Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
pIII cpu overclock
Thread Tools
Old 01-15-02, 05:08 PM Thread Starter   #1
dirtfarmer
pIII cpu overclock
first off i had fun with my computer it would crash sometime that even the BIOS would not run nothing it happen a 3 time a dealer thought it was a motherborad but end up replaceing the chip a 433 Mhz to a pIII 800 Mhz or what was suppose to be a 800 Mhz, i look in the bios he has it over clock by 100-> 133 Mhz to make it a 800 Mhz, if the overclock was disabled it a a 600 Mhz, now that not normal is it ??????????? to over clock by 200 Mhz, so it not ready a 800 cpu is it ????????? i got short change i feel maybe and maybe not ????????
a side question it a cpu stop work for any reason, could you still get in to bios, as my computer when it stop it all stop i got nothing no sound or window no bios nothing, and ontil now no one fique it out maybe so is a cpu connect to the bios in any way:
dirtfarmer is offline   QUOTE Thanks
Old 01-15-02, 05:21 PM   #2
jazztrumpet216
Senior @ss
10 Year Badge
First off, welcome to the forums.
Yes, it is quite normal. That CPU has a locked multiplier of 6. 6x100 = 600. Now, if you raise the FSB to 133, it's 133x6 = 800. No, it is not really an 800MHz CPU, it is a 600MHz CPU overclocked... and to sell an overclocked CPU as one that isn't overclocked is deceitful and illegal.
Side note: If your CPU is overclocked, that might be why your computer doesn't want to boot up sometimes. Keep it at it's 100MHz default setting and see if it keeps happening.
jazztrumpet216 is offline   QUOTE Thanks
Old 01-15-02, 05:56 PM   #3
cw823
Honeybadger Moderator
cw823's Avatar
10 Year Badge
Although, it's still a much better deal than the 400 he had in there....even at 600. I would call him and ask him questions about overclocking and the SOB's that overclock and sell (without properly informing the consumer). If nothing else, I'll bet ya could scare the guy.
cw823 is offline Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 01-15-02, 06:39 PM   #4
vlovich
You could use the FrequencyId utility from Intel to make sure the CPU is running at the correct speed. if it's not, then it will tell you if the cpu is overclocked. If the dealer sold you an overclocked CPU you have the right to sue or ask at least for the real chip for no extra price. This falls under misrepresentation and is a crime punishable by law.
vlovich is offline   QUOTE Thanks
Old 01-15-02, 06:43 PM   #5
jazztrumpet216
Senior @ss
10 Year Badge
Here's a link to that page with info on the Intel Frequency ID utility.
Intel Processor Frequency ID
Old 01-15-02, 06:44 PM Thread Starter   #6
dirtfarmer
hi found the prgram but i still do not understand why it has to be over clocked when the intel prgram tell me it ok, BIOS or motherborad can not take it maybe ?????
i found a prgram that read you id of intel chip, intesting
http://www.intel.com/support/process...cyid/index.htm
of which my gave me the follwing result
Intel(R) Processor Frequency ID Utility
Version: 4.0.20020109
TimeStamp: 2002/1/15 15:46:43
Number of processors in system: 1
Current processor: #1
Processor Name: Intel(R) Pentium(R) III Processor 800EB-MHz
CPU Type: 0
CPU Family: 6
CPU Model: 8
CPU Stepping: 3
CPU Revision: 0
L1 Instruction Cache: 16 KB
L1 Data Cache: 16 KB
L2 Cache: 256 KB
Packaging: S.E.C.C./S.E.C.C.2
MMX: Yes
SIMD: Yes
SIMD2: No
NetBurst(TM) microarchitecture: No
Reported processor Frequency: 800 MHz
Reported System Bus Frequency: 133 MHz
Expected processor Frequency: 800 MHz
Expected System Bus Frequency: 133 MHz
Old 01-15-02, 06:53 PM   #7
jazztrumpet216
Senior @ss
10 Year Badge
Do you have SiSoft Sandra??? Maybe that can shed some light on this. If you don't, I think the download section of www.cnet.com has it. That might be able to tell you more as well. I think maybe the Proc ID program just sees the 133Mhz bus and assumes everything's OK.
Old 01-15-02, 06:55 PM   #8
vlovich
I was posting a reply to something different. I was just telling you how to make sure that you weren't tricked into buying an overclocked processor. Why the bios won't load up i don't know.
PS The intel cpuid prog is the ultimate source for deciphering the real speed of the Intel CPU. If it says that it's a 600/66 then it's a 600/66. If it says it's overclocked to 800/133, then it's overclocked to 800/133. The intel prog read info directly from the CPU which has the info about itself as to it's correct speed.
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
