- Jan 11, 2008
My motherboard listed in my sig (ds3l) died a painful death last night. I had installed a TRUE and a new Q6600.
Things were going well, and I had the Q6600 overclocked to 3.6 GHz, but I was having difficulty getting in prime95 stable for more than an hour or so. The temps were good, at like 60C load, so I bumped up the VCore to 1.525. The readings in cpu-z were 1.4V under load, and again, the load temps were in the low 60's.
I was running the mch and fsb voltages the same as I have been for years. The difference was that I had never taken the board up to as high of VCore before.
Everything seemed cool, so I set it to prime 95 overnight. When I came in here this morning the computer was off and the room stunk like fried electronics. Upon further inspection it looks like the voltage regulator on the motherboard caught fire. It is covered in black soot and so is the motherboard tray.
I've taken the computer out of the den and have been testing the other components one by one. So far the CPU and RAM check out. I'm getting ready to test the video card and the HD's.
I'm getting ready to post some pics in about 10 minutes, and I'd like some feedback as to what might have gone wrong so I don't repeat it again. This was the first time I have used a HS with a backplate, and although I think I did it right, please use the pics to make sure.
I looked around the area and there wasn't any apparent contact between the MB and the MB tray.
My guess is that this MB just couldn't handle those higher voltages provided to the CPU. The Vdroop on the thing was crazy (>.1V), and I was trying to compensate for it by upping the voltages.
Thanks for the help.
