Notices
Overclockers Forums > Hardware > Motherboards > Intel Motherboards
Intel Motherboards
Forum Jump
Gigabyte EP45-UD3P
Thread Tools
Old 01-09-09, 05:05 PM   #161
skoreanime
Hmmm, perhaps I'll give it some more time in Prime95. Maybe it needs a break in period or something lol
skoreanime is offline   QUOTE Thanks
Overclockers Approved
Which motherboard should you buy? Get the final word here. Check out the latest Overclockers reviews:
ASRock Z77 OC Formula Motherboard Review
ASRock teamed up with overclocker Nick Shih to make a high-end overclocking-based, yet functional for all users, motherboard named the Z77 OC Formula. It appears they have achieved it. Read More.
Get it at NewEgg for $239.99
ASUS Maximus V Formula Motherboard
The Maximus V Formula is part of the ROG (Republic of Gamers) series of motherboards, which in itself brings a high level of expectation. It's a no brainer, Overclockers Approved! Read more.
Get it at NewEgg for $279.99
Old 01-09-09, 07:26 PM   #162
ghost_recon88
Senior Jedi Master
Premium Member #9
ghost_recon88's Avatar
I can't understand this board :shakes: It's constantly running my Q9550 quite a bit hotter then my TPower I45 did. On this board, at stock clocks (2.83GHz) I'm hitting 48c. I know on the TPower I had the CPU GTL ref at .63x, and on this board it defaults at .76x. Could that be the difference? I've reapplied thermalpaste and reseated my TRUE several times.
TPower I45
EP45-UD3P
__________________
The will to live will always outweigh the ability to die
ghost_recon88 is offline Benching Profile Heatware Profile   QUOTE Thanks
Old 01-09-09, 07:42 PM   #163
Steven-1979
4ghz @ 1.22v ... NICE! It's not .76x it's .76 ... if you're running 1.2 VTT thats about .63x
__________________
- How to pad-mod/VID-mod your cpu
Currently waiting for lga2011 to upgrade to new system
CPU: Intel E8500
Motherboard: GIGABYTE GA-EP45-UD3P
RAM: 4gb Corsair Dominator DDR2 1066 w/ RAM cooling fan
Cooling: CPU/GPU/NB = Water Cooled
Graphics: EVGA GeForce GTX 260 core 216 (@ 771/1566/1298)
PSU: Corsair tx 650w
Steven-1979 is offline   QUOTE Thanks
Old 01-09-09, 08:27 PM   #164
ghost_recon88
Senior Jedi Master
Premium Member #9
Quote:
So you're saying if I'm running 1.2 VTT and I have it set to .76, that could create the extra heat problems?
__________________
Old 01-09-09, 08:55 PM   #165
Steven-1979
I mean it's the same thing, .63x of 1.2v VTT is 0.76v ... the gigabyte mobo just lets you set it directly without dealing with ratios. 0.63(1.2v) = 0.76v
__________________
CPU: Intel E8500
Old 01-09-09, 09:00 PM   #166
ghost_recon88
Senior Jedi Master
Premium Member #9
Ah OK. If I can't get this thing figured out soon, I'm just gonna pwn it off and use a special i7.
__________________
Old 01-09-09, 09:28 PM   #167
Steven-1979
What temps are you getting on this mobo at the 4.007 settings?
__________________
CPU: Intel E8500
Old 01-10-09, 04:13 PM   #168
ghost_recon88
Senior Jedi Master
Premium Member #9
I have it figured out. My CPU VTT and PLL were set too high.
It ran a couple hours P95 stable. Now I'm at 1.24 VTT and 1.45 PLL.
__________________
Old 01-10-09, 04:28 PM   #169
Rattle
Rattle's Avatar
I usually loath gigacrap mobos, grabbed the ud3p out of desperation at a local microcenter after my x48 died. thing is awesome lol, went up to 538 now test it over night, here 525
1.22 vtt and 1.26 NB,
tried all the way up to 550 with same volts, neeeds work still, fun little mobo tho.
__________________
M5G | 2600k @ 4.5 | H100 | 16gb Sammy 30nm 1866 | GTX680 Sig SC | Xonar Essence Stx | 550d | 900w HCG | VG24QE | 120forceGT | 640black | 2tb | CherryReds | m60 | Func1030 |
HEAT
Rattle is offline   QUOTE Thanks
Old 01-10-09, 10:42 PM   #170
ghost_recon88
Senior Jedi Master
Premium Member #9
Alright I can get into Windows with my Q9550 @ 4250MHz (8.5x500) no problem, however its only P95 stable for about a minute. It doesn't hardlock or reboot, it ether closes the P95 app automatictly or just says the threads failed. Here are my settings. Any obvious settings I should change other than vcore? For the GTL refs I multiplied CPU VTT and MCH voltage by .63 each.
__________________
Old 01-11-09, 10:52 AM   #171
harlam357
Senior Fold-a-holic
harlam357's Avatar
Hey guys... great thread! I just picked up this board recently and have been playing with different memory since. Wasn't having too much luck clocking the memory I tried (Corsair C4 v2.1 & G.Skill 1000s) but then I found a set of older Ballistix 800 in a Folding rig, and it appears to be some flavor of D9. I almost had it to DDR1200 (using a Q9550)... I'm mainly a Folder, not an extreme OC'er... so that's something to say for me.
Any recommendations on the best BIOS version? The board came with F5 and that's what I've stuck with so far.
Edit: Oh ya, any recommendations on a 2x2GB 1066 Kit for this board? I'm browsing the Egg as I type.
harlam357 is offline Folding Profile Heatware Profile   QUOTE Thanks
Old 01-11-09, 11:11 AM   #172
TimoneX
TimoneX's Avatar
10 Year Badge
I've had best luck with F6d.
__________________
Giga UD3Rv2 - i7 970 - 4x4GB DDR3 - MSI 6950-6970 - Adaptec 3085 - 2x64GB M4 SSD R0 - 4x1TB Sammy F3 - DD TDX - Ultra X3 800
Heat under TimoneX - Bitcoin 1Hfp99tugY4H5FYEoM3hj4JDLzShzZ9ifB
TimoneX is offline   QUOTE Thanks
Old 01-11-09, 03:24 PM   #173
harlam357
Senior Fold-a-holic
harlam357's Avatar
Quote:
Got a link? All I've been able to find is the F7b.
http://www.fileden.com/files/2008/7/...45ud3p.F7b.rar
Quote:
Looking at these kits:
http://www.newegg.com/Product/Produc...82E16820231166
http://www.newegg.com/Product/Produc...82E16820227289
http://www.newegg.com/Product/Produc...82E16820145214
Old 01-11-09, 06:08 PM   #174
Rattle
Rattle's Avatar
they should all be the same
i am using the dominators myself
update 538x8 4300mhz
1.26NB and 1.22vtt still
__________________
HEAT
Old 01-11-09, 08:20 PM   #175
Axis
Axis's Avatar
I heard that there will be a new revision for this board... like v1.1 and it will address all of the high voltages needed on the vmch, pll and vtt for quads @ 500 fsb.
Anyone else hear this?
Axis is offline   QUOTE Thanks
Old 01-12-09, 12:26 AM   #176
TimoneX
TimoneX's Avatar
10 Year Badge
But of course...
http://www.fileden.com/files/2008/7/...2/ep45ud3p.f6d
__________________
Old 01-12-09, 11:54 PM   #177
LilBuddy
LilBuddy's Avatar
So is this the best $110 board out right now? I want something with RAID I think and I'm tired of my Abit IP35-E.
__________________
Intel E8400 @ 4005 (445x9 @ 1.37v) - Gigabyte EP45-UD3P - 2x1gb Crucial Ballistix PC8500 - 2x36gb Raptor in RAID 0 - 640gb WD Black - EVGA 8800GT (730/1700/2060) - Antec 900 - Seasonic M12 700W
AMD 3600+ Brisbane - Abit NF-M2 Nview
P4 2.8C @ 3094 - ECS PT880 NEO MB - ATI 9800 Pro
AMD 1700+ @ 2272 - Epox 8RGA+
AMD T-Bird 1400 @ 1650
LilBuddy is offline   QUOTE Thanks
Old 01-13-09, 01:47 AM   #178
Rattle
Rattle's Avatar
i would take this over the most expensive asus p45's
never thought i would say it....
__________________
HEAT
Old 01-13-09, 02:02 AM   #179
TimoneX
TimoneX's Avatar
10 Year Badge
Yep. Definitely a tremendous value.
__________________
Old 01-13-09, 02:13 AM   #180
Rattle
Rattle's Avatar
mine was bought as an emergency backup, my x48 blew up and killed my 4870's lmao
was friday after christmas. I checked loacal microcenter stock all they had that was close was this giga. Drove out 45 minutes brought it home. Starting reading about it on here and XS. Started clocking it and it is the best clocking mobo I have ever had hands down. It does 550 at less volts then my best ones did 500 at.... ohh and I hated the p5q deluxe asus mobo
__________________
HEAT
Tags
ep45-ud3p, ud3p
Intel Motherboards
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
