Notices
Overclockers Forums > Hardware > Cooling
Cooling Discussion of fans, heatsinks, thermal pastes and putting it all together to keep your rig cool
Forum Jump
What are acceptable temps?
Thread Tools
Old 04-18-06, 10:21 PM Thread Starter   #1
Billiam151
Hello, I am a newbie... I just had a system built for me and so far everything is good.. a couple of video wig outs, which I am assuming happen most likely from heat... so that makes me question what is acceptable for case temp and cpu temp...I downloaded Motherboard monitor and I am not so sure that it is not set up 100% correctly considering it says my cpu temp is -22f. here are the specs to my system:
Coolermaster Cavalier T03
Gigabyte K8NPRO SLI
AMD Athlon 64 3700
1.5gb ddr ram
XFX Geforce 6600 GT 256 pci-e
Windows xp home
Nspire 450 watt power supply
WD 250gb SATA2 w/16mb
Any help would be greatly appreciated... I am looking for what temps should be, and how I should set up MBM correctly to show correct cpu temp..
Thanks,
Billiam151
Billiam151 is offline   QUOTE Thanks
Old 04-19-06, 01:32 AM   #2
otogrim
Those temps are definately wrong unless u live in a tent in siberia or something. It should be close to High 30C Low 40C idle. As far as MBM there should be a list of mb on there where u could pick one and have it configured automatically
__________________
Heat
otogrim is offline   QUOTE Thanks
Old 04-19-06, 07:50 AM Thread Starter   #3
Billiam151
That is what I thought.
No I do not live in Siberia, so I guess I will make sure that I have the settings correct in MBM.
Thanks,
Billiam151
Old 04-19-06, 08:07 AM   #4
Electron Chaser
Senior Delta Fanatic
Electron Chaser's Avatar
I get those kinds of temps but I am phase cooling my CPU. So yeah they seem a bit out of adjustment. LOL
On startup go into your BIOS and find out what temps the MB is actually reporting so you have a good idea of where you should be and adjust accordingly.
__________________
I am the Senior Omega of the Delta ... Fan Users :burn:
Custom 48" X 24" X 12" Case- Abit IC7-MAX3 - Pentium 4 3.4 EE @ 4.2 |Mach II Phase Cooled
BFG 6800 Ultra @ 470 | NV-68 Water Cooled -1.5 GB PQI PC4400 -1 KW PCP&C -
2 X Raptor 150GB RAID 0 , 2 74GB Raptor RAID 1, 1 36GB Raptor, 1 250GB WD SATA
BIX3 w/ 3 GFB1212VHW Fans (660 CFM Total) -Case Fans 5 EFB1212SHE (710 CFM Total)
MB / RAM Cooler 2 TFB1212GHE (440 CFM Total)
:cool: 1800+ CFM of Pure Delta Coolness :cool:
Someone Help you out? Post a Thank you here. Project Denali Heat
Electron Chaser is offline   QUOTE Thanks
Old 04-19-06, 08:20 AM   #5
striker85
striker85's Avatar
Motherboard Monitor can be a pain sometimes. I know that it does not support EPoX boards for some reason(since I have one and tried using MBM to no avail). So I'd recommend trying another program to monitor temps such as Everest.
__________________
Heatware Ebay
Rusty:
Gigabyte GA-MA78LM-S2H (Rev. 1.0)
AMD Phenom II 720 (unlocked to 4 cores and oc'd to 3.4 ghz)
2GB Generic DDR2 (oc'd to 800mhz)
XFX HD5670
Corsair 520W PSU
striker85 is offline   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
