? Just a thought. :b I like the elevated rad. Speaking of wiring - how is it for the p180? I've heard of some issues surrounding that. Also, any issues with the door on the p180? It's been mention before on the forums and the display model at the local computer store here has a door problem too.
__________________
Gigabyte P35-DS3R, Q6600 w/ Scythe Infinity, Gigabyte 8600GT, 2Gb Corsair XMS2, Corsair HX-520, Antec P180 - all stock Asus P4S333-M, P4 Northwood 1.8 GHz @ 2.5 GHz, Maze4 w/ evaporative synthetic towel tower contraption & Eheim 1250 Asus S1300N, P-M Banias 1.4 GHz |
#5 |
Well the BIP isn't optimized for big flowing Deltas. It performs quite well as it sits with the Loons. The fans are actually sealed to the rad with silicon to help out the push/pull setup be as optimal as possible. Haha, the radiator stand offs are mechanical pencil bodies dremel'd to the correct length. RJ The door is a bit warped but nothing of issue to me. It locks and works perfectly and doesn't look wrong. The wiring is a PITA... but I hate wiring cases as you can tell, haha.
__________________
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member |
Quote:
__________________
"I have always wished for my computer to be as easy to use as my telephone; my wish has come true because I can no longer figure out how to use my telephone" -- Bjarne Stroustrup I like it when pandora apologizes to me. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Feb 2005
Looks great! Reminds me very much of my old watercooling case You should PM LabRat23 for some thermal adhesive. I know your ceramique/super glue works great but I couldn't trust it on a $450+ card and the tape that LabRat23's thermal tape works really well ( I had it on my 6800 Ultra and heat transfer was awesome; also they stuck so well that it took me like 5 minutes to get them off each ram module!Again great job, bryan d
__________________
Warning: Ethyl Glycol Can Kill! Heatware E4300 Abit IP35-E 2GB DDR2800 8800GS 384MB Seagate 320GB/1.5TB Audigy2 ZS Seasonic 500W Sunbeam 775, Acelero S1, and Blacked-out CM 331 |
#9 |
Wouldnt trust it how? Like falling off? I promise these wont fall off. I dont think I will ever remove them now I got the results that I did from the card.
__________________
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member |
Very nice but you might want to plug the T-line....
__________________
Asus P5Q mBIOSes 2002m BIOS OCZ Vendetta 2 Intel C2D E7200 2530MHz@3800MHz A-Data Vitesta Extreme DDR2 800+@1066MHz 5-5-5-18 PNY Nvidia GeForce 8800GT 512mb Arctic Cooling Accelero S1 Rev. 2 HEC WIN 580W PSU Heatware (Yes Israelis have it too!) PayPal Verified |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Senior Spellcheck Join Date: Dec 2005
Quote:
It looks pretty sweet. ![]() |
#12 | |
Quote:
__________________
#13 |
Hey, i got a quick quesiton: how did you shave off the ram sinks for the vid card, so that they didn't interfere with the tubing. I started filing mine with a metal file...but it was SOOO slow... took like 30 mins for 1mm ![]() |
#14 |
Dremel is god for that kind of stuff. Just get some pliers to hold it firm.
__________________
#15 |
looks awesome
__________________
Antec 900 Intel Q6600 at 2.4Ghz G0 Asus Maximus Formula x38 bios 1201 4 gig patriot 5-5-5-12 ATI 4870x2 Sounblaster X-Fi Fatality Seagate 80gig 7200 Corsair HX1000W |
#16 |
Kinda a noob question. What size lines are you running? I have the same case as you. I plan on using the same pump you have that is why im asking. Only thing different I am going to do, beside mount my rad on the back, is place my pump In the very bottom of the tower and add another fan in the bottom fan slot.
__________________
Antec 180 Quiet tower A8N32-SLI Deluxe [Bios 1303] 34c/38c AMD 3200 Venice 32c/35c G.Skill 1g 3200 DDR-400 Pioneer dvd/w/rw Seagate 160G (7200) SATA 27c/30c eVGA 6600GT 128mb (x2) In SLI 52c/61c Apogee, DDCR2 18w, BI-GT stealth 240, Tanky rez, S-flex 1600x2, Home depot 7/16 hose |
#17 |
All thick walled 1/2inch ID Clearflex. Only thing about mounting it at the very bottom with the fan down there is that getting the tubing into the main bay without kinking it. Good luck with your setup! Make sure to show us the damage afterwards ![]()
__________________
#18 |
Sure will. I'll take pics when its done. I was wondering where people get the springs to put on thier lines to keep them from kinking. I was also thinking something else. The fitting on the front side of the pump is straight out is there anyway to put a 90 on it or a swing 45? I wonder if you can buy a fitting and glue it in place with pvc glue or something. Its just a thought. I plan on taking out the hd bin at the bottom to make room for the pump.. so its outta the way.
__________________
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Banned |
Nice setup looks great ![]() |
#20 | |
![]() ![]() ![]() Member Join Date: Mar 2005
Quote:
__________________
"I've tried everything. I have not failed. I've just found 10,000 ways that won't work." - Thomas A. Edison My Heatware |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Feb 2005
Nice setup. Good job especially for a first build. It's good to know that there is SOMEONE who works at a Compusa that actually knows what they are doing with computers. I can't help but laugh and sigh at the same time whenever i am in a comp, best buy, etc. and hear the sales reps give these poor people some spiel that you know just by hearing they have no real idea what they are talking about. Sounds like you have a pretty good girlfriend for her to let you spread your PC watercooling all over her room. I do agree with bryan_d about the thermal tape instead of the adhesive. The ceramique will hold for certain, but if by some chance your video card ever dies, you probably won't be able to get the heatsinks off without pulling off the BGA chips to RMA it. The Sekisui #5760 thermal tape is the safer way to go. Last edited by voigts; 03-25-06 at 01:00 AM. |
| Thread Tools | |
