Notices
Overclockers Forums > Hardware > Video Cards > AMD (ATI) GPUs
AMD (ATI) GPUs
Forum Jump
New To CrossFire, Not sure it's working
Thread Tools
Old 08-27-08, 09:29 PM   #21
killuazaoldyeck
killuazaoldyeck's Avatar
for the power supply issue heres the link, recommended psu for crossfire
http://game.amd.com/us-en/crossfirex...nents.aspx?p=3
and after uninstalling use driver cleaner pro to delete all the old files. then restart then reinstall
killuazaoldyeck is offline   QUOTE Thanks
Old 08-28-08, 12:15 AM Thread Starter   #22
Digital_Cowboy
Digital_Cowboy's Avatar
Ok, here's the deal. I called Gigabyte to try to resolve this Overclocking issue with my cheap ram. They told me "The Cpu speed controls the RAM speed, so when one goes up, so does the other. There is no way to lock the RAM at stock speeds and only bump up the CPU." I told her that I had cheap ram and she said that I need to upgrade.
SOOO, I bit the bullet today and picked up 4gb of Corsair Dominator pc8500 DDR2 at Directron.com (I live in houston, so I picked it up at will call) and installed it this evening. It wasn't as easy as just adding in the DIMMs as I have the Zalman DuOrb Air cooler. I had to remove my mobo to re-orient the Zalman to where I could add the RAM with the cooling fan block. I started the computer and was Immediately able to OC it to 2.66GHZ. I ran Prime95 for a while with it at this speed and then OC'd it to 2.80GHZ where it is now. The RAM is running at 2.1V and the CPU is at 1.28V. It's stable through Prime95 for as long as i let it go (1hr) and Here are my new scores.
3dmark 05 - 19052
3dmark 06 - 15616
So that's better than what it was by a pretty good margin. Do those numbers seem right for my specs in crossfire?
Steve
__________________
Core I7 970 @ 3.6GHZ | Asus Rampage III Formula | 12GB Patriot DDR3 | EVGA GTX 580 SC | OCZ Revodrive X2 240GB | PCP&C Silencer 940 | Hyper 212+
Core 2 Quad Q6600 @ 3.0GHZ | Gigabyte X38-DQ6 | 8GB DDR2 | 2 x ATI 4870 1gb in Crossfire | 2 x 2tb | PCP&C 940 Silencer | Cooler Master Cosmos | hyper 212+
Digital_Cowboy is offline   QUOTE Thanks
Old 08-28-08, 12:19 AM   #23
updawg
StarCraft II Fanatic
updawg's Avatar
I'd expect more, but it could be the cpu holding you back. I just break the 13k in 06 mark with an e8200 @ 3.8 and a single 4850.
updawg is offline Heatware Profile   QUOTE Thanks
Old 08-28-08, 12:27 AM   #24
vixro
vixro's Avatar
You can already tell that it's CPU limited now, because it went up by 2,000 points with a modest overclock. You can OC that chip pretty easily to 3.2-3.4 and maybe even 3.6 with some voltage adjustments.
The rep telling you that when you overclock the CPU, you overclock the ram (and that you have no choice) was wrong. You have dividers for overclocking the CPU without overclocking the RAM. If you don't change the divider and keep it at 1:1 then yea, overclocking the CPU also overclocks the RAM. But when you use dividers you can keep your RAM near a general area and adjust timings so that no matter what FSB you're at, your RAM can be running within its limits without holding back the CPU too much. That's the whole point.
__________________
Intel i7-2600K @ 45x100 (4.5ghz) 1.36v
G.Skill Ripjaw Z 4x4GB 2134mhz @ DDR3-1068 9-11-10-27-2T - 1.65v
ASRock Z68 Extreme4 1.70
Gigabyte GTX 680 2GB @ 1250mhz / 7030mhz
Auzen X-Fi Prelude 7.1 on Cardas recabled HD580
Little Dot MKIII Headphone Amplifier (Cardas mini-RCA IC)
Silverstone DA750 750w PSU
heatware
vixro is offline   QUOTE Thanks
Old 08-28-08, 11:26 PM Thread Starter   #25
Digital_Cowboy
Upped the CPU to 3.0ghz now and it's running stable. Ram is running at 1066. 3dmark 05 score is now 20296
__________________
AMD (ATI) GPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
