Go Back   Overclockers Forums > Hardware > CPUs > Intel CPUs > Overclocking the Q8200
Reply
Thread Tools
Old 08-26-09, 02:13 AM   #151
thenamejohn
help
I am new to overclocking and want supervision before i start going any farther then this. Is the proper thing to do here to start my own Q8200 thread or do I just add to this?
Im going to post pictures of my bios and screenshots very soon along with a detailed description of my situation. I just want to know if I am going to start in the right place.
Antec900
Vista 32
MSI MS-7380 nforce 750i sli spp Rev A2 Bios v02.61
intel Q8200 @2.333 stock w/Thermaltake Big Typhoon air cool
GTX 275 oc
Buffalo Firestix PC2=6400 2gbx2 800Mhz @ 4-4-4-12-2t
please get me started
thenamejohn is offline   Reply With Quote
Old 08-26-09, 02:47 AM   #152
turbohans
turbohans's Avatar
Antec900
Vista 32
GTX 275 oc
you can make yourown thread if you feel the need too.
I notice in your sig you have a Nvidia chipset and 800mhz ram,, you might wanna look around and see what the highest FSB anyone has gotten stable with that motherboard first because the Q8200's low multi will need all you can get. also for a good OC you will need to be able to get your ram to around ~900mhz.
__________________
Intel and Nvidia, the way it's ment to be OC'd
Q8200@3.5ghz, Corsair-pc6400@1000mhz6-6-6-20,
Asus P5Q@500fsb, 3xSeagate Baracuda in Raid 0,
Nvidia 9800gt, Antec550w psu, Lian Li case,
Linksys WRT54GL & EZXS55W, HP dv2950,
42" 19" & 2x15" LCD's
turbohans is offline   Reply With Quote
Old 08-30-09, 04:18 AM   #153
kick
Hey Samsave
Yeh 490 fsb I can get down to 1.325 cpu V in bios (1.31 under load) with pl 9 on memory and 2.08v memory in bios
500fsb needs 1.41 cpu (1.39) under load 2.22v mem(2.19 under load) to hold pl 9 for 9Gb/s read bandwidth (10 Gb/s copy and write).
pll V and Cpu term V at those speeds left on auto goes to 1.85V and 1.7v!!
set manually pll 1.57-1.59V and vTt at just around cpu v in bios seems to be ok.
cpu and mch ref around 70%.
mch 1.38 -1.42.
__________________
Gigabyte EP-45 UD3 bios F8
Q8400 4.0Ghz cpu (Q8200 3.5Ghz)
1000mhz 4gb GSkill Black PI 6400(800mhz)
Coolermaster V8
vlts in bios:cpu 1.39375(1.360 cpuz),memory2.2,mch 1.42
memory "turbo" pl 9
temps:(14hr prime 500fsb)core0 69*,sys 38*,nb 36*
Jeantech 500w psu
9600 gt 512ddr3(10% o/c)
1TB WD HDD
Vista 64 premium sp2
kick is offline   Reply With Quote
Old 08-30-09, 11:18 AM   #154
ArcturusVi
Send a message via AIM to ArcturusVi Send a message via Skype™ to ArcturusVi
I currently have my Q8200 at 3.15GHz at 1.2 BIOS Voltage. Prime95 stable after 24 hours. G.Skill Memory set to manual, factory settings at 1088mhz. Locked my PCI-e bus at 100mhz for stability, and will keep it that way until I get a high enough OC that I am comfortable with.
My board is a Gigabyte EP45-UD3P. I am keeping the N/S Bridges at auto for voltage. Temps seem to be fine, as far as I can tell.
Seems like a pretty easy chip to overclock once you set a couple things to manual and leave them there. When my memory timing and multiplier were set to Auto, I would get some rough restart loops, and forget about Prime95.
ArcturusVi is online now   Reply With Quote
Old 08-30-09, 08:10 PM   #155
kick
So what do we have here.
Q8200 will clock to 3.5ghz from 2.3 which is a 50% speed increase.
This is just about the same as all other 45nm 775 quad coreswith intel chipsets.
Assuming you have a decent mbrd/decent air cooling and mem that will do 1000mhz
490 fsb/3.43 ghz will need 1.3v-1.35v for stability .
500fsb/3.5ghz will need 1.35-1.4v for stability
510fsb/3.57ghz will need 1.4-1.45 for stability and things can get v hot.
above 510/2040 fsb it doesnt seem worth trying to blow up yer cpu or corrupt data.
Below 490/1960 fsb u can probably get away with much lower voltages.
I think ill settle on 490 fsb for the rest of the cpu's lifetime(mines almost a year old now).
cpu speed>fsb speed>memory speed.
__________________
Coolermaster V8
memory "turbo" pl 9
Jeantech 500w psu
1TB WD HDD
Old 08-31-09, 09:17 AM   #156
ArcturusVi
Got it to 3.5GHZ stable. That's all the faster I need or feel comfortable trying.
Old 09-11-09, 08:20 PM   #157
kdawgmaster
Quote:
Originally Posted by SamSaveMax View Post
My P35 board didn't play well with Quad. So I changed to a P45 board which I think is a mate for it.....and a newer Cooler Master Hyper Z600R to handle the heat.
I got up to 500FSB but passed only 2 hrs with P95 small FFTs
@ 486FSB = OK P95 small FFTs 6 hrs but had problem FREEZING with OCCT Mix
Finally, I settled at 3.36GHz @ 480FSB with a nice low Vcore with decent temperature.
Very tight fit.
which is ur mobo and what PSU and ram do u have because i cant get my Q8200 past 3.32 without problems
kdawgmaster is offline   Reply With Quote
Old 09-11-09, 08:31 PM   #158
Evilsizer
Senior Member
Evilsizer's Avatar
Quote:
well the ram/mobo is in the first screen shot you quoted... the psu looks like some cheap one from dynex.
__________________
i7 920@3.6ghz | Asus R2G | OCZ3P1333LV3GK | C650TX | OCZ AGILITY 60gig(x2 in raid-0)
E7200@3.8ghz | Abit IP350-Pro | 4x1gig G.skill DDR2-800 HK |
"I Love To Camp!"
"Comensing Shock Therapy!"
HeatWare
Evilsizer is offline   Reply With Quote
Old 09-29-09, 02:16 PM   #159
checkeredhat09
checkeredhat09's Avatar
So I just noticed one thing when going over this thread...I saw that most of those people that were getting pretty high clock speeds had Q8200's with revision M1. That would mean that they are spec number SLB5M. I have a Q8200 that has "A" Stepping with revision R0. I have not been successful at OCing this hardly at all. Just wondering if that might have anything to do with it.
BTW my specs
Intel Core 2 Quad Q8200 @ 2.33 GHz Spec#SLG9S
ASUS P5N7A-VM Motherboard
G.SKILL 2x2GB DDR2 800
APEVIA brand 500w PSU (included with case)
checkeredhat09 is offline   Reply With Quote
Old 09-29-09, 04:58 PM   #160
turbohans
turbohans's Avatar
Quote:
BTW my specs
Well for a good OC on your cpu you will also needa good oc on your ram seeing as 800mhz will only get you to 2.8ghz@ stock.
__________________
Old 09-29-09, 05:30 PM   #161
checkeredhat09
Quote:
Well I'd just be glad to get to 2.8 at all. So to my dismay, somehow I can't even boot the system at 400 GHz FSB. In order for RAM to even be a limiting factor I would at least have to be able to run stable at 400 GHz. So RAM is a secondary concern atm. I just cant understand how all these people push 3.5 GHz and mine only survived 6 hours on Prime95 Blend at 375 MHz FSB!!!!!!
Old 09-30-09, 02:26 PM   #162
checkeredhat09
Well...now I don't think its my cpu's fault. I read somewhere online that the ASUS P5N7A-VM gets unstable at around 1500 Rated FSB. And due to my Q8200 low multi that translates to around 375 MHz....which explains Prime95 not working.
I saw online that with a C2D they got to like 3.3 GHz because that chip had a multi of 9. But with that multi, the FSB only had to be at 375 MHz.
So...maybe my mobo is choking my processor....thoughts?
Old 10-02-09, 04:30 PM   #163
SamSaveMax
SamSaveMax's Avatar
Pushing above 3GHz required PC8500 rams.
PC6400 rams like yours can be overclocked too. (max out around 850~890MHz)
Try 555-15 timing manually and bump its voltage to 2.1v
With that mobo....you may need to bump a lot of voltage to the NB due to its build-in graphic.
SamSaveMax is offline   Reply With Quote
Old 10-02-09, 07:50 PM   #164
Galganaban
Hey guys im dabbling in this cpu.. could you guys talke a look at my thread and give me your input?
http://www.ocforums.com/showthread.php?t=620256
( i guess i shoulda posted in here 1st.. sorry!)
Galganaban is offline   Reply With Quote
Old 10-14-09, 12:58 AM   #165
ArcturusVi
Some concerns or thoughts.
Have this, Q8200 M1 revision.
Currently have it at 500x7 with a memory ratio of 2. Board is a Gigabyte EP45-UD3P F9 revision
I have G.Skill 1066 running at 1000 at stock memory voltages.
CPU voltage I had to get to 1.3 for stability. Anything lower, and it'd eventually crash windows, let alone prime or F@H. Temps are in the mid 40's at idle, barely getting to 50 under load of F@H. Prime gets it to near 60. HSF is a Xiggy Dark Knight, lapped, with AS5.
Speedfan shows
Temp1-40C
Temp 2-31C
I am to imagine these are the chipsets, with their voltages and bandwidth set to auto. PCI-e is locked at 100mhz as well.
Any of this sound right? Or any areas of concern or further tweaking? It's been solid for a few months, doing near 24/7 F@H or gaming. I guess this means it's stable, but do temps and voltages seem right? Thanks.
It does pass prime95 under any test for 12-16 hours. I only turn it off to do other things.
Old 10-20-09, 02:21 PM   #166
kick
its about right temps too.
Depends if you are running cpu term on auto or not you will be running v high voltages thru if you are.
temp 1 is the system temp,probably (unless you reassigned a temp value) its a little high and its not taken direct from the nb or sb,I had to install my own temp sensor for nb.
temp 2 is probably the cpu temp at idle,not cores temp.Speedfan should show those also
Personally ive gone down to 490 fsb because the voltages needed are much lower and I can still get 9gb bandwidth.
Check out tweaktown since you have a gigabyte board.
__________________
Coolermaster V8
memory "turbo" pl 9
Jeantech 500w psu
1TB WD HDD
Old 10-20-09, 09:57 PM   #167
ArcturusVi
Thanks for the tips. I got it at 3.4GHz with auto everything besides divider and memory voltage. Passed Prime for all night. Seems a lot more stable now.
Old 10-21-09, 03:59 AM   #168
kick
I used to run my UD3 with a lot of auto settings for 5-6 months.
At 490 fsb PLL V will go to 1.7V+! and cpu term to 1.6V
At 500 fsb PLL V will go to 1.8 and cpu term to like 1.65v
personally i think these are too high for long term usage and it took a lot of adjusting in bios to get PLL down to 1.57-1.6 and cpu term down to 1.34-1.37.
Save the bios setting you find stable (F11 and F12 keys for saving and loading bios).
Then load and save optimised defaults and work from there.
I loaded in the cpu ref and mch ref voltages shown with optimised defaults loaded..once you do that they will automatically increase at the right percentage as you increase the other settings.
Up to about 470 fsb people seem to be able to run voltages very close to stock after that the V's needed go up rapidly.
510 for me needs over 2.3v for memory alone:2.08 needed for 490.
Then again my 800mhz mem wont go much above 1000mhz easily.
cpu below 490 1.25V approx.490 1.34v approx.500 1.39 v approx etc.
A lot is down to board/memory/quadcpu fsb limits with our low multiplier.
__________________
Coolermaster V8
memory "turbo" pl 9
Jeantech 500w psu
1TB WD HDD
Old 10-21-09, 12:45 PM   #169
Steven-1979
1.8/1.65 auto settings are definitely a lot more than needed. Hardware Canuks did test these settings extensively, including a 100 hour stress test, and never had any problems. But I do suggest lowering everything to as low as possible while still maintaining stability just for the long term health of the cpu and producing less heat. I found vtt increases to cause even more jumps in heat than vcore.
__________________
Currently upgrading to new system
CPU: Intel E8500 (@ 4.5 ghz)
Motherboard: GIGABYTE GA-EP45-UD3P
RAM: 4gb Corsair Dominator DDR2 1066 w/ RAM cooling fan (@ 1138 mhz)
Cooling: CPU/GPU/NB = Water Cooled
Graphics: EVGA GeForce GTX 260 core 216 (@ 771/1566/1298)
PSU: Corsair tx 650w
Steven-1979 is offline   Reply With Quote
Old 11-16-09, 04:02 PM   #170
tanderson
hey guys, ive been reading this thread a little bit. and am having problems. with nothing changed but the FSB and ram multiplyer in bios i can only get it to 2.55Mhz.
im not quite sure how to change the Vcore or anything else about the Ram or any of that. can someone point me in the correct direction to get the Q8200 up to 2.8 or so? and could you be a little specific, im not sure what "vcore" is labeled as in my bios i see CPU Voltage control and Normal CPU V Core. can ya'll also explain a little of what it does and what i should change it to?
Thanks guys!
tanderson is offline   Reply With Quote
Old 11-16-09, 04:40 PM   #171
Evilsizer
Senior Member
Evilsizer's Avatar
for starters for us to help you, please list the specs of your computer...
__________________
"I Love To Camp!"
HeatWare
Old 11-16-09, 07:08 PM   #172
tanderson
i have a gigabyte p35-ds3l mobo rev. 2.0
6gb ram ddr2 at 667mhz is what bios shows.
1x2 gb is qimonda?
2x1 gb is samsung and other 2gb stick idk what maker it is.
i have the Q8200 processor overclocked to 2.55ghz with all settings stock except turning off C1E and EIST and have the multiplyer set at 2x
and cpu V core is stock at 1.23750V
need more info?
Thanks for the response!
Old 11-16-09, 07:12 PM   #173
Bobnova
Bobnova's Avatar
Send a message via AIM to Bobnova
I think the ram is probably your issue, it's already running at it's maximum speed.
You could try loosening the timings (if they're 6-6-6-18 now, set 'em to 7-7-7-21, the 4th number should be the first three put together generally), that may buy you a bit more OC.
If your bios has an option for 533 ram speed use that, but i doubt it will.
__________________
Join the OCF Benching team! We're taking over the world!
Max CPUz's:
E1200(1600)@3328..|....|.
E6300(1860)@3725..||.||||
E4500(2200)@4528..||...|.
Q6600(2400)@4572..||.|||.
E5200(2500)@4807..||.||||
E6600(2400)@4932..|||.||.
i3 540(3066)@5798..||....|
My heatware.
Bobnova is offline   Reply With Quote
Old 11-16-09, 07:14 PM   #174
tanderson
okay how do i change it to 7-7-7-21. i havent seen anything in my bios that shows the numbers like that. and what if it is set differently?
thanks for the input. and should i get new RAM will that make things easier?
Ive read people can get to like 2.8ghz with just upping the FSB.. i cant even get to 2.59 by upping the bus anymore than it is. but it runs stable now.
Thanks!
Old 11-16-09, 08:32 PM   #175
Evilsizer
Senior Member
Evilsizer's Avatar
well the reason why it wont oc higher right now is because of the ram. simply the ram is rated for DDR2-667, since that is dual data rate. take 667/2=333.33, so be all accounts your highest rated per that stock ram is a 333.33 fsb. how ever you have it running higher at 2.55/2.59ghz.
what your looking for is this
http://www.xbitlabs.com/images/mainb...35-ds3l/b4.jpg
to get there from the main bios
http://www.xbitlabs.com/images/mainb...35-ds3l/b1.jpg
go to the MIT section, there you should find ram section for timings.
**source link**
http://www.xbitlabs.com/articles/mai...l_6.html#sect0
one thing you could do for us before hitting up the bios... is going to www.cpuid.com and getting cpuz and post a screen-shot of the memory tab. You might get lucky though and have ram that can run higher with a bit of work. Overclocking in some cases can require a bit more elbow grease then what some let on.
__________________
"I Love To Camp!"
HeatWare
Old 11-16-09, 11:48 PM   #176
tanderson
the ones of the memory itself is just a little extra in case you could grab more info. the first one with the 3JeDec 1-3 has 4 gbs total running the same and the last one is a 2gb stick not sure of maker and it runs differently than the other 3 sticks.
thanks for the help i will now read the links you gave me
Old 11-17-09, 12:46 AM   #177
tanderson
i found the "(SPD)" but it wouldnt let me change the ram timings it would only allow me to change the multiplier which is set at 2
Old 11-17-09, 03:07 PM   #178
tanderson
so i finally got it up to 2.60Ghz!
i changed ram timings from 5-5-5-15 to 6-6-6-18 almost loaded but didnt. then went fron that to 6-7-7-20 and now it is up and running, also changed the DDR2 OverVoltage control to +.2 and upped the Vcore to 1.24375v.
running a test right now and will let it run for a couple hours and let ya'll know the results.
Old 11-17-09, 04:49 PM   #179
Evilsizer
Senior Member
Evilsizer's Avatar
have you run memtest86 on the ram at those settings? the ram timings are really loose for what most consider low speed on the ram. is negating any performance increase from the increased clock speed. i would say consider getting new kit of ram to use, something that is either, DDR2-800 cas4 or DDR2-1066 cas5.
__________________
"I Love To Camp!"
HeatWare
Old 11-17-09, 05:30 PM   #180
tanderson
it ended up not being stable. so i changed it back to what was stable. so you're saying i should go down to like 4-4-4-12? that didnt even boot up at all so i kept raising it and it finally boot at 6-7-7-20 and was stable for a little while but finally froze.
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
