Go Back   Overclockers Forums > Hardware > Cooling > **Guide**P5W-DH Cooling Mod (Pics)
Reply
Thread Tools
Old 12-24-06, 10:47 PM   #1
enz660
enz660's Avatar
Send a message via AIM to enz660
Note: I am not held responsible for any damage you cause to your computer from using this guide. What you do to your computer is up to you. This would obviously viod any warranty you have on the motherboard.
Tools & Materials Needed:
- Small Pliers
- Sharp blade (something small such as a utility knife blade or exacto knife)
- Qtips
- Rubbing Alcohol
- Your favorite thermal paste
1. Flip the motherboard over and use the small pliers to squeeze the plastic pins closed while pressing them into the motherboard until they pop back into their holes. Be careful not to over squeeze or you might damage the pins.
2. Start with the lower heatsink. This will be a bit difficult to remove since the stock thermal paste is very dry. Use some soft levar and support it using your finger. Put the other end under the heatsink and slowly push it up a little under all four sides until it pops off. Be careful not to support the lever on any parts of the motherboard.
3. Now the upper NB heatsink should be much easier to remove. Simply unlatch both sides and rotate it a little and it should be easy to pull off.
As you can see, asus has loaded on the thermal paste and trust me, it is VERY dry. Now comes the "fun" part....
4. Use the small blade to scrape off some (not all) the dry thermal paste on the LOWER chip (the bigger black one). The top of this chip is plastic, so you can apply a very small amount of force to scrape the dry paste off. Once this is done, use a Qtip of paper towel moistened with rubbing alcohol to clean the rest off. Again, you can use some force with the blade, but dont start slicing through the chip. Get as much of it off as you can. This is what mine looked like:
5. This is probably the most difficult part since now you cannot use the blade. The thermal paste on the upper NB is as dry as the stuff you have just scraped off. You might want to grab something to drink becuase this took a while for me. Use the rubbing alcohol and a Qtip to rub all the thermal paste off. This is a bare chip so I would only use some soft object to clean it. What you can do is cut the Qtip in half and use the soft plastic of cardboard stem to GENTLY scrape some paste off.
__________________
to thideras: "If it comes down to it, play shirtless or naked :beer:"
Specs:
- e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
- P5W DH Deluxe Cooling Mod
- 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
- Nvidia 7800gt (490/575) +.1vmod (Upgrading with Crysis & Vista)
- Silverstone ST75F 750watt
- Modded Asus Vento (Black) *pics comming*
Enz himself
enz660 is offline   Reply With Quote
Old 12-24-06, 10:47 PM   #2
enz660
enz660's Avatar
6. Now for the heatsinks! Something I found out about these heatsinks when I nicked one a little and saw a silver shimmer. They are Aluminum, NOT copper. I was so sad But anyways.... use the blade to scrape off most of the dry paste off from the smaller heatsink, then clean it off with rubbing alcohol and a paper towel after. **OPTIONAL** You can take off the asus logo cover to improve airflow through the heatsink.
7. Now for the larger heatpipe heatsink. Do not remove the thermal pads on it, simply clean them off a little and cut a small piece from a plastic bag and cover it up. This will keep them nice and clean until you are finished . Ok, so thats clean, now for the other one. There will be a soft, thin protective layer on the heatsink that prevents it from wobbling that could cause possible damage to the chip. Personally...I removed it, but you can fabricate your own from tape or velcro tape if you really want it back. Clean this heatsink off just as you did the smaller one, scrape the dry paste off and clean it using rubbing alcohol and some paper towel. Again...you can remove the logo plate if you want better airflow OR want to mount a small 40mm fan on top.
I scraped a little to hard and thats when I found out the heatsinks were not copper but copper plated. Since I scratched it too much, I had to lap it .
As you can see...I didnt do a very good lap job, but it was nice and shiny where the chip would be so w/ e.
After all this is done, just put some thermal paste on both chips and remount the heatsinks! I used Zalman STG-1 Super Thermal Grease for mine.
My temps dropped about 5-8c from this mod. Hope your results are as good as mine.
__________________
Specs:
Enz himself
Old 12-24-06, 10:51 PM   #3
nd4spdbh2
nd4spdbh2's Avatar
Send a message via AIM to nd4spdbh2
nice... i have been meaning to take off the SB hs and pop some AS5 on there.... you know what REALLY helps the NB to stay cool... is a small 40mm fan sittin on top of it... heck i have one sitting at 5 volts on top of my P5W DH nb hs... it pushes barley n e air, but with out it temps rise 35*F to 135*F! (this is with AS5 on the hs and a temp prob on the underside of the hs closest to the nb core)
__________________
#12 in the 4ghz core 2 duo club baby! - 52 inches of CRYSIS! - Black Belt Ubercloxx0r -- Heatware
Main -- Lian Li V2000b -- E6600 @ 3.4ghz -- ASUS P5WDH -- 2x2GB Gskill -- GTX260 -- 2x250 GB perps -- Seasonic S12 600w -- Dell 2209WA - eIPS BABY!
HTPC -- Lian Li pc-6070 Silent -- E7200 @ 3.2ghz @ 1.210v -- P35-DS3L -- 2x1GB OCZ 800mhz -- 7600gt KO -- 80gb seagate -- Antec EA 380w -- 52inch Samsung LCD
HTPC2 -- Raidmax Aztec -- E3300 @ 2.5ghz -- Biostar G41 -- 2x1gb GSkill HZ's -- Ati X1300 -- 80Gb Seagate -- Antec EA 430 -- 60in Mitsu DLP
Server -- Antec NSK4480B -- E4300 @ 1.8ghz @ 1.008v -- ECS G33T-M2 -- 2x1gb Crucial 667mhz -- Onboard Vid -- 500Gb hitachi P7K500 + 1TB hatachi -- Zalman 400w
Netbook - Dell Mini 9 - Atom 1.6ghz - 8GB ssd - 2GB pc6400 - WIN 7 PRO!
Need 4 Speed - BH
nd4spdbh2 is offline   Reply With Quote
Old 12-25-06, 06:50 AM   #4
jimmsch
is it necessary to completely remove the heatsinks if I just want to get rid of that stupid cover? It seems to me if I just lose the cover and don't bother with the new paste I might get beter temps just like that.
__________________
Main Rig - E8400@4Ghz (445x9)...4x2gb G Skill DDR2-1000 @ 890mhz...Gigabyte X38-DQ6...Corsair HX620 PSU...MSI HD2600XT 512 Silent ...Hanns-G 19" LCD...X Fi Platinum...2x500gb WD RAID0 - 2x320gb Maxtor RAID0 ...Zalman CNPS9700...Ultra Aluminus (black)...Hanns G 19" LCD 1440x900...Logitech Z5300e speakers...Win 7 Pro x64
HTPC - E8400@3.2Ghz (400x8)...4x2gb G Skill DDR2 1000HZ...Abit IP35 Pro...Corsair HX520 PSU...Sapphire HD3850 Ultimate...Fusion HDTV7 Tuner...Auzentech X-Plosion...2x80gb WD Sata2 RAID0 HDD...Zalman 9500 CPU cooler...LianLi V1000 (black)...Olevia 42" LCD 1080P...Yamaha HT Receiver...JVC 5.1 speakers and sub...Win 7 Pro x64
jimmsch is offline   Reply With Quote
Old 12-25-06, 07:04 AM   #5
Femto
Excellent guide! I vote sticky!
Thanks for this, I mean, I don't have this motherboard...and I probably won't ever get it...but, come on, you get it!
Good job!
__________________
Main - Core 2 Duo e6300 - Asus P5K-E - eVGA 8800GTS 320mb - 2gb G.Skill DDR2-800 - Antec NeoHE 500w - WD 500gb SATA - Lite-on DVD±RW SATA - Heatware
Femto is offline   Reply With Quote
Old 12-25-06, 09:58 AM   #6
enz660
enz660's Avatar
Quote:
you could possibly do that, especially with the South Bridge heatsink. But the NB cover is a little harder to get off, and you might move the heatsink off the chip by mistake. If this happens, you MUST change the thermal paste since the stock one is very dry.
__________________
Specs:
Enz himself
Old 12-25-06, 05:17 PM   #7
Sleepy_Steve
Sleepy_Steve's Avatar
Send a message via AIM to Sleepy_Steve
I think i will preform this mod when i get mine in on wednesday... But after i get an initial temp reading.
I'll do the first tests on air, but i want to see what i can get with a 40mm fan on the NB and the included blower on the other half of the cooler. -- Hopefully doing this will work well with the WC setup im building.
__________________
Main Box: CPU Q9550 @ 3.4 Cooling Ultra 120 w/ 2x108 CFM fan RAM Corsair 4x 1GB DDR2 800 Video Saphire X1950XT
Jet Black: Linux Box / Never ending case mod experiment. Runs an old P4.
"This one goes to ELEVEN"
Sleepy_Steve is offline   Reply With Quote
Old 12-25-06, 05:24 PM   #8
jimmsch
Asus packages the NB cooler fan with a warning strictly stating that it is NOT to be used with air cooling. It is for use with passive or H2O cooling only. They claim it will interfere with the fan cooling the CPU causing irreperable system damage.
__________________
Old 12-25-06, 05:34 PM   #9
Moto7451
Senior Something
Moto7451's Avatar
Possibly it'll harm the CPU's airflow but I doubt it, especially with a TR design cooler. If anything it'll blow a little more through the base of the fins. "Irreparably system damage" sounds silly. They may as well have written "Beware the Northbridge fan of doom!"
So have at it I say .
__________________
Intel C2D e6400 @ 375MHz x8 = 3Ghz 1.328v, Gigabyte EP43-UD3L, 3GB DDR2, GeForce 9600GT, 73GB 15K SCSI HD on an Adaptec 29160 SCSI Card, 750GB SATA Drive, HDTV Tuner
D5 Pump • Bonneville w/ AC Heater Core • Gemeni Cooling Maze 4 Style Water Block
Sager 8690: Core i7 940XM Exreme 2.13GHz (3.2GHz Burst), 4GB DDR3, GeForce GTX 285M 1GB, 15.6" 1080 LCD, 320GB 7200RPM HD
Poor Man's Mountain Mod UFO Project Difference Between D5 Revisions + flow mod Difference between NPSM & G1/4
Moto7451 is offline   Reply With Quote
Old 12-25-06, 05:44 PM   #10
nd4spdbh2
nd4spdbh2's Avatar
problem is the stock nb optional fan clips onto the heatsink up by the ps2 ports... the heatpipe hs over the vregs.... and the heatpipe on thoes boards dont work well at all... so may was well just ad a 40mm fan to the stock nb hs.
__________________
Need 4 Speed - BH
Old 12-25-06, 08:39 PM   #11
jimmsch
Quote:
Are you talking about your core temps as monitored by TAT or core temp? Or do you mean the NB temps themselves? Curious coz I don't know how to check the NB temps.
__________________
Old 12-25-06, 09:19 PM   #12
Sleepy_Steve
I belive it was not a software bassed probe... and that he was using a probe placed beneath the HS right next to the exposed core of the NB.
I would think there was some sort of temp monitor in the bios... And probably another utility to see mobo temps on the driver disk -- But those software probes varry a lot, and its generaly agreed only usefull for comparing +/- deductions of any cooling mods. Because the base temps are often way off of what they really are and the rate at which a real change affects the given reading is also just as inconsistent from board to board, and manufacturer to manufacturer.
__________________
Old 12-25-06, 09:59 PM   #13
enz660
enz660's Avatar
yeah dang...i found out i was looking at the SB temps after I posted this mod... stupid asus board doesnt have a probe for NB.
__________________
Specs:
Enz himself
Old 12-25-06, 10:24 PM   #14
Sleepy_Steve
Hmm, thats good to know i think... Man i wish i had a better temp probe.
__________________
Old 12-25-06, 10:27 PM   #15
nd4spdbh2
nd4spdbh2's Avatar
yup the MB temp is the SB temp... only way to test temps on the NB is to put a probe on it... and believe me a single 40mm fan will drop the temps on the nb a good 35*-40*f
ALSO i dont think you stated n e where that you put some covering over the resistors and capacitators that are present around the NB core... pop some electrical tape around the thing just to be safe because if you look at the stock padding on the bottom of the nb hs you will notice little indentations from them... and that padding stuff isnt thick at all.
__________________
Need 4 Speed - BH
Old 12-25-06, 10:38 PM   #16
PhysX
PhysX's Avatar
this thread is pretty much a rip off of this one check link
http://www.thetechrepository.com/showthread.php?t=19
check post dates...
__________________
Asus P5Q PRO - Scythe Mini-KAZE ULTRA/ NB | Q9400 R0 @ 3.8Ghz 1.24v - CM Hyper 212 Plus | 2x2GB Mushkin Blackline 1066@1141 | eVGA GTX 480 | PCPC 750Watt
PhysX is offline   Reply With Quote
Old 12-25-06, 10:40 PM   #17
enz660
enz660's Avatar
check post dates...
wow
__________________
Specs:
Enz himself
Old 12-26-06, 10:54 AM   #18
nd4spdbh2
nd4spdbh2's Avatar
LOL ... well its a fact the cooling on the p5w isnt great from the factory... but a lil easy moddin and you have great coolign.
__________________
Need 4 Speed - BH
Old 12-26-06, 05:40 PM   #19
tyler_bishop
Banned
tyler_bishop's Avatar
Send a message via ICQ to tyler_bishop Send a message via AIM to tyler_bishop Send a message via MSN to tyler_bishop Send a message via Yahoo to tyler_bishop Send a message via Skype™ to tyler_bishop
So whats this blower thingy that comes with the board?
****STICKY!!****
tyler_bishop is offline   Reply With Quote
Old 12-26-06, 06:07 PM   #20
Jod
Jod's Avatar
I did this too and the damn thing still got way too hot. Jing Ting solved my issue and fit under a Tuniq to boot!
Jod is offline   Reply With Quote
Old 12-26-06, 08:11 PM   #21
nd4spdbh2
nd4spdbh2's Avatar
Quote:
did you ad a 40mm fan to the stock stuff?
__________________
Need 4 Speed - BH
Old 12-26-06, 08:17 PM   #22
xTrEmEoVrClOcKr
member
Send a message via AIM to xTrEmEoVrClOcKr
Nice little guide, I bought an MCX159 by Swiftech, with it's hefty pricetag, it does a hefty job of cooling (Pure copper).
Now that's what I call an aircooling setup
__________________
Budget Build: | Q8200 | Asus P5QL-E | 4GB (2x2GB) GSKILL PC6400 | PowerColor 4830 512MB @ 650 / 1900 |
xTrEmEoVrClOcKr is offline   Reply With Quote
Old 12-26-06, 08:45 PM   #23
Jod
Jod's Avatar
Quote:
W/ 4 dabs of super glue. Still shot plasma balls @ me. Tho I did this on a DS3 and a P5B Deluxe. 975 runs hotter, no? Either way, w/ the Jing Ting on there, it gets warm...like the Tuniq. You wouldn't cool your CPU w/ the stock Intel cooler, would you?
Old 12-27-06, 01:31 PM   #24
PhysX
PhysX's Avatar
isnt copper a...copper color ? that lieks uncopper to me :P
__________________
Old 01-21-07, 04:03 AM   #25
i686
i686's Avatar
Cool simple cooling ...
hi'
I'll receive my mobo in the next few days, I'll just change the south bridge hs by a zalman(you know, the tall blue one), and set a 40mm on the north one and it should be alright, with a bigTT over the E6600, it will coll all this nicely
don't you think that it could be enough?
i686
__________________
PSU : BeQuiet 750w
MB : ASUS P5Q3
CPU : Q9550(E0)/3.6ghz@1.23v
Ram : 8GB OCZ Platinium DDR3 1600 CL7
Hs : Noctua NF + push & pull
Video : Nvidia Gforce GTX 285
Sound : X-FI Xtreme Gamer Fatal1ty Pro
Speakers : Logitech 5:1 X540
Monitor : Viewsonic 28" vx2835wm
OS : Win7 64 + Linux64
i686 is offline   Reply With Quote
Old 01-21-07, 11:33 AM   #26
Drew@PSU
Drew@PSU's Avatar
PhysX: It's definitely copper, I have one, their freaking awesome ( shame I can't use it )
And I think that should be plenty i686, that tall blue one is almost as big as the swiftech one
__________________
.........CPU|Mobo|Vid|Mem|Monitor|PSU|HDD
Main: 920 D0|Rampage II Extreme|XFX 5870|6GB Corsair|Random Widescreen|Corsair HX750|160GB X25 - OC in progress
HTPC: X2 4400+|A8N-SLI|7800GT|2GB Value|Westy 1080p 42" :D|HX 520
Laptop
: Inspiron 13
HEAT Project Infection Project Cataclysm
Ask not what your country can do for you, but what you can do for your country - JFK
Drew@PSU is offline   Reply With Quote
Old 01-21-07, 02:20 PM   #27
enz660
enz660's Avatar
Quote:
Originally Posted by i686
hi'
i686
dont even bother changing the south bridge one..... plus, if you use that zalman, you will block pci & pcie slots. Other than that, it sounds good!
__________________
Specs:
Enz himself
Old 01-22-07, 03:20 AM   #28
i686
i686's Avatar
Cool idea ...
hi'
I thought about the height of the thing ...
and then I thought that an old fan from a P200 should fit perfectly and cool enough, silent enough too
i686
__________________
PSU : BeQuiet 750w
MB : ASUS P5Q3
Old 01-22-07, 11:27 PM   #29
Goshawk
Goshawk's Avatar
Send a message via ICQ to Goshawk Send a message via AIM to Goshawk Send a message via MSN to Goshawk Send a message via Yahoo to Goshawk Send a message via Skype™ to Goshawk
Nice setup!
Rock and Roll! :P
~ Gos
__________________
______________________________
XXXXXXXXXXXXXXXXXXXXXXXXX
|Main Rig:
|XXXXXXXXXXXXXXXXXXXXXXXXX|CPU: i7-980X Gulftown
|XXXXXXXXXXXXXXXXXXXXXXXXX|Cooler: Scythe Ninja2 with LGA1366 Bracket kit
|XXXXXXXXXXXXXXXXXXXXXXXXX|Mobo: Asus P6T Deluxe
|XXXXXXXXXXXXXXXXXXXXXXXXX|RAM: 6gb Kingston KVR1333D3N9
|XXXXXXXXXXXXXXXXXXXXXXXXX|VID: PNY GTX275
|XXXXXXXXXXXXXXXXXXXXXXXXX|PSU: Neo HE 500w
|XXXXXXXXXXXXXXXXXXXXXXXXX|CASE: Antec 902
PDXlan-er - "Sprinkles" on Steam (PM me if you want to add me )
Goshawk is offline   Reply With Quote
Old 01-23-07, 01:03 AM   #30
Sleepy_Steve
Forgot to mention... I did preform this mod when i went from the stock intel cooler to my ultra 120.
Modded the NB w/ AS5 and a 40mm fan. Clearance was VERY tight under the 120. Less than 5mm.
The south bridge was left stock, didnt really see the point.
__________________
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
