- Sep 4, 2007
I got installed my new Q6600 along with my new ram and motherboard. I had a little trouble installing the heatsink so I kinda broke my Freezer 7 pro so I put on the stock heatsink. The temps ran at like 72C at idle (not sure if it is accurate I hadn't installed any motherboard drivers yet) so I took it off and installed the freezer 7 pro. Here are my temps.
I think the reason my temps are so high is because there isn't really any thermal compound on the CPU. When trying to put on my Freezer 7 pro I screwed up so I wiped it all off and then put on the stock heatsink which got its compound on it. So then I put back on the freezer 7 pro so it has kind of a mix of both that isn't really spread good
So if I buy some thermal compound and put it on right should the temps go down to what other people are getting? like 30C at idle and maybe 60C at load. Mine are around 45C at idle
