Notices
Overclockers Forums > Hardware > Power Supplies and Electronic Devices
Forum Jump
Case Fan using A 4-3 Pin Adapter Quick ?
Thread Tools
Old 08-14-09, 02:53 PM Thread Starter   #1
N3K0
N3K0's Avatar
System fan has failed. Service Immediately...
^^ Lies =-P
I wanted to hook up one of the fans on the Antec 902 to my MOBO to silence this error, but the Antec 902 only has 4-pin power connections.
This may seem stupid but I do not know which cable to get. I am probably just over thinking it.
http://www.frozencpu.com/products/11...Connector.html
http://www.frozencpu.com/products/91...Connector.html
If 2nd option can someone please explain that. // Not all 4-Pin fans can be used on all controllers, check max amp draw before plugging in your fan! //
Thank you in advance for any answer(s) or help.
N3K0 is offline   QUOTE Thanks
Old 08-14-09, 02:55 PM   #2
thideras
Banned Neckbeard Moderator
Premium Member #3
thideras's Avatar
If you go into the monitoring tab (not sure what it is called on MSI boards), you should be able to disable the fan warning/monitoring. Easier and cheaper than going the route you wanted.
__________________
Desktop: Gigabyte Z77X-UD5H | 3570k 4.6 GHz | 32 GB GSkill Ares | GTX 570 | 180 GB Intel & 2 TB total | Arch Linux and Windows 7
Main server: 37 TB raw disk | 2x Opteron 6134 | Asus KGPE-D16 | 48 GB RAM | LSI 8708EM2 | CentOS 6.2
VM Server 1: Dell R510 | 2x E5645 | 128 GB RAM | 4x 300 GB Velociraptor | Xen Cloud Platform (XCP)
VM Server 2: Dell R710 | 2x E5645 | 288 GB RAM | 8x 300 GB Velociraptor | Xen Cloud Platform (XCP)
"That's not overkill, or a lot. That's just thiderastic." -txus.palacios
Current projects: Rackmount Overkill (New) | 30/45 hard drive server
Articles: Rack Mounting 101 | Dell Perc 5/i Throughput Benchmarks
Past projects: Software RAID | The Dragon Case
My Website
Want to talk directly to all the moderators at once? Call the Mod Hotline!
thideras is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 08-14-09, 03:13 PM Thread Starter   #3
N3K0
N3K0's Avatar
systems specs were outdated sorry. Just finished updating them. Downgraded =-(
Also I looked in the BIOS on my current board but could not find anything that looked like it would disable the message.
Old 08-14-09, 03:15 PM   #4
thideras
Premium Member #3
thideras's Avatar
You almost have the same motherboard that I have in my server. Find the monitoring section where it lists out temperatures and fan speed. Hit enter on the CPU fan speed (should be 0) and select "ignore". Every Asus board that I've owned (a LOT) have had that option.
__________________
My Website
Old 08-14-09, 03:34 PM Thread Starter   #5
N3K0
N3K0's Avatar
No luck. My board is one taken from my old stock HP setup. Not sure if that makes a difference.
Old 08-14-09, 03:38 PM   #6
thideras
Premium Member #3
thideras's Avatar
If there is no option for it, is it that big of a deal really? If it is shutting down the system, I could understand; but if it is just pausing during the POST process, it isn't worth it.
__________________
My Website
Old 08-14-09, 03:40 PM Thread Starter   #7
N3K0
N3K0's Avatar
Meh, only $5~. Kinda being a perfectionist though. Any thought on which cable? =-P
Old 08-14-09, 03:42 PM   #8
thideras
Premium Member #3
thideras's Avatar
Both of those will not work, they are only power cables. What fan do you have? Does it have a "third cable" (RPM monitoring)?
If it only has two cables, the motherboard can't detect the RPM of the fan.
__________________
My Website
Old 08-14-09, 04:07 PM   #9
Marshmallow64
Marshmallow64's Avatar
The first one should work. He basically needs a 4 pin to 3 pin converter so that he can plug in the fan to the mobo instead of the psu.
__________________
:: Gaming Desktop ::
CPU: AMD Phenom II X6 1055T @ 3.9 Ghz 1.4v | MOBO: MSI 790FX-GD70 AM3
GPU: EVGA GeForce GTX 570 (732/1464/1900) | RAM: 4 GB G-Skill DDR3 1600
SSD: OCZ Vertex 120 GB | HD1: WD Black 640 GB | HD2: WD Black 2 TB
SC: Xfi Titanium Fatal1ty | PSU: Corsair HX 620 W
KB: Saitek Eclipse | MOUSE: Logitech MX 518
CASE: Antec 1200 | OS: Windows 7 x64
:: Laptop ::
MOD: Macbook Pro 13” 2011 | CPU: Intel Core i5 @ 2.3 Ghz
RAM: 4 GB DDR3 1333 | OS: OS X Lion 10.7.2
Marshmallow64 is offline   QUOTE Thanks
Old 08-14-09, 04:25 PM   #10
thideras
Premium Member #3
thideras's Avatar
Quote:
Except you are completely missing the point, there is no RPM fan cable. So even if he got the first one and plugged it in, the motherboard will still report the fan is not spinning. Neither of the cables he linked will work.
__________________
My Website
Old 08-14-09, 11:13 PM Thread Starter   #11
N3K0
N3K0's Avatar
So basically I would need something like this?
http://www.amazon.com/Antec-TriCool-...0309523&sr=1-3
or is it possible to cap it off with some sort of a, don't know the word.
More so curious about it now. Does not really both me this much =-P
Old 08-14-09, 11:39 PM   #12
CharlieCS
CharlieCS's Avatar
Am with thid on this one ,you can just get another fan with RPM monitoring . This is a cheap option http://www.petrastechshop.com/12yalod1cafa.html
Edit : didnt saw your last post yep that will work .
CharlieCS is offline Heatware Profile   QUOTE Thanks
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
