Thread Tools |
#1 |
![]() ![]() ![]() ![]() ![]() Member Join Date: Feb 2006
Slightly Modified P180
Hello, I finally decided to cut 2' 2" from my loop and mod my P180 to accommodate the smaller loop. Setup: -660 OC 4.36 @ 1.5250V in bios no modding -x1900xtx OC 733.5/846 @ 1.500VGPU/MVDDC 2.108V/MVDDQ 2.108/VDDCI 1.503 -P5WD2-E Prem -2 Gig Corsair PC6400 -PC P&C 510 ASL PSU -P180 Case ------------ Cooling Setup: -Maze 4 for GPU -Storm CPU -D5 Pump -Tygon loop -BIX II -Distilled Water Here are a few photos. --------------- ![]() This photo shows the look of my loop prior to modding. This [hoto shows only: -1 BIX -roughly 9' of loop -Maze4 -D5 (not shown) --------------- ![]() This photo shows the look after modding the P180. The loop is cloudy because there are still bubbles in the loop at the time the photo was taken. Also note the 1/2" T which is actually the OD not the ID. The ID of this T normally purchased anywhere, is 3/8" which is smaller then 1/2", creating restriction...a lot of restriction. --------------- ![]() This is a close up of the 2 holes that I drilled. If you noticed I switch the order of how it enters the rad only because the tube would kink if I used the normal method. In all this worked best. -------------- ![]() this shows the tools I used as well as how much tubing I cut which is 2' 2" -------------- In order to fit the rubber hole gormments I had to drill a 1" hole in order to accommodate 3/4" gormment. Keep that in mind if you want to drill holes in your case. Also note that you want to buy a metal/wood not the wood kind. You will know you have the right tool because it costs more : Needless to say its still a work in progress... Ok, after about 1 hour 40 minutes bleeding (T line in loop)is complete and I took some temp readings (using the 3/4" OD 1/2" ID T). Before bleeding was roughly 6.5 to 7 hours on average with the 1/2" T with the 3/8" ID. Before, with the extra 2' 2" of loop and 1/2" T with 3/8" ID (small hole) readings are as follows: Ambient is 25C -x1900xtx OC 733.5 GPU and 833 MEM idle 33C and 41C using RTHDTIBL VC temps is 38C -660 OC from 3.6 to 4.36GHz idle 37C and 42.5C using Prime95 MB temps is 27C Now, with 2' 2" less tubing in the loop making it roughly 6'-7' with 3/4" T with 1/2" ID AMBIENT TEMPS ARE 30C x1900xtx OC 733.5 GPU and 833 MEM -idle temps 35.6C ![]() -Load temps 43.6 ![]() -660 OC from 3.6 to 4.36GHz -idle temps 38C ![]() -Load temps 44.5C ![]() In all in overall improvement even though there is disparity of 5C hotter on ambient, load temps for: x1900xtx = 2.6C difference with ambient temps being 5C hotter 660 OC 4.36 = 2.0C difference with ambient temps being 5C hotter. Again, the only difference is: -2' 2" less tubing -only using distilled water this time -used 3/4" T with 1/2" instead of 1/2" T with3/8" ID That is basically all that I have changed in this WC setup Also, some good info regarding DD's Maze4 & the x1900xtx from personal experience -you need to loosen all 4 blots and try to keep them all at the same height or simply remove them all and start over from stretch. -if you start over from stretch you need to count the number of turns for the first bolt, then place the 2nd bolt diagnal the 1st bolt or crisscross. Then count the same number of turns you used for the first bolt. No more then 3-4 turns please! -do the same for 3rd and 4th bolts, in criss cross fashion. -tighten the 1st 2 bolts (1st and 2nd) in a crisscross fashion with 3 or 4 turns ONLY -tighten the 2nd set of bolts (3rd and 4th bolts) in a crisscross fashion with 3 or 4 turns ONLY -now go back to the 1st bolt turn it another 3 or 4 times and do the same for the 2nd bolt. -repeat this process with the 3rd and 4th bolt. -DO NOT OVER TIGHTEN. YOU DON"T NEED TO TIGHTEN UNTIL YOU CAN'T TURN IT NO MORE...t -In all each bolt should have around 7-9 turns each. This is what I have counted but I used a x1900xtx and this number can vary. However you should only worry about tightening down the bolts when all 4 bolts are properly torqued. Then you can do 1 full turn of each of the 4 bolts until all have the same level of stress when you turn them. This is the best method that I found. Unless there is a torque alan wrench you can buy??? Why do it this way? It's been my experience when one bolt is to tight you warp the card if you do not apply the same amount of pressure (aka turns on each screw) on all 4 screws. This is because you do not have the necessary slack when tighten down the WB on the gpu (such as springs) and with each turn (when contact is made with the screw and the video card) you are actually apply pressure on the VC with the WB. All you need to do is place the card on it's axis (horizontal position) at eye level. Also, you will notice that its a bit more difficult to place it in your PCI slot and it will not line up properly. This also can cause your WB to not have contact on certain portions of the GPU while other portions have full contact... Last edited by ECH; 05-27-06 at 10:57 PM. |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Member |
Nice Setup!
__________________
BLUE-PHOENIX(gaming rig)......ZERO-ONE(file/game server) OS=.......Windows 7 Ultimate 64-bit.........................Ubuntu - 9.10 MOBO=. Gigabyte GA-MA790GP-DS4H...............ASUS M2N-LR RAM=.....2x2GB Corsair Dominator PC2 8500....4x2GB G.Skill PC2 6400 CPU=......AMD Phenom II X4 965 @ 3.9Ghz.........AMD Phenom 9850 @ Stock PSU=......Corsair 750TX.................................................. ...Ablecom 650Watt PSU VID=......EVGA GTX260 Core 216...............................on board ATI es1000 HD=.......750Gb Seagate 7200.10.................................2TB Raid5 Array + 4.5TB Raid5 array fold as if your life depended on it....Protect your Computing Rights! Remember that the Forum Search and Google are very helpful tools :) My Heat 24-0 |
#3 |
^^Thanks for the compliment but I am not done with it just yet I want to everything inside the case.Last edited by ECH; 05-26-06 at 10:38 AM. |
#4 |
![]() ![]() ![]() ![]() ![]() Member Join Date: Feb 2002
nice i love to see Other Antec P180 modded. i should really post some pix of my case. What are u cooling?
__________________
5 G H Z C L U B 631 @ 5000 - 1.55v - Water cooled P5WD2 Premium, Ocz 5400 @ 4-4-4-8 @ 1.95v Swiftech Apogee/ 85 Caprice Heatercore/ Swiftwech MCW60/ Swiftech MCP600/ OCZ Powerstream 520/ BFG 6600GT OC- 4x WD 36gb Raptors (Raid-0) - All wrapped in a modified Antec P180 Heatware: NODES |
#5 |
I've updated my sig below. ![]() |
#6 |
Update: I was getting way to much restriction using a 1/2" T. What I found out is the 1/2" T is the OD and not the ID. So I visited my local hardware store and picked up a copper (could be brass not sure) 3/4" by 3/4" by 3/4" T that has a 1/2" ID. ![]() Using a Tygon 1/2" ID and 3/4" OD tubing. Surprisingly enough the tygon 3/4" OD, 1/2" ID tubing fits like a charm and I could push it all the way in without much resistance. ![]() After I refilled the Loop with water the first thing I notice was the fact that it it took a lot more liquid then normal. Bleeding of the loop was faster then expected and I was able to start my computer in about 25 minutes of bleeding. So far after an 1 hour the bubbles are almost gone after shaking the rad a few times. If you are using 1/2" ID tubing with a 1/2" T I serious recommend that you replace it with a 3/4" T as most 3/4" T have 1/2" ID by design. Do not use 1/2" T because that only tells you that the OD (outer Diameter) is 1/2". The ID (inner diameter) of a 1/2" T is 3/8". So unless you are using 3/8" ID tubing 1/2" Ts are fine to use! Here is a photo of the old T ![]() Last edited by ECH; 05-28-06 at 11:35 AM. |
#7 |
the first post has been edited please review and give opinions Last edited by ECH; 05-27-06 at 10:58 PM. |
#8 |
Might have to take u up on that 3/4 T
__________________
#9 | |
Quote:
#10 | |
Quote:
__________________
#11 |
i got mine from lowes |
#12 |
![]() ![]() ![]() Member Join Date: May 2005
Which pic is the after pic? The one with the dual rad? I mean didnt you intend to fit everything inside the case? Or is it not done yet? |
#13 |
not done yet... |
#14 |
![]() ![]() ![]() Member Join Date: Jul 2004
well if your switching out the t because it is only 3/8 inside and 1/2 OD then aren't the bards also 3/8 id and 1/2 OD.... so then you should also switch the barbs out... EDIT- i might be wrong here but i think there is a problem with thinking this way because i don;t think by going to a bigger t will help since ur pump is also only a 3/8 id by 1/2 od so if you pump can only take in 3/8 then i dont think a t would be a restriction also take a look at the barb fittings for your storm and notice that you can fit the thread of the bard easily into 1/2 id tubing which means that the id of the barbs is also less then 1/2 id
__________________
Server: P4 2GHz - 2x256 Mg Ram - Asus P4P800-VM - WD HD 200 GB - 3ware 8006-2LP SATA RAID Controller - 2 x 320 Seagates Barracuda 7200.10 (RAID 0) - AirCooled: ThermalRight XP-120 Laptop: Asus W3V - 14” WXGA(1280 x 768) - P-M 1.86 GHz - 1024MB DDR2-533 - ATI X600 - 8 x DVD+RW DL - Toshiba 5400 RPM 100 GB 16 MB Cache - Built in Bluetooth - Built in Mic - Intel wifi 2915ABG - Secondary Modular Bay Battery - Secondary Modular Bay Hitachi 5400 RPM 60 GB Hard Drive Main Rig: AMD64 3500 Winchester - BFG OC 6800GT - Asus A8V Deluxe - Corsair 2x512 - 2 x WD Raptor 74 GB (RAID 0) - Maxtor DiamondMax 10 300 GB - Audigy 2 - ATI Tv Wonder Pro - WaterCooled: DDC1+ (w/ Alphacool Top) - Swiftech Storm - PA 120.1 - T-Line - 1/2" Tubing Last edited by Icedfire101; 05-28-06 at 03:53 PM. |
#15 | |
Quote:
It's amazing that someone can conjure up ideas like this without testing them first before you post opposition to the idea. Now if you actually tested the idea first instead of assume based on variables you think are valid then I would take some creed in what you are saying. However, this is not the case at all. |
#16 | |
Quote:
ok so how much has it improved ur temps? and how much has it improved your flow rate? specific numbers please... to me it seems like the pot calling the kettle black...
__________________
Server: P4 2GHz - 2x256 Mg Ram - Asus P4P800-VM - WD HD 200 GB - 3ware 8006-2LP SATA RAID Controller - 2 x 320 Seagates Barracuda 7200.10 (RAID 0) - AirCooled: ThermalRight XP-120 Laptop: Asus W3V - 14” WXGA(1280 x 768) - P-M 1.86 GHz - 1024MB DDR2-533 - ATI X600 - 8 x DVD+RW DL - Toshiba 5400 RPM 100 GB 16 MB Cache - Built in Bluetooth - Built in Mic - Intel wifi 2915ABG - Secondary Modular Bay Battery - Secondary Modular Bay Hitachi 5400 RPM 60 GB Hard Drive Main Rig: AMD64 3500 Winchester - BFG OC 6800GT - Asus A8V Deluxe - Corsair 2x512 - 2 x WD Raptor 74 GB (RAID 0) - Maxtor DiamondMax 10 300 GB - Audigy 2 - ATI Tv Wonder Pro - WaterCooled: DDC1+ (w/ Alphacool Top) - Swiftech Storm - PA 120.1 - T-Line - 1/2" Tubing |
#17 |
I would think that the radiator or the waterblocks are more restrictive in your loop, so it's more like you cant get any worse than the weakest link, so just dont restrict more than the rest of your loop, for me, a 1/2" OD T-fitting is fine because I have a DangerDen RBX with the impingement jet nozzle.
__________________
Current Setup: Case: MGE XG-Quantum PSU: 560w SilverStone Zues CPU: Intel Pentium Extreme Edition 965 ES @ 4617MHz 355 x 13 Motherboard: GigaByte GA-G1975X Video Card: eVGA 7900GT KO SuperClocked @ 590/1610 Hard Drives: 36.7 Gb Western Digital Raptor, 500 Gb Seagate Barracuda 7,200.9 RAM: 2 x 1Gb G.SKILL DDR2 PC2 5400 (4-4-4-12) @ 888MHz Other Devices:Logitech G5, G15, and z-5300e 5.1 Surround Sound, Sennheiser HD485's, SB Audigy 2 ZS, TWO 21" CRT Monitors (AS120-BK & IBM P260 Trinitron) Cooling: DD RBX, DD NV-78, DD-D5, Tygon R3603 (interior), TWO BIXII w/ 4 Panaflo FBA12G12U Fans (115 CFM), Stainless Steel 3/8" OD Piping (exterior to Rads) w/ SwageLok Compression Fittings. |
#18 | |
Quote:
| Thread Tools | |
