Notices
Overclockers Forums > Hardware > CPUs > AMD CPUs
AMD CPUs
Forum Jump
Help match my ram with a dual core 939 cpu
Thread Tools
Old 08-05-06, 11:28 PM Thread Starter   #1
Brando
Brando's Avatar
Like many others I've been tempted by recent price drops to keep my system alive for awhile with a cheap dual core upgrade. I'm trying to get a processor that matches the bandwidth of my OCZ El platinum 2gb set. I wouldn't want to spend $360 on an X2 4800+ if my ram is just going to hold it back. Then again I'd like to take full advantage of my sytem and use all of the memorys potential.
My particular set doesn't really overclock as it was made for low latency rather than high frequency. At 200mhz\1t or just over it can push about 6000mb\s. At what point will a cpu be bottlenecked? Any advice is appreciated. Thanks.
__________________
[]Intel 3570k 4.4ghz~Asus P8Z77-V pro~Megahalems[]Mushkin Blackline 2x4gb[]Gtx 670 direct cu II[]Dell U2410[]Plextor M3 pro 256gb~Spinpoint F3 1tb[]Pioneer BDR-206[]Corsair AX850[]Lian Li PC-V1020A[]Leopold tenkeyless~Deathadder[]Harman Kardon HK3490~Denon AH-D7000[]
HEAT: http://www.heatware.com/eval.php?id=48093
Brando is offline   QUOTE Thanks
AMD CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
