Notices
Overclockers Forums > Hardware > CPUs > Intel CPUs
Intel CPUs
Forum Jump
[O/C]3 Step Guide to Overclock Your Core i3, i5, or i7
Thread Tools
Old 08-11-10, 01:01 PM   #121
Philippe
Hello, I'm new here and it is my first overclock attempt since celeron days (I think i had a celeron 500 running @ 800 mhz for years... not sure if I remember correctly). Thanks for your guide. It was much more helpfull than every other one I saw.
So I recently bought an asrock p55 extreme with i7 860 and a noctua cooler and I'm aiming for 3.8 Ghz and trying to keep the voltages as low as possible... But I wanted to see where my rig's limit was first so I got it to 4.1 Ghz stable, albeit hot thanks to your guide.
So here's my question: while determining the max bclock I realised that I can get it stable enough @200mhz to sustain 15 minutes of Prime95 with VTT voltage slightly above stock setting (1.23). But as soon as I hit 201Mhz (or more) the mobo refuses to POST and no amount of VTT voltage increase helps and I tried to raise it up to 1.5v (stock setting 1.21v ) + 0.3v like you said?? Is it normal or did I miss something ?
(maybe a cryptic bios safeguard option enabled? but then why allow me to break the 200 Mhz barrier in the first place?)
I am now running @ 182x21 with 1.225 vcore and all the other voltages at stock levels... and it looks stable though I'm still in the early stages of stress testing. Load temperatures do not go over low 70's. Thanks again for the guide. It's the best out there.
Philippe is offline   QUOTE Thanks
Old 08-11-10, 01:28 PM   #122
redduc900
Super Moderator
redduc900's Avatar
10 Year Badge
Try raising the PCH Voltage from the default of 1.066V to ~1.15-1.20V for BCLKs >200, this w/ VTT Offset Voltage at ~1.25-1.35V
redduc900 is offline   QUOTE Thanks
Old 08-11-10, 01:57 PM   #123
beuch
another newbie guide
I just used the Miahallen guide to overclock my i3 530 with an asus p7h55-m pro motherboard and kingston valueram. The guide was very informative and covered all the pertinent issues very well. I'm currently oced to 3.5 and I'm going to go up to 3.8 or higher once I replace the stock cooler.
My one complaint is that the guide could have been organized better. It seems like it is always leaping back and forth between instructions and explanations. I found this guide a bit more clear and concise and it offers virtually the same advice: http://lifehacker.com/5580998/a-begi...ntel-processor
I would recommend reading both guides. I believe the Miahallen guide provides more information but, for me, the lifehacker guide makes the actual procedure you are going to execute a bit clearer.
beuch is offline   QUOTE Thanks
Old 08-11-10, 02:15 PM   #124
Philippe
Thanks Redduc. I just tried that and still no POST. I just had to clear the CMOS again.
Old 08-11-10, 04:37 PM   #125
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
THanks for the feedback!
Interesting bclock wall you're running into...try raising the PCIe link speed to 105MHz and see if that changes anything
Thanks for the feedback, and the link. I'dd consider the info in the other guide when it's time to do the next update.
__________________
THE POST COUNTER IS NOT AN INTELLIGENCE METER!
Intel i3, i5 and i7 Overclocking Guides
Heat "Water & Wood" computer desk build log My HWBOT Profile
MAX11Lv3 - "It kind of reminds me of going to the circus and seeing a mini drive around and then 83 clowns jump out of it!" - ollien33
i7 3820 @ 5GHz || 32GB G.SKILL @ DDR3-2000 || GTX580 tri-SLI || Corsair AX1200 || Custom water cooling
MIAHALLEN is online now Author Profile Benching Profile Folding Profile Heatware Profile   QUOTE Thanks
Old 08-11-10, 05:48 PM   #126
Philippe
Thanks for the answer... I tried to raise pcie frequency but it still won't POST.
Old 08-24-10, 09:32 AM   #127
goldenlight
goldenlight's Avatar
This is a fantasic tutorial on overclocking.. Can't wait to try this later with my new hyper 212 plus cpu cooler.
I havn't overcloced a cpu since the old Athlon days.
__________________
Follow your Bliss.....
goldenlight is offline   QUOTE Thanks
Old 08-24-10, 11:40 AM   #128
Killador
Killador's Avatar
__________________
Core i7 920 D0 @ 4.2GHz, 1.32v (4.4GHz - gaming)
Gigabyte X58A-UD3R w/F6 Bios Update
Nvidia GeForce GTX275 1792MB 680MHz Core, 1482MHz Shaders, 1206MHz Memory OC
Nvidia GeForce 8800GT Dedicated PhysX Card
6GB OCZ Gold PC3-8500F (1066) @ (800MHz 8-8-8-20 Timing)
x2 500 Western Digital 3.0 SATA HDD
CoolMax CUG-700B 700W w/Modular Cables
HAF 932 High Air Flow Full Tower
Liquid Cooling on CPU including x9 Case Air-Fans.
Asus 22" 1080p LCD @ 2ms
Realtek HD Audio Onboard Gigabyte Technology @ 7.1 Dolby Digital Logitech Surround Sound Speakers
Windows 7 Home Premium 64-bit
Killador is offline   QUOTE Thanks
Old 08-27-10, 11:59 PM   #129
zez
zez's Avatar
Yes, yes. This tutorial was a great help. I've been out of the overclocking game for a while, and this tutorial got me up to speed.
Now my i7-930 is chugging along at a nice 4GHz
zez is offline   QUOTE Thanks
Old 08-28-10, 08:56 AM   #130
Aynjell
Mia just wanna say you rock, bro. I got friends who are using this guide on their first Intel chip. You're making their life very easy!
__________________
Do not break wind in the same room as a dark brother or sister; to do so is to invoke the wrath of Sithis. - Aynjell, in fond memory of Lucien LeChance
Aynjell is offline Author Profile   QUOTE Thanks
Old 08-28-10, 04:24 PM   #131
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Quote:
Thanks for the feedback guys, I'm glad it's helpful
__________________
Old 08-29-10, 01:22 AM   #132
minority01
i tryed following this guide but when ever i make the first changes to the voltage and cpu and memory Multiplier it wont boot
im using an i5-661 on a GA-P55-UD3 motherboard
reseting the bios works but it fails when ever i change it
please help
minority01 is offline   QUOTE Thanks
Old 08-30-10, 04:47 PM   #133
minority01
wait dont worry, i fixed it, updated the BOIS
also, do i need to worry bout the iGPU if my motherboard doesnt support it?
thanks
Old 08-31-10, 05:26 AM   #134
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
thanks
Sorry, I missed your first question....glad you figured it out
No, if you've got a P55 mobo, you don't need to worry about the iGPU, it's automatically disabled
__________________
Old 08-31-10, 07:31 AM   #135
dg170775
Hey Miahallen, great article. It sounds even more appropriate to someone like me who just started overclocking, without a lot of knowledge, on the terms, etc.
Today, I'm sitting @ a stable 4Ghz system, but, I am planning to again start from basics, based on your article.
I have a i3 530 on an ASUS P7H55-M board, with 4GB Corsair XMS3 1600Mhz RAM. I am relying on the iGPU as I'n not a keen gamer, and budget's constrained
One question: Was 26th Feb the last update to your article, as I did see a lot of further questions / answers? And there was an update coming out...
I will let you know how the OC goes.
dg170775 is offline   QUOTE Thanks
Old 08-31-10, 07:56 AM   #136
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
Yes, I started working on Rev 3.0 today....should be a week or two
Start a thread and let us know how it goes with that i3...great chip and most are good for 4.4GHz or more
__________________
Old 08-31-10, 08:00 AM   #137
dg170775
Cool... Looking forward to rev 3.0
For my current OC exercise, i've taken a print of your article with all comments / questions / answers, as there's plenty of information there, especially for my H55 board (ASUS P7H55-M)
Will start a thread soon .... and update progress ...
Old 09-07-10, 06:02 PM   #138
MIAHALLEN
Senior Member
MIAHALLEN's Avatar
__________________
Old 09-09-10, 08:21 AM   #139
dg170775
Hey Miah,
Sorry, have been a bit busy off late, but I can definately say that the Rev 3.0is a much refined upadte, as I used it to overclock my i3 530, right upto 4.24Ghz. I still have the potential to go higher, but, I've just taken a break.
But, this is for anyone starting fresh, like me, this guide is a dream ..
Continue the great work, Miah !!!
Thanks!
MIAHALLEN (09-09-10)
Old 09-09-10, 12:52 PM   #140
virupaksh
Help
Hi Dude,
I have a PC with i5 650 , gigabyte HPM-USB3 model nd 4 GB Transend DDr-3 1333. Now Will overclocking work properly on my pc and how can I attain the maximum frequency of my RAM. Im very new to all these overclocking concepts. Please help.
virupaksh is offline   QUOTE Thanks
Tags
ocfhowto
Intel CPUs
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
