- Jan 29, 2002
- The Big Brother Nation
It could be that VISTA is just currupt and busted and needs reinstalled any one seen anything like this?
windows Vista has decided that it can't load my roaming profile, I have fixed a load of errors
to some of the wired-est
"Folder redirection policy application has been delayed until the next logon because the group policy logon optimization is in effect."
now all thats left is ^^ this ^^ at log off.
also DEP keeps killing steam, but only when (and its not often) its able to connect to the servers.
Code:
Failed to apply policy and redirect folder "Favorites" to "\\ymir\admins_shared_folder\profile.V2\Favorites".
Redirection options=80001211.
The following error occurred: "Can not create folder "\\ymir\admins_shared_folder\profile.V2\Favorites"".
Error details: "This security ID may not be assigned as the owner of this object.
Code:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
1 user registry handles leaked from \Registry\User\S-1-5-21-423062555-351975647-281627667-1117_Classes:
Process 224 (\Device\HarddiskVolume1\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-423062555-351975647-281627667-1117_CLASSES
DETAIL -
Process 1000 (\Device\HarddiskVolume1\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-423062555-351975647-281627667-1117_CLASSES
