If you dont want to keep the geforce 2 series, Buy a Geforce MX 4000. Trust me Its a good card for only $50 and it has 128MB. How much memory does your card have?
oc it all you want but im not sure how youre gonna play games on it....
as for the clock speeds, push it as far as itll go, try 10mhz increments. make sure you dont fry the chip, check its temp (prolly by external probe or by touch.) then check for artifacts.
i would expect an increase of 100ish mhz for the core.
