- Jun 29, 2004
- 30°3′15″N, 95°23′13″W
I never really thought to check my core clocks on the 9800 GTX's and I guess never paid attention to 3Dmark specs, but I fired up GPUZ and my cores are clocked a different speeds as well as their DDR3 respectively.
1st 9800 GTX = 700MHz
2nd 9800 GTX = 675Mhz
These are the same model and revision bought on the same day. BIOS versions are indicated differently. I dont plan on OCing these at this time since I will inevitably be stepping up, but is this common? Didn't find much with my search terms in the forum.
Model is 512-P3-N871-FR you will notice an FR as opposed to an AR in the model sequence. This is because at the time this card was made exclusively for Fry's. It almost looks like they mis-labeled a 512-P3-N872-AR (9800 GTX SC)
