Notices
Overclockers Forums > Hardware > CPUs > AMD CPUs
AMD CPUs
Forum Jump
AMD Phenom II (Results Only Thread)
Thread Tools
Old 02-10-09, 07:34 AM   #21
Deadphishy
__________________
FX 6100 @ 4.2ghz @ 1.425Vcore
Antec Kuhler 620 (Just for looks)
ASRock 970 Extreme 4
4X4GB Kingston ddr1600
4850 1GB with Zalemen VF770 cooler
120GB Vertex 3 SSD.
1TB NAS
Corsair GB600
Case = Wall
My forever belongs to you MCM- (Now MCD)
Deadphishy is offline   QUOTE Thanks
Old 02-16-09, 01:29 PM   #22
ChillPhatCat
ChillPhatCat's Avatar
Still dealing with some motherboard issues, but I've arrived at a new stable record... previously it was 3.6, now we're up to 3720... motherboard still has some issues, I'm gonna be upgrading to a Biostar TA790GX soon to resolve this. I have booted into windows at 3900MHz and 1.55v, but it would get too hot to test, I think it would be stable there at 1.6v.
About My Computer:
CPU = PII 940BE CACVC 0850EPCW, Stepping: 2
mobo = EVGA 730A
Ram = 2x2gb PC8500 OCZ Platinum
HD = 120 Gb SATA Barracuda, 320 Gb SATA Barracuda, 750Gb WD Green Power
PSU = Coolmax 700W Modular
PCI-e = ASUS EAH4700DK, 1Gb @ 835/1100
Cooling = Thermaltake SI-128SE, Lapped, AS5 Grease
Case = Closed system, Lian Li A05B mini tower
Operating System: Windows x64 7 Beta
On stock cooling and voltage, I got to 3400 MHz, 200x17 with it seemingly stable, I'm quite confident the computer resetting at 1hr 10 mins on prime was due to a really high accidental NB voltage that has since been corrected.
Stable in Win XP Pro:
3720 MHz @ 240x15.5, 1.5v
HT@ 2160 MHz
NB @ 2160 MHz
Memory @ 480 MHz, 5-5-5-15-26, 2T 2.0v
ChillPhatCat is offline   QUOTE Thanks
Old 02-23-09, 11:52 AM   #23
batmang
My current 100% stable 920 result:
1.47v, everything else default voltages. Cooling is a water setup. D-Tek block, D-Tek pump, Swiftec 3x120 rad.
batmang is offline   QUOTE Thanks
Old 02-24-09, 06:17 PM   #24
cdawall
cdawall's Avatar
CPU = PII 945ES BE stepping FACOC 0825
mobo = Asus Crosshair II formula
Ram = 2x256mb micron D9DCD
HD = 320GB Seagate 7200.10
PSU = PCP&C 510w turbocool
PCI-e = XFX 8800GTS OC@stock
Cooling = custom water with a Aquaxtreme MC-05 pro block
Case = open case, ultra dragon modded to death
Operating System: Windows XP 32bit
__________________
Dual AMD Opty 8346HE's
Asus L1N64-SLI WS (Flashed /B)
4x1GB D9GMH
Sapphire 4850X2 2GB
32GB SLC supertalent SSD
cdawall is offline   QUOTE Thanks
Old 03-01-09, 09:39 PM   #25
NIR_Meteor
Just got my new liqiud cooling setup. 3.9 so far.
NIR_Meteor is offline   QUOTE Thanks
Old 03-08-09, 08:52 PM   #26
cdawall
cdawall's Avatar
did some oc'ing with my frozen phenom
specs
2x256mb Micron D9DCD
onboard nv 8200
and my 4.9ghz validation keeps failing WTF?
this was done on all 4 cores and validated by save
__________________
4x1GB D9GMH
Sapphire 4850X2 2GB
Old 03-13-09, 04:57 AM   #27
budakinns
just put it together
CM 690
Asus m4n72-e
940BE
2x 2gb G.Skill ddr2 1066
WD 320gb + 160gb
GTX 260 not oc yet
Zalman 9700
running stable at 3.6 went for 3.8 but bsod in prime95 gonna mess with it some more tomorrow.
budakinns is offline   QUOTE Thanks
Old 03-27-09, 06:31 AM   #28
paolo.oliva2
My OC with 940
paolo.oliva2 is offline   QUOTE Thanks
Old 04-02-09, 07:42 AM   #29
soufigo
ok, seriously first time ocer here. =D i think i could go higher with more core voltage. but since its my first time, i stop here. stable tested 6hrs with prime 95, everest and amd overdrive stability test.
CPU = AM3 x4 810 Phenom II
mobo = MSI DKA790FX-GD70
Ram = 4x1gb team extreem DDR3 1600mhz(oc) running at 1260mhz
HD = 1x 1tb WD Caviar Black 32mb
PSU = Corsair 520HX
PCI-e = PC PCS+4850 512mb
Cooling = Coolermaster v8
Cased: NZXT Lexa Blackline
soufigo is offline   QUOTE Thanks
Old 04-06-09, 01:29 AM   #30
Big Dave
P2 X3 710 Foxconn A79A-S overclock on air
Well I have a stable system @3600mhz, X3 710 and A79A-S running at 277 fsb with 1.52 vcore. It seems like it will go higher without any additional vcore increase. Will see later on. I am enjoying this for the moment. I'm sorry, but I am having trouble uploading my screen shot.
Big Dave is offline   QUOTE Thanks
Old 04-06-09, 10:19 AM   #31
Big Dave
Quote:
I had to go with grayscale to get the file to be accepted. Herwe is some data that I left out of the first post.
CPU = AM3 710 Phenom II (see cpu-z)
mobo = Foxconn A79A-S Spider crossfire
Ram = 2x2gb PC6400 Patriot Viper @2.2v
HD = 1 WD black 7200rpm 750gb boot drive
PSU = Antec 500W modular smartpower
PCI-e = Powercolor ATI 4830 @749x999mhz
Cooling = Sunbeam Contact freezer 120mm fans x2
Cased system with CM690 by Coolermaster
Old 04-06-09, 02:44 PM   #32
dkizzy
Premium Member #15
Big Dave, nice work! I had my 4th core 8 hours stable on a blend test but recently I discovered that I have a bad ram chip, so now I do believe there is a decent chance I have a stable 4th core. The blend test helped me discover that one of my memory modules has gone bad, so I'll let everyone know how it goes testing with 3gb.
__________________
i7 2600k @ 4.4GHz, Corsair 600T, H70 Cooler
16gb GSkill Ripjaws DDR3 1600mhz CL8
Plextor M3 128GB SSD F/W 1.05
Samsung 830 128gb
2TB Hitachi 64mb cache
MSI GTX670 OC Edition
ASUS P8Z68-V Pro
Heatware Profile
dkizzy is offline Benching Profile Folding Profile SETI Profile Heatware Profile   QUOTE Thanks
Old 04-09-09, 04:15 PM   #33
Big Dave
Thanks dkizzy, I was never able to get the forth core, because I think the vendor patched the bios in the last update. I have been able to get to 3.7ghz, but it crashes in Windows 7 beta during stability test. I need to the voltage somewhers. Maybe the PLL needs more. I have some more fans coming, so this can wait until I get them installed. Here is a screen shot @3.7ghz.
Dave
Old 04-17-09, 01:40 AM   #34
gmony01
Heres my achievement so far. Keep clocking those Phenoms!!!!
CPU = AM3 720 Phenom II
Ram = 2x2gb PC8500 OCZ Reapers
HD = 2 x 320gb Seagate SATA II, 1x WD 250gb SATA II
PSU = Antec TruePower 650w
PCI-e = ATI Radeon 3870 512mb
Cooling = Zalman CNPS9700
Case = Antec Nine Hundred
__________________
Antec Nine Hundred Midtower PC Case
Phenom II 720BE@3720ghz 240x15.5
Foxconn A79A-S
OCZ Reapers DDR2 2x20048mb pc2 8500@960mhz
Zalman CNPS9700 LED
Visiontek HD 3870 512mb@864/1278
Antec Truepower Trio 650W
gmony01 is offline   QUOTE Thanks
Old 04-18-09, 10:37 PM   #35
edhand
edhand's Avatar
Best I was able to get out of my 920 w/stock cooler
edhand is offline   QUOTE Thanks
Old 04-19-09, 05:27 PM   #36
Xerran
CPU = AM2+ 940 Phenom II (RB-C2)
mobo = Gigabyte GA-MA790X-UD4
Ram = 2048MB x2 G.SKILL (F2-8500CL5D-4GBPK) DDR2 1100 @ 5-5-5-15
HD = x2 WD Caviar Black 500GB (WD5001AALS) SATA 3.0 HDD
PSU = OCZ GameXStream OCZ700GXSSLI 700W
PCI-e = Sapphire Radeon HD 4850 X2 2GB
Cooling = Laing D5 MCP655 Pump | D-TEK FuZion v1 CPU Block | Feser One - F1 - Cooling Fluid
Cooler Master Cosmos S Chassis
Xerran is offline   QUOTE Thanks
Old 04-20-09, 08:02 PM   #37
QuietIce
Disabled
First things first
Board = Asus M3A32-MVP/WiFi
Ram = Corsair XMS2-6400C4
HD = WD IDE
PSU = OCZ 600W StealthXTreme
PCI-e = 7300LE
Cooling = TRUE Black/Panaflo 38x120mm
Computer on the half-shell
Minimal vCore
3000 MHz (200x15) @ 1.15 vCore, 1:2, 1.15v CPU-NB, NBx10, HT Link x8
Everest 9479/3460/18.7
SuperPi (1M/2M) 23.015/0.55.30
SETI 3076/6990
3DMark03 3083
Aquamark 4011/14397
"Old fashioned" OC
3600 (240x15) @ 1.35 vCore, 1:2 but loose, NBx10, HT Link x5
Done with all the stock-speed, preliminary tests and running SETI now (at stock w/minimal vCore). I'll do that for two days to get a good work unit database before really OC'ing. I can already tell with the data shown that I'm going to have fun with this one ...!
Thanks to Sentential, BenBrown, pershoot, ChillPhatCat, and cdawall for also posting their stepping!
QuietIce is offline Author Profile   QUOTE Thanks
Old 04-26-09, 07:09 PM   #38
QuietIce
Disabled
Out of pedestrian into mundane.
3600 (240x15) @ 1.40v, 1:2 CAS 4, NBx10
Everest (read/write/lat) 12243/4315/14.6
SuperPi (1M/2M) 18.406/0.44.125
SETI 3842/9431
<<semi-stable - see post #42>>
3795 (230x16.5) @ 1.44v, 1:2 CAS 4, NBx10
Everest (read/write/lat) 12602/4126/14.7
SuperPi (1M/2M) 18.265/0.43.844
SETI 3877/8801
Old 04-27-09, 01:59 PM   #39
HousERaT
Senior Air Extraordinaire
HousERaT's Avatar
QuietIce: How hot does it get under load?
__________________
CM-690 | Maximus Formula | Ballistix D9GMH 2GB - 4-4-4-10 - 2.2v (active cooled) | E6850 @4GHz (L719B) 602 Bios 500x8 - 1.475v | Ultra 120 Extreme | 2x HD3870 840/1300 | Lite-On 52327s CDRW | WD 74GB - Raptor HDD | Corsair 620HX PSU | Windows XP Pro sp2 |
Support the OC Benchmarking Team The HD 4870/50 Thread The HD 3870/50 Thread The X1900XT/XTX Thread X800GTO˛ Thread Heatware
Make friends with your "FAST" - 90K 01SE - 77K 03 - 29K 05 - 19K 06 - 274K AM3 - single card all air baby!
HousERaT is offline   QUOTE Thanks
Old 04-27-09, 03:49 PM   #40
QuietIce
Disabled
Quote:
Well I did take that shot a little early. It's under load in the pic but hadn't been for long. It maxes out at 49-50°C. Still plenty of headroom if I wanted to push it but with WC just around the corner I don't want to exceed 1.45 vCore and ruin the chip for water.
As a side note I'll need to revise that top-end air a little - it didn't hold overnight. Currently back to tweaking but considering it ran 8+ hours that way it's got to be something minor so I don't expect the CPU speed to change, but it may need a different multiplier ...
Tags
ocfsticky
AMD CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
