- Nov 24, 2002
- Texas/Camp Lejeune, NC
***Keep in mind I am going with a custom built server and NOT looking for some proprietary DROBO type crap***
So I'm researching/planning out a massive (for me) file/media server and coming up with more and more questions. Especially regarding RAID. Now up until a couple of days ago, I was still in the ancient thinking that once you created an array that was your array. Want to keep your data and expand? Too bad! However, in my research I kept seeing people mentioning what sounded as if they were expanding their arrays over time with additional drives. I looked into it more and what do you know, the card I just got (Areca ARC-1260) for my future beast supports "online expansion." That's great. Now I can build this thing 2TB at a time.
But now I have more questions. To start the thread off, what about upgrading drive sizes? Now my impression is that the array has to use the same size drives. i.e all 1TB drives or if you throw a 2TB in with them it will only use 1TB of it. Or has this changed like the expansion capabilities? So the issue: what happens when I fill all 20 bays with 2TB drives in RAID 6 (hardware) and get to the point where nearly all that space is filled? Now I want to start gradually replacing those 2TB drives with 4TB drives without losing my data. How would one go about upgrading that as I obviously don't have a 20TB external drive to pull out? Anyone else run into similar issues or have any thoughts/ideas on that?
For those that are interested, the current planned specs (will be updated as changes are made):
Case: Norco RPC-4020 4U 20bay Hot Swap Case
Mobo: Gigabyte something or other, I can't remember the exact model now
CPU: AMD X2 Dual Core 2.6Ghz
RAM: 4GB PC2-1066
RAID: Areca ARC-1260 16 port PCIe 8x (does RAID 5 and 6!)
HDD: WD 2TB Drives
RAM: 4GB PC2-1066
HDD: WD 2TB Drives
