Notices
Overclockers Forums > Hardware > Video Cards > AMD (ATI) GPUs
AMD (ATI) GPUs
Forum Jump
The HD 4870/50 Thread
Thread Tools
Old 07-08-08, 12:24 AM   #61
keninishna
I did the vmod and I should have 1.36v under load I don't know how people are measuring the voltage but it seems to be working and temps seem to be ok no artifacts but if I go over 860 I get them. I'll probably go up to 1.41 volts tomarrow and see if I can hit 900+ on core. I modded the bios of the card but only to regulate the fan and Im using amdgpu tool to set the clocks.
keninishna is offline   QUOTE Thanks
Old 07-08-08, 04:18 AM   #62
nockawa
Is a 500W Alim enough for two 4850 ?
Hello guys,
I already have one 4850, and I'd like to get another one in crossfire, but I'm wondering if my PSU will be able to handle everything inside my rig.
The PSU I have is a Antec's EarthWatts 500W. You can see in my signature the rig description (mainly Q6600 G0 and 4 HDDs)...
Thanks for the advices!
nockawa is offline   QUOTE Thanks
Old 07-08-08, 05:10 AM   #63
reznik
reznik's Avatar
KENINISHNA
hats off to you mate thats awsome...hmm i wouldnt mind trying to push up my oc but how safe is the modding? did u stress test it under those speeds?
reznik is offline   QUOTE Thanks
Old 07-08-08, 06:25 AM   #64
Super Nade
† SU(3) Moderator †
Super Nade's Avatar
Quote:
Originally Posted by nockawa View Post
Hello guys,
It may turn on and run, but I would not feel comfortable to suggest it for X-Fire. I'd recommend a minimum 600W unit (a good one at that). Post a thread in the power supply forum and we can take it from there.
Quote:
ken, is it a pencil mod or a hard mod? How are you reading VCore? Does any software read it accurately?
Quote:
Originally Posted by reznik View Post
KENINISHNA
You will have to bump you fan speed up > 50% if you push the clocks. Also, VMods are never really completely "safe"
__________________
Motherboard Repair Tutorial || Power Supply Repair Tutorial || A Closer Look at PSU Signals ||
Understanding SMPS Technology
|| ASUS P5K Capacitor mod || Kernel Compile Guide || Guide to Wiping an SSD
Words of wisdom from krag:
"Love & trust are 2 completely different things. Trust is earned, love on the other hand should be given without measure."
My hwbot profile
Super Nade is offline Author Profile   QUOTE Thanks
Old 07-08-08, 10:40 AM   #65
keninishna
KENINISHNA
I only tested it for a few hours last night no real stress testing other than a couple vantage runs. the voltmod seems safe enough I hear though that the voltage regulators on the card can get hot and shut it down and putting some heatsinks on them helps. Temps on the core aren't bad though around 60c load with fan at 52%.
Its a hard mod I just soldered 3 10 ohm resistors together. I don't know how to read vcore at the moment which is really dangerous but temps are ok so im not worried right now but as soon as I figure it out I'll tell you the actual voltage.
As for pencil mod the 4870 requires only about 20-30 ohms which is waay too low to pencil I feel much safer with just 2-3 resistors soldered onto the board. I guess its safe someone at XS allready killed a card but the guy used a 50k variable resistor and turned it all the way down to like 10 ohms which is just baad. As long as your soldering skills aren't terrible its not a hard mod to do.
Old 07-09-08, 01:39 PM   #66
keninishna
I lowered the ohms to 20 and I was able to raise the clock an additional 10 mhz to 870 however I'm still not able to get an accurate voltage reading but heat is still pretty good. I'm thinking the 30 gauge kynar wire I used for the mod might be too small. I also played crysis on v high with x4 aa last night for about an hour and half with no problems some minor memory artifacts I might pencil mod my memory to make it more stable. The drivers though keep bugging out at first crysis would play for about 2 seconds then the drivers would crash so I upgraded to the 8.7 beta drivers and that worked until I rebooted now they crash crysis 3dmark 06 when I upgraded the drivers got me around 11,000 points so I rebooted and now the drivers crash and I can't complete the bench but for some reason vantage runs fine at any given time. I'll try driver cleaner and reinstall the hotfix drivers later today to see if that fixes it other than that this card is sick I couldent play crysis at those settings with a gx2.
Old 07-09-08, 03:34 PM   #67
mgoode
mgoode's Avatar
I got a second card from a canadian site for 245.00 shipped
1 Visontek 4870and 1 Saphire 4870 in crossfire, both cards at 790/1100 stock volt and stock cooling.
__________________
Benching: 980X
"Behold, I am Funkadelic. I am not of your world. But fear me not, I will do you no harm. Loan me your funky mind and I shall play with it. For nothing is good unless you play with it. And all that is good, is nasty!"
("What Is Soul," Funkadelic, 1969)
mgoode is offline   QUOTE Thanks
Old 07-09-08, 05:34 PM   #68
reznik
reznik's Avatar
u didnt, man thats cyco hmm 2 4870's i wanna buy a second one to now
Old 07-09-08, 10:10 PM Thread Starter   #69
HousERaT
Senior Air Extraordinaire
HousERaT's Avatar
4850s have been received. Testing now. ;-)
Fan at 50% is quiet.
__________________
CM-690 | Maximus Formula | Ballistix D9GMH 2GB - 4-4-4-10 - 2.2v (active cooled) | E6850 @4GHz (L719B) 602 Bios 500x8 - 1.475v | Ultra 120 Extreme | 2x HD3870 840/1300 | Lite-On 52327s CDRW | WD 74GB - Raptor HDD | Corsair 620HX PSU | Windows XP Pro sp2 |
Support the OC Benchmarking Team The HD 4870/50 Thread The HD 3870/50 Thread The X1900XT/XTX Thread X800GTO² Thread Heatware
Make friends with your "FAST" - 90K 01SE - 77K 03 - 29K 05 - 19K 06 - 274K AM3 - single card all air baby!
HousERaT is offline   QUOTE Thanks
Old 07-10-08, 02:08 AM   #70
nockawa
Well, after some research it ends out that my rig would pump something like 19.5A on the V12_1 line of the power supply, which is more than the 17A mentionned by the manufacturer. The 500W should be enough though...
I think I will pull back and keep only one card, this is the safest way, and it's enough to run any kind of games...
Old 07-10-08, 04:53 AM   #71
vixro
vixro's Avatar
This is slightly off topic, but still a little on topic.
http://www.ocforums.com/showthread.php?t=568842
I laughed so hard at the first line. I wonder if he realizes the GX2 is outperforming the GTX 280 in like, everything. xD
Aren't you all GLAD YOU BOUGHT 4850/4870's now?!
__________________
Intel i7-2600K @ 45x100 (4.5ghz) 1.36v
G.Skill Ripjaw Z 4x4GB 2134mhz @ DDR3-1068 9-11-10-27-2T - 1.65v
ASRock Z68 Extreme4 1.70
Gigabyte GTX 680 2GB @ 1250mhz / 7030mhz
Auzen X-Fi Prelude 7.1 on Cardas recabled HD580
Little Dot MKIII Headphone Amplifier (Cardas mini-RCA IC)
Silverstone DA750 750w PSU
heatware
vixro is offline   QUOTE Thanks
Old 07-10-08, 10:58 PM Thread Starter   #72
HousERaT
HousERaT's Avatar
Just getting started.
__________________
Old 07-11-08, 12:24 PM   #73
reznik
reznik's Avatar
ahahha 30k + that is sum mad skillz rite there, what about higher rez?..makes me wanna buy a water cooling kit and clock my quad to 4gig cee what scores i can muster up good job!
Old 07-11-08, 04:12 PM   #74
SuperDave1685
SuperDave1685's Avatar
10 Year Badge
Damn Houserat..... Nice clocks on that Duallie... and 30K to boot!! Good job!
__________________
ლ(ಠ益ಠლ)
*Main Rig-*i7 920 D0 @ 4.2Ghz (1.17v), ASUS Rampage II Extreme, 12 GB Patriot DDR3 1600, ATI HD5970 @ 775/1100, SB X-Fi Xtreme Gamer, OCZ Revo X2 Drive SSD, 500GB, 1TB SATA, PCP&C Silencer 750W , D5 pump, Thermochill PA 120.3 w/ 3 Yate Loon Mediums, Swiftech Apogee XT, Lian-Li PC-G75, ASUS VW226H 25.5", Logitech Z-5300e THX 5.1 Speakers
My Massive PC Cleaning Thread!
Heatware |
If the Army and the Navy Ever look on Heaven's scenes, They will find the streets are guarded By United States Marines. OoRah!
SuperDave1685 is offline   QUOTE Thanks
Old 07-11-08, 04:22 PM   #75
Parad0x420
Parad0x420's Avatar
hope you both noticed he's showing that score from 3D Mark 05.. but thats still a damn high score anyways, nice work HR
__________________
Phenom II X6 1075T Thuban @ 4125 15 x 275 1.439v LLC enabled
TRUE Black Rev. C - Shin-Etsu X23-7783D - CM R4 Reds push/pull
ASUS Crosshair IV Formula AM3 890FX NB@2750Mhz HT@2200Mhz
G.Skill Flare 4GB DDR3 @ 1833Mhz 7-8-7-24-1T 1.65v
ASUS 7970 3GB @ 1000/1200
OCZ Vertex 4 256GB SATAIII - Win 7 Ultimate x64
2x WD 640GB Caviar Blue / 2x WD 750GB Caviar Black
PCP&C 750W Silencer Black
Samsung Syncmaster 2493HM 24" @ 1920x1200
Corsair Obsidian 700D
Dêck Legend Toxic
3DMark06 - 23491 - Vantage - P18580
- Vantage X8757
Parad0x420 is offline   QUOTE Thanks
Old 07-11-08, 04:26 PM Thread Starter   #76
HousERaT
HousERaT's Avatar
Quote:
Nobody is gonna hit 30K in 06 using these cards without LN2 on everything including the power supply, monitor, keyboard and mouse.
__________________
Old 07-11-08, 04:45 PM   #77
El<(')>Maxi
Blank Senior Member
El<(')>Maxi's Avatar
The wire size doesn't matter on a FB mod such as this, there's no real current flowing thru it
Quote:
Nice!
Quote:
What are you waiting for?
__________________
rdrash - 'I'm gonna intentionally try to kill this CPU with more volts'
El<(')>Maxi is offline Author Profile   QUOTE Thanks
Old 07-11-08, 05:52 PM   #78
reznik
reznik's Avatar
AHAHAHH 3d mark 05 got me there howbout 06 and vantage?
Old 07-11-08, 08:26 PM Thread Starter   #79
HousERaT
HousERaT's Avatar
Just changed cooling on my hot card to a Duorb and -10°C. Was idling at 42°C and now at 32°C.
__________________
Old 07-12-08, 07:44 AM   #80
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
The wall of fame staff are pic mongers.
Good start though.
@Supertrucker: what brand card are you using?
Having some trouble with 3DMark03 ATM...but will get a better pic up soon.
__________________
THE POST COUNTER IS NOT AN INTELLIGENCE METER!
Intel i3, i5 and i7 Overclocking Guides
Heat "Water & Wood" computer desk build log My HWBOT Profile
MAX11Lv3 - "It kind of reminds me of going to the circus and seeing a mini drive around and then 83 clowns jump out of it!" - ollien33
i7 3820 @ 5GHz || 32GB G.SKILL @ DDR3-2000 || GTX580 tri-SLI || Corsair AX1200 || Custom water cooling
MIAHALLEN is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
AMD (ATI) GPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
