ASUS M2N32-SLI Deluxe+AMD 6400: Updated BIOS to 2101 from 0903, only black screen, Yu
Dear experts in this forum,
Last nite I decided that I should try to update the BIOS on the MB due to stability issue. So I downloaded the latest BIOS 2101, backuped 0903 and use the latest Asus Update utility (v.7.1304) to update the BIOS in Windows XP. Everything seems to work fine: the BIOS was successfully flushed, updated and CHECKSUM went ok and the computer asked for a reboot. So I did, and then all I was staring at was a black screen, no BIOS screen and since I don't have case speaker, no post to tell.
Can anyone give me some advices on what I should do next? This is the first time I update the BIOS (in after thought, I should have updated the video card and other devices drivers first).
I read from the user manual that I might be able to restore the BIOS from the MB Support Disk. I also read from some forums that I might be able to get the computer to boot by resetting the CMOS.
So my questions are:
1. Can you let me know what I should do?
2. What is the best BIOS version for 6400 CPU?
Below is my computer's configuration (laundry list):
* ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard
* AMD Athlon 64 X2 6400+ Windsor 3.2GHz Socket AM2 Processor Model ADX6400CZWOF
* Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
* Rosewill Stallion Series RD500-2DB ATX V2.2 500W Power Supply
* Zalman CNPS9700LED Ultra Quiet CPU Cooler
* Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804 (4-4-4-12 2.2Volts)
* OCZ 2GB ( 2 X 1GB ) Platinum PC2-6400 800MHz 240-pin DDR2 Memory - OCZ2P800R22GK (CL 4-4-4-15, 1.9 - 2.0 Volts)
* XFX PVT84GUDF3 GeForce 8600GTS 256MB 128-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
* Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
* LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache IDE 20X DVD�0„3�0†8R DVD Burner
* Rosewill RCR-102 52-in-1 USB 2.0 Black Card Reader
* Arctic Silver 5
Thanks in advaced.
* Arctic Silver 5
Thanks in advaced.
