- Aug 14, 2007
So I took the ihs off my 165 in an attempt to lower temps. I'm still using the stock Opteron heatsink(copper with heatpipes) to cool it, so I also had to sand down the underside of the motherboard bracket to get good contact and a solid mount on the cpu die. Well, all of that work, and at load it's only like 2-3 degrees cooler. My "hot core" bounces around between 54-56 running Orthos. It was pretty close to that with the ihs still in place.
Does this indicate that the factory hsf can't handle the thermal load? Everything is mounted solid and I know I'm getting good contact with the cpu die because I've checked it several times.
I had read that the factory opteron coolers were "decent" to use when overclocking, but maybe I'm expecting too much. Technically I guess it's working, but I'd like to get the temp down a bit if I can. I'm even undervolting atm and that's not really helping.
