Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
[O/C]3 Step Guide to Overclock Your Core i3, i5, or i7
Thread Tools
Old 06-14-10, 05:31 PM   #101
DocNick
Nice guide man! Saves me for a lot of time!
DocNick is offline   QUOTE Thanks
Old 06-14-10, 07:10 PM   #102
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
to OCForums DocNick, glad the guide was helpful for you
MIAHALLEN is offline Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 06-16-10, 06:52 AM   #103
gosa
Great guide!
Found this forum searching google for some hints on overclocking my i7 860 and like some of the other posters I just had to register to post my appreciation.
Only problem I have now is to make a good chunk of time available to try this out without the gf complaining to much...
gosa is offline   QUOTE Thanks
Old 06-16-10, 06:53 AM   #104
Ace.
Ace.'s Avatar
good Guide!
Here my i5-661 @4,7Ghz LinX and Prime stable
Ace. is offline   QUOTE Thanks
Old 06-16-10, 09:31 AM   #105
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Hey guys.... to OCForums to the both of you!
Nice....thanks for stopping by Stick around a bit
Quote:
Originally Posted by Ace. View Post
good Guide!
Whoa ....nice OC
Old 06-21-10, 09:27 PM   #106
verysoon
Excellent Guide
never had i register in any OC forum just to say thanks.
where i come from, it's very hot, like always in the 30c ~ 34c range. 100% load on my stock intel cooler can easily hit 90c.
even thou, u made me dauntless in my impending attempt to OC, at least to 4ghz.
Thanks
verysoon is offline   QUOTE Thanks
Old 06-21-10, 10:01 PM   #107
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Thanks mate....glad it was helpful
Old 06-22-10, 01:41 PM   #108
gosa
I sure will...
Been doing some initial testing and I've managed to get my i7 860 up to 3,8GHz (BLCK190*20) so far... the voltages I've used are 1.3V for VCore and 1.3V for VTT - With that I'm stable for a full night, and temps keep between 75-79C running Prime95 which means I can do most of my "stuff" at temperatures around 70C.
I do have serious problems taking the step up to 4GHz though, because right now I just don't have sufficient cooling for that... Need some better fans in my box first (but that's a question for the "cooling" section.
Anyway - Thanks again for the guide, now I'm looking forward to the next step!
Old 07-17-10, 02:28 PM   #109
Joe12
QPI question
Hi, this is my first time overclocking. Thanks MIAHALLEN, for the amazing guide, it cleared up alot. I am overclocking an i7-930, and I have a question about the QPI clock ratio. You mentioned that it is a function of the bclock, so should I just keep the QPI clock ratio at 'auto' since it will be increased as I increase my bclock, or should I change it to something else? (I can chose between x36, x44, x48, and slow mode). If i do keep it at auto, when (if ever) would need to change it?
Joe12 is offline   QUOTE Thanks
Old 07-18-10, 02:32 PM   #110
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Hey Joe, to OCForums
If you leave the QPI ratio on "auto", most motherboards will set it to x36 when you OC....and that would be fine. If you'd like to set it manually, do so at x36. And no, there would never be a need to change that unless you want to push the bclock to the limit for benching (not for everyday use), in that case "slow mode" sometimes helps a bit
Old 07-31-10, 05:06 AM   #111
virang.dalal
Talking MB for i7 930 ??
I am planing for a complete update. I am getting a i7 930. Which motherboard is better?
ASUS P6X58D-E -- $239(apprx)
http://www.newegg.com/Product/Produc...SUS%20P6X58D-E
Gigabyte GA X58A-UD3R -- $209(apprx)
http://www.newegg.com/Product/Produc...82E16813128423
virang.dalal is offline   QUOTE Thanks
Old 08-01-10, 06:24 AM   #112
wkchan1979
thx MIAHALLEN for great info especially newbie like me!!
nod question here, if i would like to fix my CPU clock to 3.9Ghz but i doubt which option i should increase, either BCLOCK or CPU Multiple? there are few combination i can play around this two option to get 3.9Ghz but what is your suggestion? Increase BClock or CPU Multiple?
thx again!!
wkchan1979 is offline   QUOTE Thanks
Old 08-01-10, 06:26 AM   #113
EarthDog
Researches Meritless
LIES for the Front
Page and Super Mutterator
Overclockers.com Editor
EarthDog's Avatar
Unless you have an unlocked multiplier chip, you cant move your multi up outside of the turbo function (which on most boards can be permanent).
With that said, IMHO, thats the game, a nice solid bclck will improve performance a bit more than only a raised multi.
__________________
"We have more information and more ways of accessing it than ever, yet seem increasingly less inclined to do so."- Michael Wilbon
EarthDog is online now Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 08-01-10, 07:05 AM   #114
wkchan1979
thx! i tried play around and found Temp increase more if increase BClock compare to CPU multiple... too bad. btw another nod question, will SPD number lower will be better? i try change from Auto to 6.
thx a lot!!
Old 08-01-10, 07:09 AM   #115
EarthDog
LIES for the Front
EarthDog's Avatar
You cant change SPD number...thats just a setting for a specific speed. You would need to know your memory's default timings/voltage (the SPD you were talking about!). I would set those 4 main timings manually as well as the voltage.
You can change the memory latency speed though (which was what you were talking about with just the wrong terminology). I doubt you will be able to go to 6.
__________________
Old 08-01-10, 08:10 AM   #116
wkchan1979
Unhappy
you are right sir. it just died when try to restart. i have to reset the BIOS so should i put into Auto mode? as i saw memory frequency at bios shown more than 1333(default) = around 17++ when i set to auto mode and it can reduce by put the SPD to 6... would should i do then. thx again!!
Old 08-01-10, 08:14 AM   #117
EarthDog
LIES for the Front
EarthDog's Avatar
No set it manually as mentioned above.
Dont bother with CAS6 really. If 7 is stock, run it there.
__________________
Old 08-01-10, 08:42 AM   #118
wkchan1979
thx!! let me have a try and review again the tutorial. i must be miss out something that i yet understand... Thx!!!
Old 08-09-10, 07:29 AM   #119
ufc
Quote:
So, are you ready to start overclocking? After entering your BIOS and lowering the CPU & MEM multipliers, go to the voltages section and raise your IOH to 1.3-1.35V and your CPU VTT to +0.2V. Then restart your machine and go back into the BIOS
Quote:
If the test ran without error, raise the bclock by 10MHz, reboot into your OS and run the test again. If the test failed, raise the CPU VTT voltage by a small increment, reboot into your OS and run the test again
Quote:
What is the maximum safe CPU VTT voltage? Depends on a lot of things, but I feel like these are some basic conservative guidelines. If you’re running the stock Intel heatsink and fan, I would not advise more than +0.2V, if you are running a high end air cooler
So I am using a stock intel cooler with an i7 920 so you say in the first step to increase the CPU VTT to +0.2V and then perform a few tests if the first test fails to increase the CPU VTT by a small increment(what exactly is considered a small increment 0.05?) but its already at the maximum safe voltage. So do I just adjust the bclock frequency and leave the CPU VTT Voltage alone after setting to +0.2V in step one? Sorry just a bit confused here. Thanks
ufc is offline   QUOTE Thanks
Old 08-09-10, 08:26 AM   #120
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Quote:
That is correct Since you're using the stock cooler, my reccommendation for starting voltage, is also the recommended max, if you feel more would be benneficial, I would suggest getting a better cooler first
Good luck, and keep us posted. Feel free to start a new thread so more people will look at your questions
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
