Notices
Overclockers Forums > Hardware > Cases and Case Modding
Forum Jump
[O/C]Cooler Master CM690 II Advanced Review
Thread Tools
Old 03-22-10, 09:02 AM   #21
gcwebbyuk
gcwebbyuk's Avatar
Nice
What sort of temps do you get?
I was considering two MCR220s with a 655 pump, Apogee GTZ and a water block too.
At present, my silent air setup with stock CPU settings is getting a range of between 25c to 56c running OCCT PSU test. With fans on full, I get between 25c-50c.
Only change to the above pic is that I have moved the S-Flex E from the bottom of the case as an intake, and mounted at the top/back of the case as an exhaust.
__________________
CPU: Intel Core i7 2600k @ 4.9GHz
Motherboard: Asus Sabertooth P67 v2302
RAM: 16GB Corsair Vengeance 1600MHz 8/8/8/24
GPU: Gainward GTX670 Phantom
Sound: Asus Essence STX with LME49720 Op-Amps
HDDs: 3 x 128GB Crucial M4, 800GB WD8000AARS, 1TB ST31000524AS
Case: Corsair Carbide 500r
PSU: Corsair HX650w
CPU Cooler: Corsair H100 - 2x Scythe Slipstream PWM SY1225SL12HP
gcwebbyuk is offline   QUOTE Thanks
Old 03-22-10, 09:09 AM   #22
gcwebbyuk
gcwebbyuk's Avatar
With my modified Zalman cooler (2x Scythe 92mm gentle typhoons) - glad I have the VGA retention bracket to keep it supported!
I am getting GPU temps in OCCT PSU test of between 16c and 45c and with both fans on full - 13c to 31c! Thats with the card running at GPU-780MHz RAM-1090MHz!
__________________
PSU: Corsair HX650w
Old 03-22-10, 09:11 AM   #23
Owenator
Active Senior Member
Owenator's Avatar
10 Year Badge
Quote:
Originally Posted by hokiealumnus View Post
Awesome job Owenator!! That looks great.
BTW, I think you forgot to plug your motherboard back in.
Yeah it's not all juiced back up in that shot. I also removed the Thermaltake fans and just used two 140mm in the bottom of the case wiht no fans in the top.
Here it is all filled and running.
__________________
System: ASRock P67 Extreme6, i7-2600k @ 4.6 GHz, 16GiB Corsair Vengeance DDR3 1600, Galaxy GTX 570 & EVGA GTX570 in SLI @ stock, 120GB Corsair F120 SSD for Win 7 Pro x64, WD Caviar Black 1 TB for everything else, Lite-On Dual layer DVDRW, Cooler Master Silent Pro Gold 1200W PSU, CM690 II advanced case.
Accessories: ACER 23" WS LCD + ACER 21" WS for web/TS/etc. DIY 4-way monitor stand. Logitech G35 headset, Idelazon Fang keypad, Logitech G9 mouse, Zalman FPS Gun mouse, Logitech Extreme 3D Pro joystick, momo racing wheel w/ pedals.
Water Cooling : Replumbed to one single loop. Apogee GTZ CPU block, MCR220 w/ 2x Panaflo 120x38 'M's, MCR220 w/ 2x Panaflo 120x38 'H's, MCP350 w/ bored over Alphacoool top. MCP220 drive with second MCP350 in series w/first. 2x MCW60 GPU blocks Temps: TBD
Blackbelt Ubercloxx0r My Current Rig My First WC Rig DIY Nvidia Surround Setup
Owenator is offline   QUOTE Thanks
Old 03-22-10, 09:17 AM   #24
hokiealumnus
Water Cooled Moderator
Overclockers.com Lead Editor
hokiealumnus's Avatar
You don't have any fans on the rad up top?
__________________
Enjoy benchmarks? Join the benching team! | New to water cooling? Read the Beginner's Guide to Water Cooling Your PC.
xsuperbgx - "As a wise man once said: "Less talky. More clocky."" | cyberfish - "When overclocked, it's undefined behavior."
I.M.O.G. - "Vaseline on Ivy Bridge is a bad idea. But not so bad of an idea that it can't be fixed with a torpedo heater, a dishwasher, an oven, and a few hours. "
\m/ OverClockers mATX L33T Club \m/ - Join Now! - My mITX Build
hokiealumnus is offline Author Profile Benching Profile Heatware Profile   QUOTE Thanks
Old 03-22-10, 09:19 AM   #25
gcwebbyuk
gcwebbyuk's Avatar
Yeah I thought it looked quite slim up there - so is it just 4 fans in the whole system?
__________________
PSU: Corsair HX650w
Old 03-22-10, 09:25 AM   #26
Owenator
Owenator's Avatar
10 Year Badge
Quote:
You're both right - no fans on top. I was planning on the 140's up there but they don't fit. The existing 120's I have are too loud so I was running no top fans until I get quieter alternatives. I was thinking of using the rear 120mm from this case and then scavenging a second from the second CM690 II I have coming today. I am debating on a homemade window in the side also.
I've decided to keep the second CM690 II as I seem to always need spare mid size cases. Not sure what I'll do with the old Thermaltake Armor beast. Maybe a server?
__________________
Old 03-22-10, 09:28 AM   #27
gcwebbyuk
gcwebbyuk's Avatar
What sort of temps are you getting? Do you reckon the loop would handle one of your graphics cards too?
__________________
PSU: Corsair HX650w
Old 03-22-10, 09:28 AM   #28
hokiealumnus
Slim is fine - you can put 25mm fans in between the top panel & the case itself, so the only thing taking up space inside is the radiator.
Quote:
Originally Posted by Owenator View Post
You're both right - no fans on top. I was planning on the 140's up there but they don't fit. the existing 120's I have a re too loud so I was running no top fans until I get quieter alternatives. I was thinking of using the rear 120mm from this case and then scavenging a second from the second CM690 II I have coming today. I am debating on a homemade window in the side also.
I've decided to keep it as I seem to always need spare mid size cases. Not sure what I'll do with the old Thermaltake Armor beast. Maybe a server?
Ahh, gotcha. Just glad you're not leaving it fanless.
Do you have a boat? It might make a good anchor.
__________________
Old 03-22-10, 09:29 AM   #29
Owenator
Owenator's Avatar
10 Year Badge
I haven't started temp monitoring yet but now that it's fully bled I will. I really did this rebuild to get quiet more than cooler.
__________________
Old 03-22-10, 09:34 AM   #30
gcwebbyuk
gcwebbyuk's Avatar
Thats what I would be aiming for too. I use PC a lot at night and it's in our bedroom, so silence is priority.
Am adding 3 more S-Flex Es to the case, two on the bottom as intake and another up top as an exhaust. They will all be set to run at 660rpm so they won't be heard. I can then use them for the rads if I do go watercooled.
One change I have made to the case is to block off the two 140mm side vents, currently with just some sound deadening material as is sticks nicely, but looking for a better alternative. Blocking these off has made no negative change to the temps so am happy with that.
I also cut away the rear honeycomb style fan shroud on the rear of the case with a dremel to cut down on air turbulence:
__________________
PSU: Corsair HX650w
Old 03-22-10, 09:48 AM   #31
gcwebbyuk
gcwebbyuk's Avatar
Are there any side panels with windows cut in available for this case in the uk yet?
__________________
PSU: Corsair HX650w
Old 03-22-10, 10:00 AM   #32
hokiealumnus
There aren't any available in the US, at least from Newegg. They have none listed on their site either. if you want one, looks like you have to make your own.
__________________
Old 03-22-10, 10:05 AM   #33
Owenator
Owenator's Avatar
10 Year Badge
I saw the one at the CM site but I have no problem making my own. After I move/add the 120mm fans, I'll try by blocking off the side vents to force the airflow up and out like gcwebbyuk did. That should help my setup. MI don't think I need the rear fan either as my two GTX260's move a lof of air out of the case.
__________________
Old 03-22-10, 10:38 AM   #34
gcwebbyuk
gcwebbyuk's Avatar
I am just thinking, if I go down the route of watercooling, then a side window to show it off would look good. I may consider getting one made for me, maybe even with tinted perspex/acrylic so it still has the stealthy look. I think if I don't go full watercooled then I may get an H50 or try a CM V10...
Just got an email from CM saying they are soon to have the side window available in the uk, but no date as of yet.
__________________
PSU: Corsair HX650w
Old 03-22-10, 11:46 AM   #35
Owenator
Owenator's Avatar
10 Year Badge
In the US Tiger Direct has them listed as RA-692-KWN1.
http://www.tigerdirect.com/applicati...ey=RA-692-KWN1
__________________
Old 03-22-10, 11:49 AM   #36
hokiealumnus
Ooo...that's sweet, and they're only $20. Nice find!
__________________
Old 03-22-10, 01:05 PM   #37
baneonrt
Here's a picture of mine with the side window. Gives you a better idea than the tiger direct product page.
Steve
__________________
Intel i7 930 on MSI X58 Pro-E w/ 6B Corsair XMS DDR3
Corsair H50 Cooler
EVGA 275 GTX
1TB WD Black 64MB, LG GGC-H20L Blu-ray
Coolermaster 690-II Advance w/OCZ 700W PS
Dell Ultrasharp U2711
baneonrt is offline   QUOTE Thanks
Old 03-22-10, 01:10 PM   #38
Owenator
Owenator's Avatar
10 Year Badge
Quote:
Nice! Is that a 120mm of 140mm fan in the window?
__________________
Old 03-22-10, 01:22 PM   #39
baneonrt
120mm. Don't remember which brand...Hyper something. Too loud at 12v so I run it at 7.
Steve
__________________
Corsair H50 Cooler
EVGA 275 GTX
Old 03-22-10, 01:41 PM   #40
Owenator
Owenator's Avatar
10 Year Badge
Steve
Thanks! I was wondering how big that opening was in the clear "grill" part. I am trying to reduce my fan count or use as big of fans as possible.
__________________
Forum Jump
Search this Thread:
Advanced Search
Mobile Skin
X
Welcome to Overclockers.com
(4 digit year)
Why Join Us?
  • Share experience
  • Max out your hardware
  • Best forum members anywhere
  • Customized forum experience
Already a member?
