- Oct 27, 2002
Evening-
I'm at the end of my rope here and hoping someone might shed some more ideas for me to use.
My computer randomly freezes. It freezes when idle, when I walk away, when I hit the back button. There is no rhyme, reason, cpu load, or discernible pattern.
The system is not overclocked- stock 4200 (200x11) using stock voltages, although I did up the voltage on the ram to test that.
Memtest86 shows no errors in ram (2gb OCZ matched)
I have a SCSI controller, FireWire controller, and a Promise 133 controller.
The problems first manifest themselves when I installed the Gigabyte SilentPipe II 7600 GT card.
I removed that and replaced it with an AGP card- system locks up still.
I removed the Promise controller (since it kept hosing my 4x200gb seagates). System locked up.
I reinstalled the Promise controller and the 7900GT then I removed the SCSI and IE1394 controllers. System locked up.
I have tested 3x different PSU's - Antec 430 True, Ultra 500 with the funny cables, and another ultra 500 with fixed cables. All had lockups.
I'm starting to wonder if it's the power regulators on the board that are crapping out, but I don't know any way of testing it. Monitoring programs show the voltages are nominal and, with no easy way to predict, it's sporadic crashes that I can't duplicate.
Worst of all this last 'crash' hosed (apparently) one of the 200gb seagates in the raid 5 array off the promise controller. I'm trying to rebuild it now but that takes time.
Any other suggestions that I can try that I Might have missed? Any other iterations?
Thanks much-
Jason
Thanks much-
Jason
