Thread Tools |
#61 |
![]() ![]() ![]() ![]() Member |
ok i just got this board also and i cant figure out for the life of me why my cpu goes from 1700mhz to 2600 mhz according to CPU-Z. can someone please explain what to change in these darn bios or what ever. and is there a guide to the bios around somewhere as its confusing the heck out of me.been use to asus and abit bios. thanks
__________________
1.DFI Lanparty DK P35-T2RS ,intel q6600@3 ghz 375x8, corsair hx620 mod, 2 160 gig sata HD's raid 0, 22" samsung lcd, dvdrw,dvdrom, 1 evga 7800 GT's 470mhz 1100 mhz, Sapphire 4870 ,2x1gig dominator ddr2 1066mhz, coolermaster stacker. If you built it then overclock it!! http://www.heatware.com/eval.php?id=47446 ebay name anothermbdusted |
#62 |
![]() ![]() ![]() ![]() ![]() ![]() Member Join Date: Mar 2005
try disabling C1E - See Genie Bios CPU Features (biosd 1 link pic2 in here:-) DFI LP UT P35-T2R - Mini Living Review This might also be of help. FI BIOS Guide For Intel Chipset Based Motherboards. DFI Lanparty P35/X38/X48 Luck ![]()
__________________
Mobo: Abit IX38 QuadGTCPU: Core2Duo 6600 + WaterMem: Crucial Ballistix PC2-8500 DDR2 2X1GB 5-5-5-15 2.2v Gfx: 320MB BFG 8800GTS OC Clock 580 mem 1700 + Dell 2007WFP PSU: Etasis ET-850 3.3v= 28A 5v=30A 12v=70A SATA Hitachi II 4x80Gb Raid 0 + 250gb+320GB OS WinXPPro SP2 + Vista RC2 32 +64 Case: Lian-Li V2000B Plus OC 8x470@1:1.20 =DDR2 1128 @5,5,5,10 2.175v Some people believe football is a matter of life and death,it is much, more important than that - Bil Shankly |
#63 |
OH BOY!thanks alot for that it explains exactly what the functions are and also found another page that explains what to do to OC it better in the options lol http://www.clunk.org.uk/forums/overc...s-dfi-add.html thanks again supershanks big time
__________________
#64 |
![]() Registered Join Date: Apr 2008
I got quite a few questions and am hoping somebody here can help me. The cpu I'm using is a q6600 and the board is the DFI LP LT P35 - When I do Prime testing, the PWM temp goes to 58C and the chipset temp goes to 54C, what is the suggested safe operating temperature for these two areas? I know people have said up to 100C but I think that is a little crazy, the entire system would be cooking. Also where exactly is the PWM in case I want to put a fan on it to cool it down? - I set the value to 1.2875v in BIOS, but CPU-Z reads it as 1.311v at idle and 1.280 during Prime testing (due to vdroop). How can I get CPU-Z to read it as 1.2875v? - Some people have Thermal Management Control and Vdroop Control enabled while others have it disabled when overclocking. Why would you want to turn off those options? I thought TMC gives more accurate temp readings and vdroop prevents loss of voltage when the cpu is under load. Thanks for the help! |
| Thread Tools | |
